Black Streaks on all copies and scans - Office Equipment & Supplies
    Sergeant:
  • 167 Answers
Try to replace the toner coz the toner is low
Posted on May 22, 2011
5740 hp officejet printer streaks on scan or copy
The glass is smudged or dirty or the scanner bar may have dirt on it. Cheaper to just replace the machine.
Aug 19, 2016 | HP DeskJet 5740 InkJet Photo Printer
When using the auto feed, copies come out with black streaks down center of page
If you only get streaks when using the automatic document feeder, then in most cases it is dirt on the scanner glass. You do not state model but if you can also scan flat objects, trying copying a piece of paper that way. If that copy comes out fine, then you definitely have dirty glasss, if that copy has streaks you either have dirt on the scanner itself or a faulty scanner unit.
May 08, 2015 | Office Equipment & Supplies
Why when I select color copy on HP Deskjet 3050 J610, it prints with a blue background?
The issue is from the glass on the copier, it would be better if you clean it very well or possible change.
Aug 20, 2014 | HP Deskjet 3050 All-in-One J610A Printer :...
Vertical black line on scans or copies;
Hello James,
Please click Vertical Bands Lines or Streaks in Copies Faxes or Scans to access the troubleshooting steps that should resolve the issue.
Mar 03, 2014 | HP Officejet Pro L7680 All-In-One Printer
Black Streaks on copy
This means that teflon is wearing off of the Fuser Roller. It collects toner and then tracks it back on everu copy. It needs to be changed out by a trained tech.
The other thing that can cause this is a bad drum. Both about $200 I believe.
Cheers
Dec 29, 2009 | Sharp Office Equipment & Supplies
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
Hp Photosmart c5280 1/ 2inch thick black line
There is something on your scanner glass. Clean the glass with glass cleaner. If this happens when using the automatic document feeder, open the top side cover where the paper feeds into. There is a narrow glass strip there. Clean that as well.
If this fails, the scanner head has a bad sector on the CCD and will need to be replaced. You will probably find that it will be cheaper to replace the printer entirely if that is the case.
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
I have a BROTHER MFC- 8860DN that makes black streaks on copies
If this is only happening with copies and not straight prints, it is possible that the problem is with the scanning unit. Use the soft cloth to clean the scanner area to the left side of the machine where pages are scanned when run through the page feeder. A spec of dust or other debris in this area will appear as a streak along the length of the page.
If it occurs on all prints, You may need to replace the drum or clean the fuser unit.
May 29, 2009 | Brother MFC-8860DN All-In-One Laser...
Dirty copies.
Does this streaking problem occur when printing (not copying)? If it does then you are probably looking at a consumable issue. Alot of times black streaking is caused by a defective or spent drum. Is your drum new? There is also a blue piece on the drum unit used to clean the corona wire that cleans the drum. Have you tried moving it back and forth several times?
If the problem only happens when copying and the streaks are as bad as you make them out to be then you problem have a bad CIS unit (scans your originals for faxing or copying)
Inkworks
866-381-0541
Nov 21, 2008 | Brother IntelliFAX 4100 Laser Fax
Black lines when scan and copy documents
It is because coping is not the best way to get a perfect copy on the printer, Try scanning with computer using black and white photo it will come out much better if you are doing a pic. then use color picture.
Feb 17, 2008 | HP Photosmart 2575 All-In-One InkJet...
70 people viewed this question
k24674
jasbo
jasbo
