Question about Dishwashers
Dishlex global 300 : dishwasher dispenser won't
  • Dishwashers Master
  • 713 Answers
Hi just read your posting.The problem could be a faulty dispenser coil ,or the wires to it are faulty or the computer is faulty.Try selecting a normal eco wash and when you push the start button to start the machine hold the button in until the pre wash light turns off.This should make the dispenser activate straight after it fills.The only way to test which part is faulty is with an electrical meter.Have you or can you borrow one.If so then I can guide you step by step in finding the fault.please reply with additional information and I am sure I can help you further.Looking forward to your reply.
Posted on May 22, 2011
  • dandppiper May 22, 2011
    Just selected normal eco wash and held start button as suggested. Same problem, the dispenser didn't open. What's an electrical meter?
  • luisa_sgro May 22, 2011
    Hi just read your posting.An electrical test meter tests for power, resistance etc.The reason for the test meter is to find out if the dispenser is getting power from the computer board.Unfortunately this is the only way to accurately and safely test your machine for the fault.Please reply on how you would like to proceed and I will help you as much as I can.Looking forward to your reply.
Dishlex global300 is gone into flood mode how do I fix it
Dishlex Global 300 Dishwasher issues - Kitchen - Home - Whirlpool ...
forums.whirlpool.net.au > Home > Kitchen
WhirlpoolAug 31, 2011 - As stated in the title, it is Dishlex Global 300 model and it was here when ... is flooding about to happen inside the DW and prevents flooding). Bosch or Asko dishwasher
Mar 7, 2014
Dishwasher that actually WORKS PROPERLY?
Dec 3, 2012
Dishlex Global 300 dishwasher woes
Aug 8, 2005
Dishwashers ...
Mar 28, 2004
More results from forums.whirlpool.net.au
Nov 25, 2015 | Dishwashers
Dishlex Global 200 won't fill with water
Shut off the water to the dishwasher. Take the line off where it connect to the dishwasher. Get out a bucket (dishpan, etc.) and put the open line into the bucket, turn on the water. Does it have a good stream? If not the problem is in the supply coming from your house. If the stream is good, house water is fine. Connect the supply back up, find the electrical solenoid that the water feed goes to and disconnect the line on the other side of it. Try turning the dishwasher on with bucket catching water, when the solenoid clicks on is there a good stream of water? If not either solenoid is bad, or maybe there is a filter (screen) before the solenoid that needs cleaned. If there is a good stream after the solenoid, then the controls must be bad telling it to shut off too early.
Dec 25, 2011 | Dishwashers
The detergent dispenser on my dishlex global 300 dishwasher not opening during the cycle. How do I fix this?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Sep 09, 2010 | Dishwashers
Dishlex global 300.... The normal light starts flashing mid wash
i think it means the water heater in the dishwasher is not working,or the element is shot.
my 300 had a burning smell before the light started flashing.
Feb 07, 2010 | Electrolux Dishwashers
Dishlex Global 300. Eco light flashing and nothing happens.
could be the water inlet valve or solenoid
Jan 25, 2010 | Dishwashers
Dishlex Global Unable to remove heater element retaining screw
I have a simialar problem with the Dishlex 450 Global model, after searching for the heating element on line, I found a picture of the element (450 model), showing that the Stainless Steel screw is actually spot welded to the element bracket, hence you should be able to remove it by accessing a retaining nut from underneath the dishwasher....(turn power off first!)..
May 24, 2009 | Electrolux 18 in. ESL4114 Slim-Line...
Thomo, make sure the sprayer holes in the spray arms are clean. Grains of rice seem to be a dishwashers biggest enemy as they don't desolve and eventually end up lodged in the spray holes. The holes at the end of the spray arms are the ones responsible for the washing out of the soap powder from the dispenser, if they are blocked this does not happen.
Hope this helps
Cheers
May 29, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Dishwashers Logo
477 people viewed this question
Top Dishwashers Experts
