Question about Sigma Sport BC1106 Dts Wireless Bike Computer
My Sigma wireless dts 1606 L is not getting a consistent signal between the transmitter and the receiver. For example to day I rode 60 kms and the computer only worked / received 2kms worth of signal - the transmitter clicks loudly when it passes the magnet, however the green light does not always flash when it passes the magnet. I tried changing the battery on the transmitter but that did not solve the problem - the reciever has a good clear screen so the battery is not an issue here. The issue is very frustrating and I would appreciate any expert input.
    Brigadier General:
  • 8,546 Answers
It's a matter of good line of sight and distance between the transmitter and the receiver. Yours may be on the hairy edge of too far. Remove the receiver and test it at various proximities to the spinning wheel when it's transmitting.
Posted on May 22, 2011
Sigma wireless bicycle computer. Model BC 1606L. Wireless cadence monitor has abruptly stopped working. All other functions of this unit working perfectly. Transmitting unit and receiver have new...
Did you throw the magnet on the crankarm? If not check the alignment of the transmitter and the magnet - sometimes they need to be quite close. Sometimes they just fail. I have seen instances where cadence worked and speed didn't and vice versa - so the unit is transmitting perfectly, but one of the sensors has gone bad.
Jun 12, 2011 | Sigma Sport BC1606L Dts Wireless Bike...
Tip
Genie Intellicode Remote Transmitter Programming Instructions
USE ONLY WITH SERIES II ELECTRONICS.<br /> Older Transmitters and Receivers will not work with these new electronics. There are no Security Code Switches inside the Door Operators, Transmitters and Receivers.<br /> <br /> <br /> To Program Receiver <br /> Step 2-1 Locate the Learn Code Button and Radio Signal Indicator on the Power Head Receiver of your Door Operator.<br /> <br /> Step 2-2 Press a Transmitter Button once within 30 seconds.<br /> <br /> Step 2-3 Press and release the Learn Code Button<br /> &bull; The Radio Signal Indicator will blink approximately 2 times per second.<br /> &bull; The Radio Signal Indicator stays lit - SOLID.<br /> <br /> Step 2-4 Press the same Transmitter Button within 30 seconds.<br /> &bull; Radio Signal Indicator will go out.<br /> <br /> NOTE: If a second Transmitter Code is not confirmed within 30 seconds or if a different Transmitter Code is sent, the Radio Signal Indicator will blink approximately 4 times per second, then programming will stop. If programming stops, repeat Steps 2-2 through 2-4.<br /> <br /> Step 2-5 Repeat Steps 2-2 through Step 2-4 for each Transmitter, Wireless Keypad or other access device to be learned.<br /> <br /> NOTE: A maximum of 7 Transmitter, Wireless Keypad and other access device Codes can be stored into Receiver Memory at one time. If a Transmitter becomes lost or if you want to delete a Transmitter, Wireless Keypad or other access device, proceed to ERASING ALL RECEIVER MEMORY.<br /> <br /> <span style="font-weight: bold;">Multi-Button Transmitters</span><br /> <br /> NOTE: Only ONE button of a Multi-Button Transmitter can be programmed into a single Receiver. The other buttons are to control other Door Operators.<br /> <br /> NOTE: If you are replacing a lost or stolen Transmitter:(1) Erase ALL Transmitter Codes from the Receiver memory. (2) Reprogram the Receiver with the remaining Transmitters Codes.<br /> <br /> <span style="font-weight: bold;">Erasing All Receiver Memory</span><br /> <br /> Step 4-1 Press and HOLD the Learn Code Button for 10 seconds or until Radio Signal Indicator goes out.<br /> <br /> <span style="font-weight: bold;">ALL Transmitter Codes are erased from Receiver memory.</span><br style="font-weight: bold;" /> <br /> Step 4-2 Reprogram the Receiver with the remaining Transmitter Codes (Repeat Steps 2-2 through 2-4).<br /> <br /> <span style="font-weight: bold;">Step 5-1 Battery replacement</span><br /> &bull; Slide Battery Cover off of Transmitter back.<br /> &bull; Replace with new batteries.<br /> &bull; Slide Battery Cover back on.<br /> <span style="font-weight: bold;"><br /> Step 5-2 Visor Clip installation</span><br /> &bull; Slide Visor Clip into back of transmitter until it snaps into<br /> place.
on Jun 21, 2011 | Genie Company IntelliCode GICT390-1BL...
My Sigma BC 1106 bike computer won't register the movement of my wheel. I spin the wheel and the speedometer stays at zero. I changed the batteries, the magnet on the spoke is still magnetized and I...
I had this problem as well. What I found was that the transmitter path from the magnetic sensor to the computer is very narrow, a 15 degree cone. Reposition your computer to fall within this cone. It should pick up the signal.
May 08, 2011 | Sigma Sport BC1106 Dts Wireless Bike...
Hi, My sigma bc 1009 sts stop functioning during rides.The speed flashes as 0km\h.I changed the transmitter battery,then the display flashes"spd trans low".Then I changed battery and it's the...
Well, it IS wireless. Perhaps the distance or line-of-sight isn't right. As a test, hold the receiver in your hand and hold it closer to the spinning wheel transmitter.
Mar 31, 2011 | Sigma Sport BC 1009 STS Wireless Computer
Sigma BC 1106 DTS wireless. After 2 years it will only register time, total distance and total hours all other functions have ceased to work. Battery's have been changed, contacts cleaned and all parts...
Here is the link to Sigma Sport. They have a good customer service and I would discuss directly with them. That way whatever is determined you cut out several steps and either get the unit replaced or fixed properly with advice that is direct from the source.
This may also be a warranty situation in which case again you will eventually need to go through Sigma Sport.
You have done all the normal things that make sense to diagnosing the problem, sounds more like the problem is internal. One thing to also keep in mind, electronics like this do wear out and sometimes they just start to die off. This may also be the case, but Sigma Sport will be able to tell you.
Good luck
Dec 19, 2010 | Sigma Sport BC1106 Dts Wireless Bike...
How do u turn up a galaxy dx55v.
Hi, my name is John. Welcome to FixYa. Take off the cover, with the circuit side down, take a plastic tuning tool, you can get one at your local electronics store. turn your channel select to midway of the band. make sure your modulation is turned off. Key your mic and tune VR13 to the Maximum on the watt meter. this is for the power. Next, locate VR14 turn the modulation up, and say ahhhhhhhhh, repeat if needed. Thanks for choosing FixYa....John
Dec 01, 2010 | Galaxy Radios DX-55V Base CB Radio
Hi The pictures in manual docent show the direction clear . The magnet and the trnsmiter.
magnet gets screwed or clipped onto the spoke.the transmitter attaches to the fork.make sure the magnet on the spoke passes the centre of the transmitter (should be a mark on the transmitter)and also make sure the magnet passes the transmitter with 3 to 4 mm gap.you may have to turn the transmitter alittle to get it closer to the magnet.hope this helps
Oct 14, 2010 | Sigma Sport BC1106 Dts Wireless Bike...
Sigma Sport BC1106 Dts Wireless Bike Computer Logo
399 people viewed this question
Top Sigma Sport Cycling Experts
kirkjw
Level 1 Expert
Tom Chichester
Andy Brown
Andy Brown
Are you a Sigma Sport Cycling Expert? Answer questions, earn points and help others
