Can not sign on to the internet. with wireless or local connection
Dear First you check all physical connectivity (wire)
tahn you put right User Name & Right password sign in
Posted on Aug 15, 2008
Samsung DP500A2D computer My computer won't allow me to sign on because it says there are no networks available (there are) I keep signing in and it won't let me sign on because of no internet
I'm going to assume you're using the Microsoft based sign on (Win 8-10) and that you connect to your network via wireless. My guess is that it's lost the wireless password, it's been changed or is having driver issues. You have a couple of options; If you have an open port on your router or switch, you could make a cabled connection. The other is that when you set up the computer, you hopefully created a local account. Login via that.
Dec 28, 2017 | Samsung Computers & Internet
Compaq presario F500. Wireless internet connection not working. Internet works when plugged into modem. D-Link wireless modem working perfectly. Constant red/orange light on next to wireless switch at...
Hi, Thanks for using fixya.
When you connect it to wireless make sure you go into control panel / network view your connection right click on local area network connection choose disable then connect to your wireless connection. Right click your wireless icon by your clock choose connect to wireless network or view available local wireless connection.
Feb 15, 2011 | HP Compaq Presario F500 F700 and G6000...
How do i join xbox live i dont know howtoget internet on xbox live can you help?
You need to sign up through your xbox or by calling 1-800-4-My-Xbox. You need your xbox to be connected to the internet either by plugging in the network jack in the back of the console, or buying a wireless network adapter and hooking it up to your local wireless network.
Dec 02, 2009 | Microsoft Xbox 360 Console
Wired nor wireless connections for my ps3 wont work
if you setup your wireless in adhoc mode like useing the pc wirless it wont work because ps3 doesnt see adhoc wireless.
and for the ethernet connection is the pc setup right. you have to enable internet sharing on the accuall interface that has internet..
If local area connection 1 is connected to internet and local area connection 2 is plugged into ps3 then under local area connection 1 settings you have to set share this connection and in the drop down menu select local area connection 2. other than that you need to buy a router.
Sep 20, 2009 | Sony Playstation 3 (PS3) Console
M300 toshiba connecting to locally, not connect to internet
Dear Shifsa,
Considering the fact that you are trying to connect to a wifi connection which of course is unsecured,
here are some workarounds..
1. Uninstall the wireless card driver.
Go to device manager > click on the + sign beside network adapters > right click on the wireless adapter and select uninstall. Restart the computer it should get reinstalled automatically.
2. try disabling or uninstalling the antivirus or internet security software. you can later on again download the a free software from
Hope this helps.
Apr 05, 2009 | Toshiba Satellite Pro M300-S1002X Notebook
Unable to connect Acer Aspire 7250 to wireless broadband router (Netgear)
no the empower wireless connection programme is very good but can be turned off if you wish to use Windows Wireless Zero Configuration, which may be better to try and solve the problem, if you right click on the network icon on taskbar do you get the local and internet bubble or the triangle warning sign?
If no warning, click on the connect to a network command and see if the router appears there.
If not click set up aconnection or network at the bottom of the window, then click set up a wireless router or access pont and follow the wizard, or click manually set up if you are the braver type and will have a go
If you get a warning sign i suspect the pc is trying to connect to the wrong type of encryption eg WEP when you have set WPA-PSK or visa versa or a wrongly typed passkey
Sep 03, 2008 | Acer Computers & Internet
Not able to connect to internet
1. try to check the status of the connection:
make sure it is connected and the status does not say either of the ff:
a. local only
b. limited or no connectivity
c. limited access only
2. try to change the network name [ssid] and the network key [wep or wpa passphrase]
you can change this by accessing the ipaddress of the router or its user interface
3.try to reconnect to the new network name
and make sure the status says connected.
this is not a browser issue . it is with the connection set up.
Aug 05, 2008 | Microsoft Broadband Networking MN-500...
Help mi out plzzzz(wireless problem)
what you can see on your network connections? If you can see some icon of internet connection or local network connection you can right click and then point to properties after that you can see the local area connections properties. double click the Internet protocol (TCP/IP) click it and then click obtain automatically ip address. Some wireless network, you can see the network provider which you can see on your network locations. Sometimes you can put specific ip adress of your provider. If not? you can make your own network connection, right click the internet connection and then click properties follow the instruction and go to network connection and sign up your username and password so that you can access through internet connections.
Jun 25, 2008 | HP Pavilion dv6000z Notebook
Wireless connection problem
Internet Setup
Internet Connection Type: Obtain an IP automatically
Host Name: linksys
Domain Name:
MTU: Enable Disabled
Speed & Duplex: 10 Mb Half
Local IP Address:
Subnet Mask:
Local DHCP Server: Enabled
Start IP Address: 192.168.1.
Number of Address: 50
DHCP Address Range: ~ 149
Client Lease Time: 0 (0 means two day)
Static DNS 1:
Static DNS 2:
Static DNS 3:
DDNS: Disabled
NAT: Enabled
Dynamic Routing: Disabled
Wireless: Enabled
Wireless Network Name(SSID): linksys
Wireless Channel: 6 - 2.442 GHZ7
Wireless SSID Broadcast: Enabled
Wireless Security: Disabled
Feb 23, 2008 | Dell Inspiron 1200 Notebook
I cant log in. PLEASE help me.
I guessing you live close to a neighbor that has an unsecured wireless network. It is possible that they changed their security settings to block out other IP addresses (meaning your PS3). The best solution would be to establish your own internet connection and/or wireless network thru a local broadband internet provider.
Jan 27, 2008 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
