Question about Nokia E90 Smartphone
Conection error and call drop, changed my sim card, are hinges related to network conection
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 145 Answers
Fthis solution helpful/useful for you please rate the solution. THANKS FOR USINGFIXYA. Wait for the device to start up completely
Posted on May 22, 2011
Bagaimana cara download RSA DATA SECURITY NOKIA E51
Posted on May 02, 2013
Im getting sim card registration failed error in nokia e63
Hi, issues like this are related to your Sim card (network),
not your Cell Phone . In most cases, regarding Sim card problem is from the Service Operator. Have you tried the Sim card on another phone? If not,
remove the Sim card, insert it on another phone.
or you can do it in vise- versa by inserting another Sim card on your mobile.
If you can't receive text messages even when it's inserted on another handset,
then you will need to call the customer care of your Network Operator and tell
them your problem, they will help you fix it immediately.
If the same Sim card doesn't not work on another handset,
don't bother to change the settings or to make any changes with it,
first call the customer care and verify from them, you may make mistakes instead of fixing it.
Hope that helps.
Thanks for using fixya.......
Jan 24, 2011 | Nokia E63 Cell Phone
Tip
PUK Code problem - Sim Card
A PUK code (which is commonly called as PIN Unlock Code) is required if a GSM SIM card was locked after entering the wrong PIN code three times in a row. Entering a wrong PUK code ten times in a row disables the SIM card permanently. Both the PIN and the PUK codes are supplied by the operator, but only the PIN code can be changed by the user.
This problem is very common and most users think that it's related to phone or it's phone code problem, which is not true, it's only with your sim card and is for security reason related to sim card security. That particular sim card will never work on other handsets. We can't use software or hardware or other tricks or methods to unlock it, the only solution is from the Service Operator/Network Operator. Well, some service providers like Airtel has sms facilities to get the PUK code by sending a unique text message, but most providers don't have that facility.
If you keep entering random codes/unknown numbers several times (maximum ten times), your sim card will be rejected or blocked and will be unusable permanently.
Your only solution is to call the Service Provider (Network operator's customer care), ask them to give you your puk code, they'll promptly give it to you after few queries to make sure you are the right/true owner of the Sim Card. (there's no fee or charge as well, and if you call from the same network's sim card number to the customer care, you'll not spend/pay a penny, and of course few service providers may charge). You'll be given instructions on how to enter and change the PIN2 code by the Customer Care representative/s.
There's no other alternative, or no other options that you can get the code from, so don't play around, instead make a call to the customer care of the sim card network operator and get the code.
I wish you good luck.
on Jan 13, 2011 | Cell Phones
Tip
There is another Solution to get out sim card error / Invalid sim card from...
How to correct sim card error / insert sim card
Procedure to follow
Step 1: Check the sim tray or sim seater to see if it it broken, if it is, replace it
Step 2: If the sim seater/tray is not broken, clean the entire terminal.
Step 3: If the sim seater/tray is not directly on the board, trace the broken led and solder it, or you replace the broken led with another sim tray.
Step 4: If it is still not working, change the battery and put a new battery, because a virus infected battery will always give such problem.
Step 5: Finally, if the problem still persist, then check the sim card and replace with another sim card if the former is bad because a bad sim card will always display such message as insert sim card or sim card error.
on Dec 09, 2010 | Cell Phones
My text messages wont send, keeps saying system error
I suspect it's related to your sim card (network), not your samsung cell phone. In most cases, regarding text messages, the problem is from the Service Operator. Have you tried the sim card on another phone? If not, remove the sim card, insert it on another phone and try sending a message from another mobile to you number, or you can do it in vise versa by inserting another sim card on your mobile.
If you can't receive text messages even it's inserted on another handset, then you need to call the customer care of your Network Operator and tell them your problem, they will help you fix it immediately.
You can check the message center number, but I don't think it's very much important in your case, well, if you wanna try, just check the text message settings and verify that the message center number (which is currently in use) is the same number which is on another phone with the same network (the other sim should be of the same network in your area). If it's different, make the changes and save the settings. Also disable the "Receive Via" or similar settings.. (I can't recollect the exact settings as i don't have the same model with me, please excuse me for this.).
If the same sim card doesn't receive text messages using another handset, don't bother to change the settings or to make any changes with it, first call the customer care and verify from them, you may make mistakes instead of fixing it.
Also itmight be caused by VIRUS,
You will need to format to restore back phone.
Take care.
Sep 14, 2010 | Cell Phones
Need unlock code for sony ericsson z550a for a tmobile SIM
Hi, If you get error message as PIN blocked. Unlock?" You have entered the wrong PIN code too many times. You need to unlock your phone using the PUK (PIN Unlocking Key) code. Your PUK code is provided by your network operator. If you get error message as Insert correct SIM" You have inserted a SIM card that is not supported. Insert correct SIM card, or contact your Service Provider for a SIM unlock code. If you get error message as Phone locked" or "Enter PIN" Your phone is locked and you need to unlock it with your personal PIN. The default PIN is '0000', but you or your network operator may have changed it. I Hope it helped you. Thank you for using ' Fixya ' and have a nice day!!
Nov 18, 2009 | Sony Ericsson Z550A Cellular Phone
Tip
Phone displays "SIM card rejected" or "SIM card unaccepted".
The SIM (subscriber identity module) card is a small card inside your phone that establishes a network connection. The SIM card is provided by your operator or service provider. In most cases, they are the best source of assistance with SIM card problems. Your phone may display a SIM card error message if:
  • The SIM card is out of alignment. If the phone has recently been dropped, bumped, or opened, the SIM card may need adjusting. Follow the SIM card installation instructions in your user guide.
  • The PUK (Personal Unblocking Key) code is entered incorrectly multiple times. This can inactivate the SIM card. If inactivation appears to be permanent, contact your operator or service provider for a new SIM card.
  • You have recently changed service providers. In this case, either your SIM card or your phone may be configured for your previous operator and may require reconfiguring. It may also be that your phone is configured so that it cannot be used with a SIM card from a different operator or service provider. Please contact your current operator or service provider for assistance.
If none of the situations above apply and you continue to receive this error message, your SIM card may be damaged. Please contact your operator or service provider to have the SIM card tested and/or replaced. Or alternately, bring your phone to the nearest Nokia Care point for inspection
on Sep 12, 2010 | Cell Phones
Tip
SIM card Rejected ? orvSIM Card unaccepted?
The SIM card is the small card inside your phone that establishes the network connection. In almost all cases, your operator or service provider is the best source of assistance with SIM card problems.
  • You have recently changed service providers. In this case, either your SIM card or your phone may be configured for your previous operator and may require reconfiguring. Please contact your current operator or service provider for assistance.
on Mar 14, 2010 | Cell Phones
Insert sim card problem in Nokia 6030
nokia6030 mobil is not conecting the network its showing insert sim card
Aug 24, 2009 | Nokia 6030 Cellular Phone
I added money to my sim card but when i try to make a call it says service unavailable
just change ur sim to some other (ur friends\ relation) mobile and check it, same probs happened, confirm ur network people and change ur sim card.
Apr 20, 2008 | Lands Phones
Nokia E90 Smartphone Logo
93 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
