Question about Canon Office Equipment & Supplies
Paper want go thur feeder it goes half way and stops
    Sergeant:
  • 167 Answers
Some paper is still in their or clog inside, try to remove it first gently and slowly
Posted on May 22, 2011
How do i change the drun cleaner blade
How do you know its the blade, does this happen when you print? or when you copy?? if copy is happening when going thur the document feeder ?? if so place the original on the big glass then make copy if it goes away the its on the small slit glass to the left or right of the big glass
Feb 25, 2015 | Sharp MX-2300N Color Copier
Why is my photocopier only printing half a page?
Sounds like one of the sensors in the doc feeder that detects the size of the paper has gone bad.
Also, make sure you always close the document feeder when making copies. Sometimes it helps to put a blank sheet of paper over the back of a small object if you're copying something small.
Copier Collin Houston TX Copier and Imaging Expert
Aug 18, 2014 | Sharp Office Equipment & Supplies
Printer paper pulled half through then stops
Leading cause of paper jams or misfeeds is debris or foreign objects that fell accidentally in the paper feed area. Try to remove the sheets of paper from the feeder. Grab a flashlight and look into the feeder for any obstructions.
Also, try to open the printer cover and make sure the paper path is free from foreign objects or debris.
Re-insert your cartridges and make sure they are properly seated in the carrier.
Dec 23, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
I have a minolta copier (Di1610fp). The feeder does not work. When a paper goes through half, it stops
Try cleaning the media rollers with 409 solution. The media feed rollers become dirty after a certain amount of prints. The toner is a wax based toner so excess wax gets on them after a while. Dirty media feed rollers can also cause image shifting problems. I hope this helps you.
Apr 15, 2011 | Konica Minolta Minolta DI1610P Printer,...
Minolta DiAlta model 151f, when i try to use the automatic paper feed on the top of the machine the paper goes in about half way then stops then a message comes caution original doc jam
Try cleaning the pickup wheels that pull the paper into the feeder. There might be an electrical sensor problem also that is not sensing the right paper size. So lets start with cleaning the feeder
Jan 04, 2010 | Minolta Office Equipment & Supplies
Konica 7025 paper jam
Does this happen when he orginals go thur the document feeder? How does the copy look if the orginal is placed on the glass. Vertical feed problem mite be dirty rollers or dirty clutch,
Aug 13, 2009 | Konica Minolta Office Equipment & Supplies
Document Feeder Jams
This could be a simple problem of the fees rollers just being dirty or an obstruction in the path of the paper.. sometimes paper clip or staple gets pulled through you can test by putting a heavy paper or piece of card in dock feeder and see if this goes through if you lift up the cover try to see how far the paper goes in yu might catch the obstruction you can also clean the rollers with a little glass cleaner and a soft cloth.. goood luck A
Jun 09, 2009 | Canon imageRUNNER 400S Copier
Paper returns only half way then stops
remove the paper from the feeder unplug the power and plug it nback in it should go into initialization
Apr 25, 2009 | HP DeskJet 5740 InkJet Photo Printer
Problem with sending faxes
change a paper size in the fax setup
Feb 04, 2008 | Office Equipment & Supplies
Paper problems
I had same problem. first turn of the printer and unplug electrical supply. turn the printer upside down and make sure there is nothing stuck in paper feeder. the next step, take a paper sort of a greetings card and try to run it through the feeder gently. if you cant get it through then don't force it. but this will clear up any object stuck in to paper feeder. now plug in yor power cord and try a test page from your printers properties. hope this will work for you. good luck...........
Aug 16, 2006 | Dell 810 All-In-One InkJet Printer
20 people viewed this question
old marine
old marine
