Question about Frigidaire FSC23F7D Side by Side Refrigerator
Just had a new part # 241734301 installed, because the old one broke during a move. It appears to work fine although the water continues to dribble for a while after filling a glass. Also, the water will come on and pour out through the water dipenser intermittently. Could the hoses have been hooked up incorrectly? Or do you think the new part may have been bad? Thanks for any assistance you can provide in this dilema.
    Sergeant:
    Champion:
  • 257 Answers
It seems as though the water hoses are reversed, Ice maker line and water dispenser line are probably switched, this would explain why the water comes out the door intermittently. It's probably trying to dump water into the ice tray but its coming out the door.
Posted on May 22, 2011
My Senseo Coffee Machine works fine on the one coffee duck. But, when I use the 2 cups duck, nothing - just a few dribbles. Then I can't open the top either - it appears to be suctioned closed.
The 2 pod strainer it clogged. If you hold it up to the light you should be able to see light coming through the other side. Try soaking it in hot water for a half hour and than blow it out the center of the pod strainer with one of the compressed air/ gas duster cans. If this doesnt work than try a needle.
Mar 02, 2015 | Fire Sense Pool & Spa
Dishes on the lower rack are not getting clean. The unit is about 3 years old and was working fine until a week or two ago. When I open during the cycle, it doesn't appear that the lower sprayer has...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Mar 07, 2011 | GE GLD5900NWW / GLD5900NBB / GLD5900NCC...
I have a Rheem Steller natural gas hot water service. There is a continuous dribble of water from the pressure valve overflow, even when the heater is not heating. I have tried easing the valve a few...
Yes, Turn the knob on the gas valve to off. Turn off the incoming water line into the water heater. If you have a valve on the outlet turn it off too. Open the drain at the bottom of the heater to drain a little water from heater. You can then lift the lever on the temperature/pressusre relief valve to let a little air in to release the vacuum and let the tank drain. If the relief is in the side let it drain a bit longer so the water level is below the outlet. Be sure to re-install the down pipe on the relief valve on the new valve. You should drain the a few gallons of water at least once a year from your heater, and you should exercise your temperature relief valve once a year to be sure it will function. If your new valve leaks suspect your temperature control allowing the water to get too hot.
Oct 03, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Model frs23lh5ds9 repairing water valve when solenoid energizes to fill ice maker water is also dispensed at door
Your model has a triple water control valve. That is part number 241734301
That is the possible reason something has cause them to send water to both places. Does your model also have a water filter below or inside the refrigerator? I will need to find a set of better photos/wiring diagrams to understand why this is happening. I will try my best but I will need to go to Frigidaire to look over the refrigerator you have, I just am trying to picture the water lines and I admit this is one strange case.Let me know, Sea Breeze
Nov 20, 2009 | Frigidaire Refrigerators
Hot water stopped working Cold is OK
may be the new facuet see if the hose is clogged detach it from the sink turn on the water and see if it comes out into a bucket if it does than its your new facuet
May 12, 2009 | Plumbing
GE PFSS6SMX french door fridge water dispenser not working
check the fiting where you tapped the water for the uit. If its a saddle valve what happens is the the gasket closes down and restricts the water flow.
Feb 28, 2009 | Whirlpool GD2SHGX Refrigerator
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Just moved. New washer leaks water and appears tub is off center
CHECK THE BALANCE SPRING LOCATED (INSIDE LEFT REAR OF MACHINE). IF SPRING IS OFF IT CAN CAUSE THE TUB TO TILT TOWARD THE FRONT AND THE TUB FILL HOOD WILL NOT BE OVER THE TUB DURING FILLING OR THE TUB WILL BE ERATIC DURING THE SPIN WHEN RINSE WATER IS SPAYING IN CAUSE ING THE WATER TO MISS THE TUB AND SPRAY OUTSIDE. THIS IS COMMON IF THE UNIT HAS BEEN MOVED OR PLACED ON IT'S SIDE OR CARRIED AT EXTREME ANGLE.
Jan 17, 2008 | Whirlpool LSN1000LW Top Load Washer
Frigidaire FSC23F7D Side by Side Refrigerator Logo
59 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
