I have problem with color setting - Computers & Internet
    Master:
  • 341 Answers
· open Control Panel and select Display menu and open it
· Then select Settings Tab from where you can change resolution and Color quality as 32 bit /64 bit
· ]Or you can click on Advance where you can set DPI
If you want to switch in 256 color
Some games and other software programs require that your monitor be set to 256 colors, or they run better in 256 colors. Many of those programs will switch your monitor to 256 colors automatically when you start the program. For those that don
Posted on May 22, 2011
Print colour pictures from laptop to printer
If your printer can print in color and your printer is set to print in color, then you need to do nothing else, it should print in color. There are only 4 things that could prevent you from printing in color. 1. The printer settings is set to print in shades of grey. 2. The printer itself is set to print in black and white only. 3. There is no more ik in your color cartridges. 4. You don't own a color printer.
Sep 30, 2014 | Toshiba Computers & Internet
MY CANNON PRINTER IP3600 IS PRINTING RED IMAGES IN PINK
go to Edit > Color Settings, how is Photoshop Elements currently set? The first thing I would do is try setting it to "No color management" and see if you get better results. If this works for you, you're in luck, because color management gets tricky.In settings "No color management" does not produce acceptable results, you will have to start reading up on color management and color calibrating your devices, particularly your printer. You might want to also read Photoshop Elements Help topic "To print using color management."Most graphics software has setting for color management, but personally, I have always gotten the best results by simply turning color management off. Color management is primarily intended for people in a pre-press environment. Not everyone needs it. If you're not doing professional printing, first try working without color management before you assume you need it.
Apr 26, 2012 | Canon Pixma iP3600 InkJet Photo Printer
My philips dvp3560 will only playback in black and white
Check the TV System menu:
[TV System]
Change this setting if the video does not appear
correctly. By default, this setting matches the most
common setting for TVs in your country.
• [PAL] - For a PAL-system TV. (European TVs)
• [Multi] - For TV that is compatible with both
PAL and NTSC.
• [NTSC] - For an NTSC-system TV. (American TVs)
Also try:
[Picture Setting]
Select a predefined set of picture color settings or
customize the personal setting.
• [Standard] - Original color setting.
• [Bright] - Vibrant color setting.
• [Soft] - Warm color setting.
• [Personal] - Customize the color setting. Set
the level of brightness, contrast, tint and color
saturation, then press OK
Mar 05, 2011 | Philips DVP3560 DVD Player
Need to set the color to 6500K
No, the manufacturer is the one to contact on what resolution is best for your project.
Most monitor are already set for best resolution for photos and movie view and also media editing so you should be OK
if your monitor is a recent model at 16500X780 or it says that is 1080p or 1080 i then you should have no issue with the color setting.
You can go to the control panel and set the display settings for hue, color , contrast and brightness if your Monitor has a graphical user interface for it. Check your user manual for color adjustment for your monitor and also the video card that is install in the PC.
The "control panel will have the display setting for "true, and High color resolution.
Jul 18, 2010 | Hannspree 19" Widescreen LCD Flat Panel...
Hp printer 7450 won't print colored text from a word document. test page shows colors on the windows logo flag. changed the ink cartridge....color one that is....no help i will try to print something else...
It may be set for grayscale (black and white) in the print properties. Go into the print properties in Word and look for a color or black and white setting, either under Color Management or Advanced. Set it for color, and then print your color document.
Jun 19, 2010 | HP Photosmart 7450 InkJet Printer
Vo370M no color on dvd color on tv godd but only
Please change the display settings on DVD, the settings is not NTSC only set PAL then color Display will apear
Jan 28, 2010 | Televison & Video
RCA TV lost Color
It sounds like your grandson found the "monochrome" setting in the menu on your remote. It may be in the "picture settings", "set-up" or "advanced" setting.
Sep 10, 2009 | RCA 32F531T 32" TV
Copies and prints in color are black procesed, but in black are ok
Using CMY Color produces a Processed Black.
Using only K will produce a Black.
In the print driver on a PC change your default setting to Black, from the machine you can set it to use only black as well.
That Patch is on the transfer belt. which it will alwyas do, that is what color machines do.
Install the print driver twice and set one driver s Color Mode to color and one to greyscale. This setting can be accessed by right clicking on the print driver and selecting Printing Preferences, click on the Color tab and set the Color Mode appropriately.
Oct 23, 2008 | Sharp AR-BC260 Color Copier
Color setting
MOST likely, use remote [maybe set] for <menu[setup]> <video>. This is normally where <brightness><contrast><color> and so forth live.
Jul 27, 2008 | Philips Magnavox 20MT133S 20" TV
Samsung DLP HL-R5667W
Your set has a defective color wheel. This is the noise you hear and why the set wont even come on now. The colors were bleeding because the color wheel was getting stuck and when you hit the set you unstuck it. You need to call a tech to put in a color wheel the part is about 100 dollars plus labor.
Feb 05, 2008 | Televison & Video
Open Questions:
6 Ways Cloud Computing Helps Businesses Save Time and Money You must be using cloud computing now even if you do not realize it. For doing a simple task like sending an email, uploading a video online, downloading work related files it is nothing but cloud computing that is making it all possible behind the arena. Cloud computing is a big switch from the orthodox way businesses think about IT resources. Many Online Cloud Backup services advertise a lot of features, such as fast upload and download and unlimited backup, but often in real life usage these commitments fall short. As the old saying goes you get what you pay for stands true. For extremely basic file storage or sharing, you may look for a low cost, simpler product. However, if you are looking to get the best for your business, you'll need to consider better solutions like DataAlign. We all have masses of unstructured data scattered across laptops, desktops, and mobile devices and this is an ever-growing pain not only for a business but also for a home user. With time scarcity and insufficient security measures to protect these valuable data assets, we decided to create a competent Online Computer Data Backup Solutions that can not only assist you to organise your data, but secure it with military-grade encryption. Unlike other business online backup services that does not give optimum functionality, DataAlign provide application and operating system backup, 24-hour support, advanced file versioning, compliance-level security, server and NAS backup and infrastructure-as-a-service IaaS features. Of course, these offerings are simple to use and self-explanatory. With our ever growing and latest technology, Data Align Online Business Server Data Backup Solutions makes data backup, disaster recovery and business continuity uncomplicated and less extravagant as the is mirrored at multiple redundant sites on our network. DataAlign has been designed with you in mind. You wouldn't require any technical skill or IT degree to use it. Simply, upload your data and the technology will do the rest, enabling you to focus on what really matters; your business. Our dedicated support is readily available to answer any questions that you may have.
Jul 23, 2018 | Best Computers & Internet
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
