Question about Sony CDX-S2210 CD Player
My sony cdx-s2210 not working. It lights up in my car, but I can't get the controls to work, nor will the stereo come on. I was fiddling with the buttons a while back and then it just wouldn't work any more. If I take out the face plate and put it back in, I can play a cd. I just can't control the volume or change the track. The screen constantly cycles through all the different mode names, but none of the buttons will operate. I did push the reset button that someone had mentione, but to no avail. Any other things I should try?
  • 59 Answers
SOURCE: sony CDX-M8800 face plate is non responsive
There is a ribbon cable that tells the face what to do. You will have to take it in to get serviced as it is very hard to change. There are alot of pieces / parts inside.
hope this helps
Posted on May 30, 2008
SOURCE: CDX-S2000 Volume, Source, and Mode buttons not working????
Hey jshaff, try taking off the detachable front, and you will see a reset button, press and hold in for 10 secs, this should solve your problem. if it doesn't work first time keep trying. you must have power to the head unit for this to work. you will hear the cd make a noise and that should be that, try and let me know.
Posted on Oct 04, 2008
  • 4 Answers
SOURCE: i have a dual xdmr7700 stereo and lost the manual need to get the face plate off
Same problem as yours with my deck. Bought the deck a month ago, turned car on in the morning face plate does not move down, music plays everything ok but can not access the cd or move the plate regadless button pushing.
Have you tried the reset button? Hold it for 3 seconds ( ball point pen to press the button above power button) U will lose the presets but Oh weel.
I am going to remove power completey from the unit later on today, and if it still has issues I am returning it for a replacement ( Bought it form Best Buy)
L8R
Posted on Nov 09, 2008
welcomejee
  • 10594 Answers
SOURCE: Wiring Diagram For Sony Disc Player
Download required wiring diagram or user manual from Sony Support.
Posted on Jan 02, 2009
  • 27 Answers
SOURCE: Sony CDX-S2210 CD Player stuck on demo mode
make sure the unit is switched off and the clock is displayed then
1 Press and hold (SEL).
The setup display appears.
2 Press (SEL) repeatedly until the
desired item appears.
3 Press the volume +/– button to select
the setting (example “ON” or “OFF”).
4 Press and hold
(SEL).
The setup is complete and the display returns
to normal play/reception mode.
Note
Displayed items will differ, depending on the source
and setting.
With the card remote commander
In step 3, to select the setting, press
< or ,.
The following items can be set (follow the page
reference for details):
“z” indicates the default settings.
*1 When the unit is turned off.
*2 When the audio output is set to “SUB.”
CLOCK-ADJ
(Clock Adjust)
(page 4)
BEEP To set “BEEP-ON” (z) or
“BEEP-OFF.”
SUB/REAR*1 To switch the audio output.
– “SUB” (z): to output to a
subwoofer.
– “REAR”: to output to a
power amplifier.
DIM (Dimmer) To change the brightness of the
display.
– “DIM-ON”: to dim the
display.
– “DIM-OFF” (z): to
deactivate the dimmer.
DEMO*1
(Demonstration)
To set “DEMO-ON” (z) or
“DEMO-OFF” (page 4).
A.SCRL
(Auto Scroll)
To scroll long displayed items
automatically when the group/
track is changed.
– “A.SCRL-ON”: to scroll.
– “A.SCRL-OFF” (z): to not
scroll.
LPF*2 (Low
Pass Filter)
To select the cut-off frequency
“78HZ,” “125HZ” or “OFF
Posted on Jan 29, 2010
Hi i have a sony cdx-s2210s car radio and i need to know the unlock code thankyou :)
There is no unlock code. What is the problem with the radio??????
Sep 21, 2011 | Sony CDX-S2210 CD Player
Sony CDX-S2210 buttons are jammed
Hi Sameersach,
Have you found a solution for your problem? I have the same player and I got the same problem...please, let me know if you found a solution. Thanks!
Apr 17, 2010 | Sony CDX-S2210 CD Player
Ampers for Sony CDX-S2210S CD
If the in-line fuse from the car installation is still attached, check the fuse rating; it will state a figure that is in excess of the demand of the stereo. In other words, if the fuse has 10A on it, it was chosen to fail at currents higher than that. If this unit is only a CD player (no amplifier built-in), it will not likely draw in excess of 2 amperes and probably not over 1 ampere.
If you have no documentation, you can download what you need here:
Sony manuals for your unit
Nov 15, 2009 | Sony CDX-S2210 CD Player
I want to get the user manual for sony atrac cd player
Here is the installation and user manual for Sony CDX-S2210.
http://www.docs.sony.com/release/CDXS2210install.pdf
http://www.docs.sony.com/release/CDXS2210.pdf
Hope this helps.
Thankyou,
Mohsin Idrees Khan.
Apr 08, 2009 | Sony CDX-S2210 CD Player
how do i install a cdx-s2210 to my 92 camry..what wires do i connect?
Jan 02, 2009 | Sony CDX-S2210 CD Player
Manual tuneing on the Sony S2210
you need to press and hold the seek button the it should beep (or not) then you should be able to serch through manualy,just don't hit the button to fast as it will turn the auto search back on?
hope this helps?
Nov 28, 2007 | Sony CDX-S2210 CD Player
Sony CDX-S2210 CD Player Logo
453 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
