Question about NorStar Meridian 8314 Corded Phone
Nortel 8314 will not allow me to delete stored numbers or memory keys using the prescribed methodin the manual (pressing # key twice). Any ideason on what could be wrong or any other method to do this?
2 Suggested Answers
ynotphone
  • 192 Answers
SOURCE: Ris, Hold and Feature Buttons
Have you tried unplugging the set?
Try unplugging the set wait for about 15 seconds then plug the set back in... i he set will flash for a while, stop, and flash for awhile... just be patient and it will return.
Then test to see if the Feature, Rls and hold buttons work again.
PS those buttons are hard coded, and cannot be erased, they may fail, but they will not erase.
Maybe you also have a stuck button, that is affecting the set?
Posted on Jun 02, 2009
Need to program new phone numbers
The manual is available here: www.uniden.com/pdf/CEZ260om.pdf. If you search google for "uniden cez260 corded phone manual" it is the first result.
You can find the instructions in the fourth column of text under "Storing a Name and Number in Memory"
Here is the text from that section, but I can't promise the copied text is accurate. Check the pdf at that address if anything doesn't work.
1. Press STORE. LOCATION? shows in the display.
2. Press the desired memory location (0 to 9 or quick call buttons A, B, or C.) NOTE: Press LEFT or RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C to select a location.
3. Press STORE again to con? rm the memory location. NOTE: Use Delete to erase existing memories or to correct errors.
4. Use the number keys to enter the telephone number (up to 32 digits) and then press STORE to save. (The unit will not dial a phone number in this mode.) The cursor automatically moves to the text line for name entry.
5. Use the number keys to enter the name of the person associated with the telephone number you just entered. More than one letter is stored in each of the number keys. Press the keys multiple times to scroll through the letters for that key. For example, to enter "B," press "2" twice. Press LEFT two times to create a space. NOTE: The ? ashing cursor automatically moves to the next position or you may press LEFT or RIGHT to move the cursor to the next position.
6. Press STORE to save the name.
7. To enter another name and number in a di erent memory location, return to step 1 and repeat this process.
Storing a Pause in Memory
The REDIAL/PAUSE button has dual functionality and becomes a pause button when pressed in sequence after the STORE button. It is valid only when storing a number into memory locations. Use the REDIAL/PAUSE button to insert a pause when a delay is needed in an automatic dialing sequence (for example, when you must dial a 9 to get an outside line or when you enter codes to access your long distance company).
NOTE: A pause is 3 seconds in length and you can store more than one if a longer pause is needed. Changing a Stored Number Repeat the storage sequence under Storing A Name and Number in Memory, and press DELETE to delete the old number before entering the new number.
Erasing a Stored Name & Number
1. Press STORE.
2. Press the memory location (0 to 9 or quick call buttons A, B, or C) to be erased.
3. Press DELETE.
Copying Caller ID Memories to User Memory
1. Press LEFT or RIGHT to view the caller number and name you want to copy.
2. PressSTORE.
3. Press the memory location (0 to 9 or quick call buttons A, B, or C). The number ? ashes if there is a number already stored in that memory location.
4. Press STORE to enter Edit mode, and then pressSTORE again to edit the name. NOTE: Select a di erent memory location by using LEFT and RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C.
5. Press STORE to con? rm and save. Wait three seconds to exit.
NOTE: If the name you want to enter is longer than 12 characters, only the ? rst 12 characters will be copied into memory.
Storing a Redial Number to Memory
1. Press STORE.
2. Press any key (0 to 9 or quick call buttons A, B, or C) for the memory location. If a number is already stored in the memory location, it will appear on the display. Use LEFT and RIGHT to select a di erent location.
3. PressSTORE again to con? rm.
4. Press REDIAL/PAUSE, and then press STORE again.
5. Enter the name, if necessary, and then press STORE to con? rm.
Copying a Redial Number to Memory
1. Press REDIAL/PAUSE while on-hook. Redial number will display along with PICKUP PHONE.
2. Press STORE.
3. Press any key (0 to 9 or quick call buttons A, B, or C) for the memory location. If there is a number already stored in the memory location, it will appear on the display. Use the RIGHT or LEFT buttons to select a di erent location.
4. Press STORE twice.
5. Enter name, if necessary, and then press STORE again to con? rm and save.
Dialing Numbers Stored in Memory
1. Press DIAL.
2. Press a memory location button or use LEFT or RIGHT to scroll through stored memory locations to ? nd the desired number. The number in that memory location displays.
3. Press SPEAKER or pick up the handset to dial the displayed number.
OR
1. Lift the handset or press SPEAKER.
3. Press DIAL again to dial the stored number.
Jun 11, 2015 | Uniden CEZ260 Corded Phone
I hasve a Uniden CEZ260 Corded Phone and i am trying to reprogram the numbers in the speed dial locations how do i do that.
