Question about CTX Value VL 510 15" CRT Monitor
I have a CTX VL 510 monitor, it is not switch on and produce a relay operating tic tic sound....it just happened when i was working....
    Sergeant:
  • 167 Answers
Pls bring it to the near electronics center for check up before any worst happen
Posted on May 22, 2011
Set up pv505 monitor to computor do i use both power dc in and display in put ports
Yes you do, connect the mains power to the monitor and the video cable from the monitor to the video port on the computer.
Sep 02, 2010 | CTX Value VL 510 15" CRT Monitor
Tic tic sound with L.E.D blinking
it can be a broken monitor or a faulty video card. try replacing your video card. hope this helps
Jul 03, 2009 | LG Studioworks 700S 17" CRT Monitor
Tic tic tic sound
Check for other problems. You might need to buy another FET as well. But this time don't put the FET back in until you make sure nothing can blow it.
May 15, 2009 | LG L1915S 19" LCD Monitor
Tic tic problems
check filtering capacitor of lot+B & replace it
May 14, 2009 | LG Studioworks 700S 17" CRT Monitor
Acer CRT Monitor with tic tac sound
1. horizontel transistor bad.
2. dry points on neck board.
3. cheak the power supply out put
4. LOT problem
Oct 13, 2008 | Computers & Internet
I have a 2 year old CTX S760A monitor, when I switch on the computer the monitor switches on and off several times about 25-30 times before stabilising. It works well after that. This has been happening...
First, I would try connecting a different monitor if possible. If the problem persists, it would be a problem with your computers video card. If the 2nd monitor works fine, then your monitor is at fault and may need to be replaced.
Apr 06, 2008 | Computers & Internet
CTX lcd monitor model s700b is come on 1 second and shut off
this purely the problem with operating system just reinstall windows... u will get rid of it...
ur monitor is in good condition no need to worry about that...
Jan 29, 2008 | Computers & Internet
CTX PCU monitor
A reputable computer or TV repair shop could probably fix it, but it will continue to be prone to failures due to its age. Also, the cost would likely be 70% (or more) of the cost of a new one.
I would recommend replacing it with a new one....you'd be pleased with a nice 17" LCD monitor...but if you're concerned about price...the CRT models are still a little cheaper.
Jan 14, 2008 | CTX Value VL 510 15" CRT Monitor
Windows multiplied not solved
did you try the mode reset switch on the monitor after going back to 800x600? also try 640x480/16 colors since that is one of the default modes for all vga monitors.
Jun 29, 2006 | CTX Value VL 510 15" CRT Monitor
Windows multiplied
what your son did is change the video resolution on your video card. right click on a blank area of your desktop, this will bring up a popup menu, left click on the word "properties" in the menu. this will bring up your display settings window. click on the "settings" tab. this is where the video resolution and color parameters are set. under screen resolution, there is a slider. move the slider to the left until the resolution is either 800x600 or 1024x768, then click "apply". this will get you back to a screen resolution that most monitors are happy with. if you had a higher resolution setting before, follow the same process to increase the resolution. also there is an option that allows you to test the resolution setting, and if it doesn't work, returns windows to it's previous setting. i recommend you use that option.
Jun 28, 2006 | CTX Value VL 510 15" CRT Monitor
CTX Value VL 510 15" CRT Monitor Logo
109 people viewed this question
Top CTX Computers & Internet Experts
Rommel Balcita
Jerry Greenberg
Jerry Greenberg
Are you a CTX Computer and Internet Expert? Answer questions, earn points and help others
