Question about Craftsman Drills
Change drill bit - Craftsman Drills
  • 4 Answers
Depending on what sort of chuck it is, hold the chuck where u put the drill and pull the trigger and hold onto it, depending wheather it has a chuck key, then you turn in oppersite direction.
Posted on May 24, 2011
The bit wont lock in the drill, how do i fix this problem
This is a very easy fix - you have a quick change chuck on this tool. Turn the chuck counter-clockwise and pull it straight off - the new one goes on the same way. Quick Change Bit Chuck
May 23, 2014 | Bosch 11236VS Rotary Hammer
Change drill bit
no thanks, I don't need to change drill bit. but thanks anyway
Dec 08, 2013 | Milwaukee Tool Drills
I can't loosen the the sleeve that holds the bit and therefore I can't change my bits.
Stick the speed fix to 1, put drill in reverse, and hold on to the chuck as hard as you can, and squeeze the trigger.
Jun 07, 2012 | Makita 12 Volt Cordless Drill/Driver Kit
Changing Bit
where the bit goes into the drill there is a metal ring. Pull the metal ring away from the drill with one hand and pull the bit out. this model you may have to pull the meteal ring twards the body of the drill.
Feb 26, 2010 | Makita 9.6v Cordless Impact Driver 6903VD
How do I change the bit on makita 6095d The drill bit is on right now and I simply want to change it to the phillips screwdriver bit. Thanks
have you opened up the chuck to remove the drill ? If not then you need to by holding the chuck tightly with your hand and then run the drill in reverse. hope this helps you
Oct 05, 2009 | Makita Drills
Keyless Chuck how do you change the bit? Model
hold outside collar on chuck firmly with your hand and reverse drill
Jul 10, 2009 | Black & Decker 3/8" Variable Speed...
Getting a small drill bit in straight and tight
I would replace the chuck or purchase a 1/16" quick change drill bit.
Apr 04, 2009 | Ryobi 3-piece 18V Drill / Circular Saw /...
How to change the drill bit
there is a rippled edge close to the very tip of the drill and there is a key supplied with the drill with the corresponding ripples place key into the hole near tip of drill so ripples meet each other and turn key in an anticlockwise direction to loosen put in new drill bit re tighten in clockwise direction hope this helps if not please ask for more info glenn
Nov 23, 2008 | Black & Decker 3/8" Variable Speed...
Drills Logo
35 people viewed this question
Top Craftsman Drills Experts
Tim Venetis
Tom Chichester
Are you a Craftsman Drill Expert? Answer questions, earn points and help others
