My modem become wrong because i crack it, how can i do?
    President:
  • 2,340 Answers
Modem for ADSL with RJ45 ports.
1. If your external modem and if it is broken/crack replaced it with a new unit.
2. If the modem is internal & the RJ45 port/jack is broken ie.built-in with a Laptop/notebook, you can buy a external USB modem.
Hope it helps.
Posted on May 22, 2011
I need mt 6225 usb modem drivers
You can download MT6225 USB modem driver from " http://www.downloadkeeper.com/mt6225-usb-modem-driver-free-download-crack-serial-download.html", or " http://www.warezaccess.com/search/mt6225-usb-modem-driver-free-download.html". Hope these will help you.
May 25, 2011 | Computers & Internet
Modem has become security enabled and we have never password protected the modem. How do I un-security or disabled this so we can access wireless?
look on the back of the modem near the power input jack and find a little hole that you can stick a unbent paper clip in and hold for about to seconds to reset to factory specifications.
Jan 10, 2011 | Arris SURFboard SB5120 Modem
My motorola SURFboard SB5101 has a on power light, a blinking recieve light, and an on PC/Activity light, with the other lights off. what is wrong with it?
The light pattern you have described indicates that the modem can not establish a connection to your internet service provider (ISP). This is typically do to a signal related issue. To trouble shoot the problem you will need to connect the modem directly to the main cable line where it first enters into the home. You will know when the modem establishes a connection by the top 4 lights becoming green. If at any point all 4 top green lights start to blink in sequence than you will need to contact your internet service provider to "unwall the modem". Remember most internet service providers require you to register your modem on there network. So if you have not all ready completed that process you will most likely not have access.
I hope that information above has helped is some way.
If possible please rate this solution.
Sep 01, 2010 | Arris SURFboard SB5101 Cable Modem
I bought a Vigoro deluxe water timer last spring, it worked fine all summer. This year I can't seem to get it to work, I hook it up to the spicket and the water runs thru the whole thing and in on the...
I had the same problem with several of mine. So I tore one apart. The problem isn't that the valve doesn't close. The valve uses a rubber diaphram that flexes in and out, sealing off the water supply. The rubber diaphrams develop cracks, allowing water to pass through the valve. The rate of water flow depends on how large the crack is. The crack will become larger over time as the valve moves the rubber diaphram in and out. The diaphram can be easily replaced. However, these units are not designed to be taken apart and repaired and I can't find a replacement for the diaphram. The bottom line is that once the diaphrams crack (and my experience is that they all do within 1-2 years-time), you have to throw it away and buy a new timer.
Jun 14, 2010 | Garden
Need help to install router, westell modem already installed
Turn off the modem (unplug it). Plug the eithernet wire into the router and into the modem. Turn on the modem - when lights become stable, turn on the router. - when the lights become stable, turn on your wireless computer. Make sure your wireless is enabled. Use the wizard you will find in Networking (Control Panel).
I love Network Magic for network management, You may choose to get this program and use it. Google "Network Magic"
I hope you find this post informative.
Oct 18, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Forgot pin # and screen is crack.?
PUK code in PIN UNLOCKING CODE, which is required when you give PIN number wrongly for 3 times,
This code is OPERATOR specific and not phone specific and you have to call you operator and get PUk if PIN is blocked...
if you provide PUK code wrongly for 7 time, you sim may become useless, then you have to buy new SIM
NOTE: You should ask your service provider..
Sep 05, 2009 | Dual Electronics CECT P168 Cellular Phone
Modem
You want a 56K modem at least. Modems are becoming less common these days as brpadband (DSL/Cable/WiFi,etc) are becoming more cost effective.
Does your computer take PCI cards? If so, you might be able to find a PCI modem. There are also some serial modems still being sold. If your computer has 9 pin serial ports, you could try to use a serial modem. I think there also might be a USB modem that you could use, providing your PC has serial ports.
Mike
Dec 21, 2007 | 2wire (1000-000057-000) Modem
Im having problems getting my modem to get online. The light wont come on. All but the online light come on. The online light blinks then all the lights go off except the power light, and the receive...
Your modem is not synching. It could be a number of possibilities, and you're going to have to do some troubleshooting to narrow it down.
  • Verify that your AC, Cat 5, & ethernet cables are connected securly
  • Verify that your modem is not in "standby" mode
  • Power cycle your modem
  • Try a different cable outlet
  • Call your ISP to make sure your modem is provisioned and your service is set up for cable internet.
Nov 06, 2007 | Arris SURFboard SB5120 Modem
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
