Question about Ovens
I have an ILVE oven and the door is not closing properly so heat is escaping from top left and right sides, discolouring the white frame polyurethane. How do I adjust the door so that the bottom comes out a little and the top seals properly?
Hi david23413, it's the ILVE service team here. Please contact our Service Manager, Peter Dale, on 02 8569 4672 to discuss your issue further.
Posted on May 23, 2011
GE wall oven JKP07god2bg oven door does not seal properly. heat escapes from the right hand side of door
see if the door is warped . perhaps you can twist it a little the other way .
Feb 27, 2017 | GE Ovens
Kebs208dss11 model double oven. When upper oven is on with door closed, steam can be seen escaping from top of door. Door is closed all the way. Even when putting pressure on door to make sure it is...
The first thing I'd suspect is a poorly fitting door seal / gasket. This will permit the heat inside the oven to escape. Check to be sure the the one installed is defective (cut, split, frayed, dislodged, etc.) Replacement parts:
http://www.appliancepartspros.com/whirlpool-gasket-door-w10074200-ap3892420.html
Make sure this is the part you need before ordering.
Feb 25, 2014 | KitchenAid Ovens
The door on my la germina oven will not close properly
Sorry, I sent this by accident. Anyway, you can adjust the door to close a bit closer to the frame.
Feb 25, 2013 | Ovens
We have a Jenn Air Wall over that the door will not close air tight. They have replaced the hinges but you can actually stick a thumb between the top part of the oven and the door. They say it's supposed...
there's a door gasket that seals it not the metal part of the door so you might be able to stick your thumb in there as long as the seal on the door is closing tightly to the frame,when you open the door it should be on a 90 degree angle,before you had new hinges put on the door, most likely the door sagged lower to the floor and didn't close properly,if you think alot of heat is escaping you could have a bad door gasket.so open the door,look at it from the side,it should look like an L or at a 90 degree angle or even up a little,if it is the hinges aren't the problem if you think to much heat is escaping,call whoever did the work for you and have them check the door seal or gasket same thing.you didn't send the model number so i don't know what seal you need,go here and watch video should be similar and you can put your model number in to find correct part
http://www.appliancepartspros.com/whirlpool-gasket-oven-door-wpw10162384-ap6016005.html
hope this helps you out,if heat is coming out with door closed and you have new hinges this is most likely what's wrong
Jan 07, 2018 | Jenn-Air Ovens
Eog 6330 oven door does not fully close ie small gap at top unless you hold door closed are hinges damaged or bent?
you will have to replace both left & right hinges / this should correct problem .. mm
Jul 12, 2010 | Electrolux Ovens
Oven door not closing properly
If it is a drop down door with hinges on the bootom of the oven door, then it is likely to be weak door hinge springs, the usual solution is to replace both hinges.
If it is a swing open door, then the problem is related to a worn or broken door catch, or worn striker pin.
Apr 13, 2010 | Ovens
Heat escaping, uneven baking, longer cooking times
Either the seals need to be replaced, or you may have weak oven door hinges, and the door is not closing properly.
Only solution would be to replace both hinges if this is the case.
Please rate my solution.
Thankyou.
Feb 01, 2010 | Neff U1421 Double circotherm Electric Oven
I removed the range door to clean oven. Now I
NOTE: The door removal pins you inserted must still
be in both sides of the door.
1.
Grasp the door on the sides with your fingers on
the front of the door and your thumbs on the
inside surface.
2.
Rest the hinge hanger so that it is flat (at the
bottom of the hinge hanger on the bottom of the
front frame slot).
3.
Position the door with the hinge hanger slots
almost parallel to the front frame.
4.
Push up and in until the hinge hanger slots
become fastened to the range. Lower the door
and rotate it slightly from the front to the back
until the slots are fully fastened. The hinge
hanger will be close to the bottom of the front
frame slot.
5.
Pull door open about halfway and remove the
door removal pins. Save door removal pins for
future use.
6.
Close the door.
Dec 25, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Beko SC152 oven door will not close properly, couple of mm gap at the top and heat is escaping, please help regards adele
your door hinges are probably worn,theyre under spring tension.
go to your local appliance repair shop with the model number and they can order you some,or arrange to do them.
hope this helps.
Mar 23, 2009 | Ovens
Oven locked so I can't shut door/operate oven
Thanks a million, solved the problem like a charm. For those that can't find it, it is on the left side orf the OVEN, not the stove. Once you open the door, you'll find it on the frame's upper left side corner, can't miss it. Good luck
Oct 27, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
1,205 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