To assign or change youe speed dial. Do the following: 1. Press STORE. LOCATION? shows in the display. 2. Press the desired memory location (0 to 9 or quick call buttons A, B, or C.) NOTE: Press LEFT or RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C to select a location. 3. Press STORE again to confirm the memory location. NOTE: Use Delete to erase existing memories or to correct errors. 4. Use the number keys to enter the telephone number (up to 32 digits) and then press STORE to save. 5. Use the number keys to enter the name of the person associated with the telephone number you just entered. More than one letter is stored in each of the number keys. Press the keys multiple times to scroll through the letters for that key. For example, to enter "B," press "2" twice. Press LEFT two times to create a space. NOTE: The flashing cursor automatically moves to the next position
Apr 18, 2011 | Uniden CEZ260 Corded Phone
How do you program #'s in to the phone
There are 20 memory locations to store numbers in, they are numbered 01 - 20. Press and hold the memory button until Memory Store shows in the display. Dial the 2 digit memory location or use the arrow keys to choose the memory location. Press the select/channel button which will show Store Name in the display if the memory location is empty or will show edit and delete options if the memory location has an entry in it. If the memory location is empty, use the number keys to enter a name for the memory location. Press the select/channel button which will show Store Number in the display. Enter the phone number using the dial pad. Press the select/channel button to save the entry. Press the memory button to end.
Here is a link to download the manual in pdf format.
http://www.uniden.com/pdf/TRU348om_VA.pdf
Jan 23, 2011 | Uniden TRU348 Cordless Phone
Looking for conair cm200wcs manual
To store numbers into the phone's memory:
Lift receiver - you should hear dial tone. Then, press 'STORE', press key M1, M2 or M3.* Enter the number you wish to store. Then, press the 'STORE' key again. Now, press the memory position you chose above, (M1, M2 or M3).** Replace receiver back on cradle.
To use - lift receiver and press the memory key that was optioned, (M1, M2 or M3). If a numeric key, (1-9), was chosen - press the 'MEMORY'' key then the chosen number.
* To store in numeric 1 - 9, just press the 'MEMORY' key for this step.
** When storing in numeric 1-9, Press the 'MEMORY' key and then the number you wish to store in this step.
Tip: For a phone card, use M1 for the 800 number and M2 for the PIN.
Jun 30, 2010 | Conair TAD920 Corded Phone
Need to record phone numbers on speed dial - have lost the owners manuel - 4 line phone
1. Press the STORE button on the handset, ENTER NUMBER is displayed.
2. Use the keypad to enter the phone number (up to 32 digits).
3. Press the SELECT button. The display shows ENTER NAME.
Telephone Operation
17
4. Use the touch-tone pad to enter a name (up to 21 characters). More than one letter is stored in each of the number keys. For example, to enter Bill Smith, press the 2 key twice for the letter B. Press the 4 key 3 times for the letter I. Press the 5 key 3 times for the letter L. Press the 5 key 3 times for the second letter L, and press the 1 key to insert a space between the first and last name. Press the 7 key 4 times for the letter S; press the 6 key once for the letter M; press the 4 key 3 times for the letter I; press the 8 key for the letter T; press the 4 key twice for the letter H.
5. Press the STORE button again to save your selection. ENTER LOCATION is displayed.
6. Enter two digits to enter the location, ranging from 01 to 40. For example, to store the record in location #5, press “0”, “5”. After entering a valid location number, the record will be saved. If the memory location you selected is not empty, OVERWRITE? will show in the display. Press the STORE button again to confirm the current record and overwrite the old one or press the EXIT button to select another location.
7. To enter another name and number in a different memory location, return to step 1 and repeat the process.
Good Luck.
Jan 30, 2010 | RCA 25413RE3 Corded Phone
Program numbers
Storing a Number in Memory
1. Press the STORE button. ENTER TEL. NO. is displayed.
2. Use the keypad to enter the phone number. You can put spaces in the number and it will still dial correctly. To enter a space, press NEXT button.
• To scroll forward or backward, use NEXT (when the cursor is not at the end of the number) or REVIEW.
• To erase the current digit, press DELETE.
3. When finished, press STORE. ENTER NAME is displayed.
4. Use the keypad to store a name (up to 16 characters). More than one letter or character is available in each of the number keys. For example, to enter the letter "A," press the 2 key once. For a "B," press the same key twice. For a "C," press it three times.
• To add a space, press NEXT.
• To scroll forward or backward, use NEXT or REVIEW.
• To erase the current character, press DELETE.
