Question about Champion International Garden
Battery for 580c 1977 backhoe case..it had a marine battery m70..should i get the same.....thx
2 Suggested Answers
  • 202 Answers
SOURCE: Case 580C Backhoe starting problems
either you have a short in the wiring, a loose connection somewhere or a bad starter, check for broken wires first and clean connections. then try the starter see if it turns with a direct connection to another battery
Posted on Jul 14, 2009
1977 580c you have to rev up motor to steer and then its still hard to turn
does it have power steering? check the fluid level.
Jul 06, 2017 | Cars & Trucks
I have installed a new starter on my 580C backhoe When I turn the starter switch it will not engage wheel and just akes a whirring sound Have taken it out and reinstalled it but get the same results
I can talk to you in automotive terms, I know nothing about a backhoe.
I can usually lay the starter motor on the ground, hook up jumper cables properly from starter to battery, at the least, it should kick out the starter drive gear and spin. If it doesn't kick out the drive gear, starter is faulty. I don't know if starter solenoid sits on top of starter motor? I replace as an assembly. Did you check flywheel teeth? I've never worked on a backhoe.
Feb 25, 2017 | Cars & Trucks
Where do I check the brake fluid on a 580C?
I am going to have to guess you are referring to a 580 C Case backhoe.
In any case never ever put anything in a brake fluid reservoir but brake fluid, and the right fluid to be sure, or you will seriously damage or destroy the brakes "forever".
The brake fluid reservoir is usually plastic, and often you can see through it just enough to see the level of brake fluid.
It should be located near the front of the brake pedal, and is usually sort of white in color, with a black cap that can be screwed off.
God bless your efforts.
Aug 04, 2016 | Cars & Trucks
Where is the serial number located on a john deere 510d backhoe..so i can find out the year of the backhoe
Diane, JD 510D VIN# Location: On older models plate is attached on outside of frame behind either left or right front wheel. On newer models VIN plate is attached just above left (Highway) side cylinder arm. Same location as Caterpillar. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://cppsocal.org/wp-content/uploads/2014/04/Heavy_Equipment_Catalog_Vol_5.pdf
https://www.oswca.org/uploads/combatting-heavy-equipment-theft-2015.pdf
Thread where is Serial number for 1977 John Deere 510 hoe
Serial number plate location for john deere 510d backhoe Google Search
Jun 20, 2016 | John Deere Garden
580c case backhoe front bucket is weak and slow goingup
Valves not sealing in the remote control block could be the problem or ram seals.
Mar 12, 2016 | Cars & Trucks
Anyone have auxiliary hydraulics layout particularly where/how its plumbed into control valve
PDF]2013 Skid Steer Loader Parts - Tractorpartsasap.net - All ...
www.tractorpartsasap.net/.../2013_Skid-Steer-Loader_Parts-Catalog.pdf
Auxiliary Heaters . ... Hydraulic Lift Cylinder . .... Service Manual - Tells you how to take the skid steer apart, how to fix it, and how to put it back together ... in the serious repairs or restoration, you need the shop service manual; It can give you many ...Bobcat. 520, 530, 533. 122571. $48.00. Bobcat. 500, 600, 610. 122521.Missing: layout ‎plumbed ‎into
[PDF]PARTS REFERENCE GUIDE - Service Motor Company
servicemotor.com/catalogs/PM-8490.pdf
HITCH PARTS. 125. HYDRAULIC PARTS ... Find the same heavy-duty quality builtinto Case IH batteries for your truck ... lawn and garden tractor, Case IH has the ... Whether it's off-road, lawn and garden, automotive, or marine application, look ...... 12 Gauge. Aux. Lead, 3/8" Eye with B- Splice 12". ZQC708101. 4 Gauge.Missing: layout ‎plumbed ‎1977 ‎clark ‎520
Massey Ferguson Tractors Information - SSB Tractor Forum
www.ssbtractor.com/wwwboard/messages9/
What hydraulic fluid is needed for a Massey Ferguson 390 · MF135 Selling ...... Hydraulics quit working after installing Aux Hydraulic control valve. MF 135 lift
Case Farm Tractor Parts and Manuals - Yesterday's Tractors
Dec 12, 2015 | Garden
How do i fix throttle shaft leak in Roose Master injector pump on my case 580c backhoe?
there will be small seals or "O" rings in the pump shaft cover. Manual details will be on the net but best if you have a case technician repair it as it will be done quickly and properly.
Dec 02, 2014 | Cars & Trucks
Jul 14, 2009 | Champion International Garden
Case 580C model 33 backhoe - transmission problems
Pregunta , tienes, el manual de la case 580 ck, donde se muestra el circuito hidrailico de la transmision, si es asi, embiame una foto del circuito o el manual y te puedo apoyar.
Apr 29, 2009 | Ertl 580 Super M Series II Tractor
Garden Logo
Top Champion International Garden Experts
JohnPaul Robertson
Douglas Wade
Douglas Wade
Level 1 Expert
chuck ringwood
chuck ringwood
Are you a Champion International Garden Expert? Answer questions, earn points and help others
