In printer cp 3525 black car... is finished i refiled it atd try to re install... but there is a memory error is there how to solve
    Scholar:
  • 61 Answers
Some ink cartridges have a tiny circuit that tells the printer when it is out of ink and refilling want reverse the circuit. If it is a refillable cartridge and has worked before after refilling I would check my print head to see if it is clogged. Also there's the murphy's law probability-- you haven't got enough ink on you and everything else for it to work. I always got it all over me and in he floor with none left for the cartridge. hope this helps, printer can run you crazy; dhgill1949
Posted on May 22, 2011
I have laser printer hp 3525 and printer don't mix colours properly so letters are to be printed green the yelow color print seperate and the blue seperate ,so the the print come with two letters as if...
> go to menu, apply set of default setting, then check..> go to menu, device setting,quality,calibrate color,calibrate now.. printer performs color calibrate, after completion, check the print quality. I hope it will resolve the issue.> if above said advises are not resolved the issue mechanical adjustments has to done which is not suggestible to the users.. only professionals can perform the activity.
Oct 05, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
I have refilled my HP4280 black ink cartridges with ink bought from ebay which is apparently the correct ink for this printer. It worked once no problem, but now the printer is saying there is a cartridge...
No. There is something wrong with the electronics on your cartridge. Most likely what happened was that there was ink clogged in your print head and when you continued to print there was no ink flowing through the nozzles to cool them so they overheated and fused. Causing the electrical error. You need to get a new cartridge refilled or not to solve the problem. I recommend Cartridge World refills because they make sure these problems don't happen to customers.
Jan 27, 2010 | HP DeskJet F4280 All In One Printer InkJet
Can anyone here solve my problem on the refilled black ink #830. I recently refilled the black cartridge then I installed it to the printer but indicates an error on black. Can anyone help me on this...
I think those cartridges are chipped to tell the printer how much ink is in them. Look for a chip zapper from the internet and as you search the solution will become evident. You need to probably reset the chip.
Jun 13, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Error "remove and check color cartridge" after cartridge was refilled.
try cleaning the contacts opd the color cartridge
with a wet towel
if the problem is not solve return the cartridge in the shop you get it and ask them to replace it
Apr 13, 2009 | HP Photosmart 2610 All-In-One InkJet...
Fairly new toner and display reads "Install black cardtricge"
I have just resolved the "Install black cartrige" issue on my printer I am not sure if it will solve everyone's problem but these are the steps I took to solve the problem.
1. removed the black cartrige.
2. removed all the paper from the tray and noticed that one of the pages was a little jammed.
3. I then turned the printer on and off again and still encountered the "Install black cartrige" error message.
4. I then put the black cartrige back in the the printer and restarted the printer.
5. When the printer restarted it started to initialize correctly and I perform some test prints to confirm that it was back up and running.
Apr 07, 2009 | HP LaserJet M1522nf Multifunction Printer...
Getting error message on samsung clp 510 printer
yes refilling will solve the problem.but you have to change the green colour small chip on the side of the toner to make it work,as the new chip will be detected as new toner in the printer.
Jul 28, 2008 | Samsung CLP-510 Laser Printer
My Dell 962 Photo Printer gives error when trying to photocopy.
The issue you are experiencing with your printer i.e error 2200 is related to "Scan Carrier Stall error" I believe the steps mentioned below will fix the issue,
1. Unplug the power cord from the wall socket.
2. Disconnect the power supply from the back of the printer.
3. Wait 15 seconds.
4. Reconnect the power supply to the back of the printer.
5. Plug the power cord back into the wall socket.
  1. Go to www.support.dell.com.
  2. Click on Drivers & Downloads.
  3. Under Option 2: Select a Product as printers .
  4. Locate the printer(s) 962 printer and click Go.
  5. Select an Operating System that is installed in your computer then choose downloads and look for Firmware.
  6. Download and install the firmware, then restart the computer and the printer, however please make sure that you do not restart your computer and the printer when the download and the installation is in progress.
I would appreciate if you could let me know if you have refilled the black cartridge, cause Dell printer often give error messages if the cartridges are refilled and not replaced with an original Dell one. If you have done so please replace the cartridge with a genuine Dell cartridge.
Regards
Malik Khan
Jan 24, 2008 | Dell 962 Photo All-In-One InkJet Printer
Canon thermal printer cp-330
search for canon cp-220. There is an explanation of the problem. Good luck.
Nov 27, 2007 | Canon CP-330 Thermal Photo Printer
51 people viewed this question
jasbo
jasbo
