Question about Fuji FinePix F810 Digital Camera
Fuji finepix f810 flash wont pop up when button pressed
    Sergeant:
    Champion:
  • 214 Answers
Hi your camera is kind of getting old but it is still great. some people really like it. personally I like also. however, fuji finepix f810 has little problem like yours due to delicate design. on your flash problem could has two sequence check. first is flash circuit defective or flash tube defective. second is main pcb doesn't work properly with flash function. your local repair shop would charge around $75 to 185. Fuji camera usually charge more than other brand. I am sorry that you know. Good luck with you and best regard.
Posted on May 22, 2011
Testimonial: "thats what i have learned from another sorse"
How do I fix the pop up flash on my fuji finepix s700
fix the pop up flash,,,,select manual M operation,flash donot pop up.
Apr 03, 2010 | Fuji FinePix S700 Digital Camera
My fuji finepix releases the flash when the shutter button is pressed but the flash does not pop up into place
Mine did the same thing. The problem in mine after extensive disassembly was the plastic had broken inside the flash where the pop up spring attaches.
This was a pretty extensive repair with full disassembly in my case, not for most people.
A workaround is to take a small rubber band, loop it over the top of the camera from the eyepiece for the viewfinder to the lobe in front of the flash. When you need flash, release the flasy and unhook the elastic fromt he front lobe and let it go under the raised flash unit and it will keep it up. If you case lets you, you can leave it that way. Not pretty but functional.
Jan 04, 2010 | Fuji FinePix S700 Digital Camera
A camera with a club
Low light level indicator.
Press the button on the left side of the flash that says "open" to pop the flash up.
Nov 13, 2009 | Fuji FinePix S1000FD Digital Camera
Flash not popping up
This model does not have a manual flash pop up release, so if the flash is not needed, it won't pop up at all. Use the "flash" button on the back of the camera to set: fill, forced, disable, etc. flash settings.
Jul 05, 2009 | Fuji FinePix S700 Digital Camera
Flash isnt working finepix s5700
try to pull it up to get it out and then choose the lightning button to activate flash....
Nov 11, 2008 | Fuji FinePix S5700 Digital Camera
Fuji FinePix F810: flash light does not pop up when button is pressed
Hi guys,
I've had the same problem with my f810. I found the solution on a german photography forum:
while pressing the flashbutton with your thumb on the rearside of your camera, push on the body of the camera under the flash on the frontside with your index. try various positions of your index and you'll see: it will open!
neto
Oct 26, 2008 | Fuji Cameras
I have a fuji f810.the pop up flash will not pop up.
The problem is the top RH edge of the Flash Assembly becoming stuck under the edge of the top side of the camera case in which it sits. Solution gently prize the flash housing to the left as viewed from the top of the camera case whilst the camera is in the take mode whilst pressing the flash button. When the flash assembly pops up file the RH edge of the flash assembly cover as viewed from the top with a fine swiss file. Take care not to get any filings in the camera. This will totally restore the flash operation to normal.
Oct 01, 2008 | Cameras
FinePix A350 Power Button stays down after being starting camera
This just plain shouldn't happen. Call Fuji while your warranty is in effect, and have them fix or replace it.
Mar 23, 2008 | Fuji FinePix A350 Digital Camera
Flash - how do you get it?
The button to 'pop up' the flash is located just above the LCD display
Feb 06, 2008 | Fuji FinePix E510 Digital Camera
Fuji FinePix F810 Digital Camera Logo
176 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
