Question about Sony XM-2165GTX Car Audio Amplifier
I have a 1000 watt sony explode mx-2165gtx and i have 2 12inch rockferd subs all hooked up in my truck. i turn on the sterio and turn it up just a little bit and it goes into protect mode i cant figure out whats going wrong i gronded the wire to my seat bolt powerd it to a fuse box under the hood and remotley to just a sterio fuse in the dash panel.. i got the subs to work one minit an the next it just started on its tempermental pertect mode...
    Problem Solver:
  • 7 Answers
Sounds like you're overloading the amp. Which rockford subs are they exactly? I can find the specs and see if theyre just too much for the amp or you just have to hook em up to the amp different so the amp wont go into protect mode
Posted on May 23, 2011
How do i bridge a 1000 watt amp to two 1200 watt subs
a sony 1000 watt rating is an exagerration. you will blow your 1200 watt speakers far before reaching sonys claim of 1000 watts
Jul 10, 2014 | Sony Xplod XM-1652Z Car Audio Amplifier
I have Sony xm-2165gtx amp 165 watt rms x 2 at 4 ohm 200 watt x 2 at 2 ohm 400 watt x 1 bridge output at 4 ohm stereo or bridge mono output 4 ohm stable in bridge mode this mean can't go lower then 4 ohm...
You can't bridge that amp onto a load lower than 4 ohms. So you can't bridge that amp onto two 4 ohm subs. To get the most power out of your subs is easy. Run one channel to one sub and the other channel to the other sub. 165 watts RMS is plenty for most subs.
Dec 05, 2013 | Car Audio & Video
Car audio
If you are asking if you can have a kenwood amp hooked up to your Sony Head unit then yes it would be compatable.
Jun 02, 2010 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
How to hook it up to system with two 10s 400 watts per sub and two 6x9s at 200 watts each?,subs behind seats, 6x9s in doors. IF i need another amp i have one,to help push. But either way i need your help...
Hello www_mitzjohn,
I'd definitely use another amp.
The 2-channel Sony is well suited for powering the 6X9's but a monoblock would be better for the subs. The different types of speakers running from the same channel will not sound very good and likely it'll be impossible to get the impedances to match.
You'll want to set the Sony to send higher frequencies to the 6X9's, but not to the subs. You can't adjust the channels individually. So, just connect each 6X9 to one channel of the Sony and use a monoblock subwoofer amp for the subs.
Hope this helps.
Oct 31, 2009 | Sony XM-2150GSX Car Audio Amplifier
How do I fix the problem so they work again.?
A 1000 WATT AMP HAS PROBABLY GONE INTO PROTECTION MODE BECAUSE YOU ARE TRYING TO RUN 1600 WATT SUBS COMBINED
Jun 08, 2009 | Car Audio & Video
Amp burning speakers.
one of the channels your using may be burned out or there is sum wire touching inside the amp so take the cover off and make sure nuthn is touching and see if sumthn is burnt and also try using a different channel on the sub
Feb 26, 2009 | Sony XM-2165GTX Car Audio Amplifier
Help asap
hook blue wire to ur radio to amp remote
Feb 12, 2009 | Sony Car Audio & Video
High distortion
The head unit may be rated at 200 watts but it cannot produce more than ~20 watts of real power per channel. There's no way that it can drive the high end speakers to a level that will be needed to compete with the subs on a 1000 watt amplifier.
Apr 18, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
1000 watt amp sony xplod
That's not a 1000w amp. It's a 400 watt amp when loaded to it's lowest rated load. If you have one speaker per channel (the only safe load if you have single 4 ohm coil speakers), you're only getting 165 watts/speaker. It's probably distorted because you're driving it to clipping.
Jan 01, 2008 | Car Audio & Video
Sony XM-2165GTX Car Audio Amplifier Logo
144 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
