I have no sounds here on my computer - Computers & Internet
  • Computers & ... Master
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
Posted on May 22, 2011
I have a tv screen that i use to play x box,watch movies and use it for a computer but there is no sound on the computer
That sounds like a computer problem, not an Xbox or screen problem. There may be no sound on the computer because it is aware that you are running the sound to another device like external speakers or the speakers in the TV if there are any. There may be a setting in the software of your computers that allows for sound to come out both the computers speakers and any speaker device the computer is feeding sound to.
Aug 07, 2013 | Televison & Video
My grandad has bought a computer and i tryed to show him how to play a dvd but no sound was playing. I found out there was no sound card? I dont actually know what this means but surely a computer should...
If there is no sound card. Probably it was disabled the sound and maybe there is no really sound card was installed. To make it short buy a PCI sound card, turn off your computer and install the card to PCI slot and turn on your computer and your computer will detect that there is a found new hardware. Ignore it and insert the cd installer and install the driver of your sound card. If it's ask you to restart just restart your computer to update its system. In case that there is a built in sound on your computer check your motherboard model and search for the driver from their official website and download and install, if you download the correct driver it will automatically installed your sound and your sound will be working. Have a nice day!
Jan 07, 2011 | Acer (54.AA806.001) Sound Card
Tin like sound from small speakers only. No sound
switch on your speaker set in full volume unplug it from computer touch the plug , as you touch you can hear a sound ( loud hum sound) if the speaker is working. If okay then check the right jack, plug it into green color jack. you can try if your computer is okay use a headphone plug it into the jack in PC , if the computer is okay you may hear the sound.
Jul 01, 2009 | Dell OPTIPLEX 960S Desktop Computer
My speakers will not play on my computer
Those speakers were originally supplied with Gateway computer system that had sound cards with digital outputs. While some versions had analog and digital sound inputs, most often the speakers had digital input only. The on-board sound in the eMachines is analog output only, so the speakers are most likely not compatible with your computer. If you want to use those speakers, you will need to locate a PCI sound card with digital output.
Mar 08, 2009 | Boston Acoustics BA735 Computer Speakers
No sound on my computer
Hi There,
Do you know the sound card you are using? if so look it up in google with the make and model number for the devices, or respond and ill find them for you.
many thanks
Feb 16, 2009 | Samsung Audio Players & Recorders
Control Panel - System - Device Manager - Sound adapter
instal driver. Go to manufacturers website to find the correct sound driver. You do not need a CD driver, just a sound card driver.
Feb 15, 2009 | AMD SEMPRON 2500 Processor - OEM (AMD2500)
No sound when phone disconnected
Hello!
in sound settings (in control panel) you shold find the computers sound card and set that as default soundcard.
And in the settings (preferences) menu in the software you use to perform calls you just specify your computer phone as sound device.
Feb 04, 2009 | U.S. Robotics USR9600 IP Phone
I bought a computer the was rebuild \. My sound is not working at all. I have been online and keep seeing a sound device or sound card is needed. I'm am not to computer savy and I have no idea what this means. Is the sound card and sound device the same? can I order the and just download so tha tI will have sound? Please help. I just so confused right now. What do I need to do so that I can hear on my computer. Even if it is through headphones?
Feb 12, 2008 | Intel Motherboard
Sound
make sure your sound is connected,the wires to there correct location on computer.make sure monitor connections are correct and secure ,(tight)then reboot computer ,if know sound, then roll back sound drivers in device manager or re install sound drivers and reboot again,see if this correct's your sound problem
Sep 07, 2007 | ViewSonic EA771 Monitor
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
