Question about Maytag Washing Machines
My maytag washing machine model lat9606age is Washing my clothes but has no spin cycle and leaves the Clothes dripping wet. I've had someone here to look at it and charged me $85 to tell me the hub seal or something needs to Be replaced and was going to cost another $450 not shore wether to pay for it to be repaired or just buy a new machine Can you please advise me Thankyou
  • 1 more comment
  • antoninoe May 22, 2011
    no eqater leakage at all
    Thats no water leakage
  • 713 Answers
Hi just read your posting.The only time the hub and seal needs to be replaced is when the machine is leaking.Is your machine leaking on the floor.If you have a leak then the water could be leaking water onto the belt making it slip therefore not spinning.I have done a few of these machines and the job will take about 1 to 2 hours.Can you reply back and let me know if your machine is leaking water.Could be all you need is a new belt.Looking forward to your reply.
Posted on May 22, 2011
  • luisa_sgro May 22, 2011
    hi just read your posting.From the information in your last posting you said there is no water leakage.Is this correct?If it is then why is the service man going to change the hub and seal?I think you should call him and ask if the reason for quoting on a hub and seal kit is because of a leak.Please reply with additional information.Looking forward to your reply.
Clothes too damp after spin cycle
Front loading washers are notorious for not spinning the water out of a small load of clothes. This is because there is not enough clothes in the washer to balance the tub during the spin cycle.
Try washing a slightly larger load with a minimum of six items or more. This is one of the downsides to front load models and no specific brand is immune to the problem.
Mar 17, 2013 | Washing Machines
Clothes are too wet when finished washing. water drips from clothes.The spin cycle seems to be spinning as the clothes are against the outside wall of the tub. we have the extra spin cycle used aslo and it...
Transmission is bad. Buy new washer. Best brands are (Kenmore, Whirlpool, Maytag).
Thanks and Please Rate me! Tips provided by www.HoustonRefrigeratorRepair.com Brian Gillespie (GOFAR Services, LLC)
Aug 26, 2011 | GE WPRE6150HWT
Spins but laundry is still dripping wet
This happens to me sometimes. My washing machine doesn't drain right into the drain, I have a pipe coming out of the back of the machine that I have to hook into the kitchen sink myself to let the water drain out. My washing machine was still full and I realized that it was because my sink was a little blocked and so it was draining too slowly and leaving water in the machine. If there was too much water, it would sometimes help to put the machine on again or put it on a drain cycle. My machine doesn't have a spin cycle so it will just give your clothes an extra spin so I couldn't do that and my clothes would still come out dripping wet. I advise that you give them another spin before you take them out if possible! xxThe fact that the washing machine is spinning but not drying clothes shows that there is some problem with the outlet of water. The water outlet is blocked. You can check for the blockage yourself. Normally threads or other waste accumulate in the water outlet, and if possible you can remove it yourself. Otherwise call your washing machine's customer services center and ask them to send a repair man
May 01, 2011 | Smeg Washing Machines
Clothes still wet after wool cycle
Hi
For all washing machines irrespective of the make... Wollens and acryllic do NOT have a spin cycle as the same will damage the clothes....
In wollen and acryllic mode the machind is NOT supposed to go into a spin cycle and hence you get wet clothes.....
There is Nothing wrong with your machine.
Regards
Berry
Jan 31, 2010 | Washing Machines
Spin doesn't seem to work - clothes are dripping
Sounds like the belt is slipping. I would check that first. You don't say what model, or how old it is.
Jan 07, 2010 | Maytag Washing Machines
Will not do final spin cycle leaving clothes
Your drain pump has something lodged in it. Remove drain motor, open it up and inspect for obstruction. remove it then reassemble.retrywashing cycle.
Nov 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag top loader on final spin cycle leaves the clothes soaked
how much water is in the bottom of the tub and is it louder than normal if so could be small droplets of water leaking from tub seal if not the pump is restricted by something and req replacement
Aug 20, 2009 | Maytag Washing Machines
Spin Cycle Fails on Washer
This solution is 100% correct, change the : wax motor &control board.I'll be happy to guide you through this if you need me to.
Apr 23, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Washing Machines Logo
205 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