5. When finished, press STORE. MEMORY LOCATION is displayed.
6. Press the memory location number (0-9 or A, B, C) to store the number.
Here is a link for this telephone off the GE website:
http://www.home-electronics.net/ge/pc/IB/29897GE1_IB.pdf
May 11, 2009 | GE 29897GE1 Corded Phone
Need to program numbers in speed dial (or replace lost manual).
If you go to the following webpage there is a link to the manual:
http://www.amazon.com/exec/obidos/ASIN/B00005NGRJ/plaza101-20/ref=nosim/
It is under the 'Product details' section. The section on managing the memory start on page 34.
To change a stored number you just follow the initial instructions, namely:
2. Use the keypad to enter the phone number. If you
want to add spaces instead of dashes in the number,
it will dial correctly.
PREVIOUS.
• To erase the current digit, press ERASE.
displayed.
“A,” press the 2 key once. For a “B,” press the same
key twice. For a “C,” press it three times.
PREVIOUS.
displayed.
store the number.
I hope this helps you.
Jan 03, 2009 | GE 29893GE1 Corded Phone
Loading speed dial numbers on a XS1215
1 press the memory key(phone on standby mode)
2 choose from number 0-9. enter the number of choice. this will be the speed dial number where you can store the entry. scroll through the list and press the select/channel key twice.
3 STORE NAME will appear. when it's flashing, you can enter the name then press select/channel key. (name can be upto 13 char)
4 STORE NUMBER will appear. when it's flashing, you're ready to enter the number. (each number can be upto 20 digits) If you have an account number, you can store it so that if you call a hotline that needs that account number, you can just press the speed dial number key. you can also press the pause key after the number if you want a 2 second delay before it rings. you can put several pauses
5 press the memory key. if the phone is idle for 30 seconds and you did not press the memory key, it will return to standby mode.
6. press the end key
Nov 12, 2008 | Uniden Cordless Phone
Erasing all phone numbers and user information on A650
FROM THE MANUAL
ERASE MEMORY
Erase memory erases your Phonebook and Voice Dial recordings. This feature is useful if you want to give your phone to a friend or family member.
1. In standby mode, press the left soft key (Menu), then press 9 (Setup), 4 (Security). You're prompted to enter the lock code.
2. Enter the lock code (try the last 4 digits of your phone number unless you set a different one), then press 6 for Erase Memory. A confirmation prompt appears in the display.
3. Use the navigation key to highlight Yes or No, then press OK. A confirmation message appears in the display while your messages are being erased. Your phone then returns to the Security menu.
RESET PHONE
Reset Phone returns all setup options to their factory default.
1. In standby mode, press the left soft key (Menu) then press 9 (Setup), 4 (Security). You're prompted to enter your lock code.
2. Enter the lock code, then press 7 for Reset Phone. A prompt appears in the display asking if you wish to restore default settings (except for the Phonebook and Voice Dial).
Feb 05, 2008 | Samsung SCH-a650
Storing #s in memory
Try this. Memory The handset can store up to ten 24-digit numbers with up to 15-character names in memory for quick dialing. This memory feature is in addition to the CID memory log, which stores up to 40 CID records in the handset. Storing a Name and Number in Memory 1. Make sure the phone is OFF (not in TALK mode). 2. Press the mem button. 3. Press the desired memory location (0 through 9) or use Caller ID/vol (+ or to scroll to the desired memory location. NOTE: If the memory location is occupied, the memory location number and its contents show in the display. 4. Press the mem button again. The display shows ENTER NAME. NOTE: If you don?t want to enter the name, skip step 5. 5. Use the touch-tone pad on the handset to enter the name (up to 15 characters) and press the mem button to save. More than one letter is stored in each of the number keys. For example, to enter the name Bill Smith, press the 2 key twice for the letter B. Press the 4 key 3 times for the letter I. Press the 5 key 3 times for the letter L. Wait for one second. Press the 5 key 3 times for the second letter L. Press the 1 key to insert a space between the L and the S. Press the 7 key 4 times for the letter S; press the 6 key once for the letter M; press the 4 key 3 times for the letter I; press the 8 key for the letter T; press the 4 key twice for the letter H. 6. Press the mem button to save the name. The display shows ENTER TEL NUMBR. 7. Use the touch-tone pad to enter the telephone number you want to store (up to 24 digits). 8. Press mem again to store the number. You will hear a confirmation tone. NOTE: If you make a mistake press the del/chan button to backspace and erase the wrong character(s) or number(s). If there are any further questions or comments, please post here. Please rate this solution through fix-ya.com Thank you
Jun 18, 2007 | GE 25836 Cordless Phone
NorStar Meridian 8314 Corded Phone Logo
85 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Jose Ma DM.
Jose Ma DM.
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
