Question about Philips HTS3251B/F7 Theater System
The sound coming from the both the speakers behind are very less. is there any particular setting i need to do to get the proper home theater effect.
    Brigadier General:
  • 8,546 Answers
Yes, read the manual...
Go here and drill down to the model number you have...
http://www.p4c.philips.com/files/h/
The individual alpha directories are very big and slow to load. Be patient.
Posted on May 22, 2011
Bose cinemate speaker system suddenly gets very loud why?
If the unit is around 5-6 years old or less, you have a bad Rotary Encoder. It is an input to the microprocessor IC(a computer within your Bose). If you would like to inquire about repairing your Bose, please visit me at my website, audioserviceclinic.com. You may contact me directly from the site.
Jul 19, 2014 | Bose CineMate GS Series II digital home...
What is the time delay switch for on a sa 5760 receiver
Hi,here is the basic info for your question..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Surround Sound System Settings ---- Correct Time Delay Setting in Multi-channel Audio
A correctly set surround sound system can yield dramatic improvements to your
home theater sound or multi-channel music listening experience. In particular,
a correctly set time delay setting between the different channels is essential
for a realistic and unified surround soundfield.
Luckily, most of today's surround processors make setting the time delays
between the rear and the fronts a matter of a few entries in the setup menu.
Yet having a proper understanding of the principles behind correct time delay
settings is essential for the best results.
In this guide, we explain the principles behind time delay settings in surround
sound and show you how to adjust your surround processor or AV receiver for the
best surround sound field.
Time Delay Setting in Multi-channel Surround Sound Systems
Correct home theater speaker placement and properly balanced sound levels
between the different channels in multi-channel audio, while crucial, are not
enough to sustain a unified soundfield in a surround sound setup. A correctly
set surround sound system requires that sound from all the different speakers
reach the listener at exactly the same instant.
This explains why all fronts, left, right and center channel speakers, should
be set at exactly the same distance from the listening position. At the same
time, in a typical home theater setup, the surround speakers are closer to the
viewer than the fronts.
To compensate for this distance discrepancy, surround sound playback systems
apply a split-second delay to the surround sound channels.
Jun 22, 2011 | Technics Audio Players & Recorders
I have purchase onkyo 5.1 channel home theater but i am not able to hear sound from rear speaker when a and b speaker setting toggled and subwoofer effect also not getting
The 2 front speakers need to be connected to 2 big banana plug/screw connection marked Speakers A and not the last 2 color coded Push in style connectors,I had the same issue and this was the fix.Look at the quick setup guide closely,I did not look at it close enuff also.
May 24, 2011 | Onkyo HT-S3300 Theater System
How to set up a soundbar with a subwoofer. Where to place the subwoofer. Does it need to be behind us? Is it ok if its in a corner? Will it sound as good if it is in front of us next to the tv?
The subwoofer deals with low frequencies, which are not very directional (ie, it's harder to tell where the sound is coming from).  So where you put it isn't critical to the sound, provided that it's not behind curtains or something that will soak up sound.  The bigger speaker you have in your subwoofer; the less important the position is.
Putting it in a corner is something you're going to have to try, but you may even end up with better bass if you do, as a corner can act as a soundbox and emphasise bassy sounds.  Conversely, your subwoofer may not like being in a corner and interference effects from the sound reflections could degrade the sound.  Like I say, try it and see what it sounds like.  It depends upon your subwoofer, what else is in the corner, precise positioning, and how reflective to sound the corner is.  If it sounds terrible, move it a few inches and try again.
You can put it in front of you next to the TV, no problem.  The only downside it it's a big ugly box.  My wife always makes me hide my subwoofers behind something.
Mar 23, 2010 | Sony HT-CT100 Theater System
No surrond sound
TV's are not sources of multichannel audio. The best you'll get is stereo analog. Get the best TV-related audio from the same source the TV gets it - in this case the Cable Box.
Feb 28, 2010 | Audio Players & Recorders
Can I still use my prologic receiver for my LCD TV ?
optical connection in tv is only input optical connection in receiver is only input will not work.need to connect rca jacks to tv's audio out jacks behind tv to any available input in receiver
Jan 04, 2009 | Samsung HTP-1200 System
Panasonic Home Theater SC-PT760
This is not a problem, this means that your system is working. Polar Express was recorded in Surround Sound with separate tracks for each speaker channel. In most movies you will find that the rear speakers will only play certain sound effects so that it appears they are coming from behind you (gun shot, train, fireworks). Most of the diaglouge will come through the center channel and music/effects through the front left and right, with bass coming from the subwoofer.
Now, you can still hear more from the rear speakers if you like this enveloping effect, or if you like your music coming from all directions. There are Sound Effects options to have the front and back speakers always playing the front track, there is Dolby Pro Logic II that turns stereo sounds (like many TV shows) automatically into 5.1 Surround Sound, and you can also individually change the volume of each speaker.
These are all explained on page 29 of your owner's manual under Sound Options. If you need specific button to button help, let me kow.
Jun 29, 2008 | Audio Players & Recorders
Poor Surround Sound
There is a setting in the dvd player to up the rear speakers to a + setting you have to dig deeep somewhere in the speaker settings. mine did the same thing till I found it.
Jan 08, 2007 | Panasonic SC-HT940 System
Philips HTS3251B/F7 Theater System Logo
51 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
