Question about Garmin GPS
Can not unlock maps nuvi 760 can you help - Garmin GPS
You need unlock code
Posted on Feb 09, 2009
Garmin nuvi 760 map update free download
Garmin Express Garmin Express but it probably won't be free. $50 for one time or $90 for lifetime... dont get the lifetime, get a new unit instead.
Jul 29, 2014 | Garmin Nuvi 760 Car GPS Receiver
Update file on garmin corrupted
Same happened to my Garmin Nuvi 760, power failed during upload. Files corrupted. Garmin could not locate it with Sat. Told me to trash it and they would give me $70 towards purchase of a new one, which would not fit in my cars receiver. My solution was to purchase a used one that had a good Garmin File folder. I copied the folder to my pc. It was important to remove the device file from the copied folder. I then formatted my corrupted 760. Then copied the folder from my pc into the formatted 760. Next step was to use Garmin Express to replace the missing device file, do the updates, and reinstall the maps. Product code to unlock maps was inside the rear plastic housing to unlock the maps. Whole process took about 4 hours and it works like new now.
May 02, 2012 | Garmin nuvi 255W GPS Receiver
Is it possible to get inland waterway maps (IRELAND)to suit nuvi
GPS City (http://www.gpscity.ca ) sells compatible Inland lake maps. Please note Garmin does not recommend them for that unit but I am sitting at my desk with one in my Nuvi 760 and it is working fine. You will need to turn off the street maps first to see the inland lake maps. I tested it with a Garmin Pre-programmed card for Alberta Canada.
Jul 12, 2010 | Garmin Nuvi 760 Car GPS Receiver
Garmin 750 cant unlock maps
Map unlock codes are specific to each unit. You will need to contact Garmin to obtain a code to unlock the maps.
Jul 10, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
Garmin nuvi 360 wont unlock maps
Master reset is after you turn on the GPS put a finger on the left lower corner rightaway and then keep the finger there, wait until it shows up the "Do you really want to start up in maintainance mode"
You are not able to use others nuvi's map on your nuvi 360, as each map must match with the GPS unit ID, to find out your GPS's unit ID, go to "Setting" tab on "System", tab on " About"
Mar 29, 2009 | Garmin NUVI 360 GPS Receiver
Garmin Nuvi 760 memory card
Does the Garmin Nuvi 760 require an additional memory card for normal use?
The simple answer is : no it does not need and SD card to work
Jan 26, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Can't unlock maps
What have you tried? without knowing anything else, one suggestion is to make sure you are using the correct unlock key number. There are at least three numbers located on the disk.
Aug 25, 2008 | Garmin (010-00583-00) for nuvi 750/760/770
Nuvi says "No Data Found"
I had the exact problem and i called 800-800-1020 to recieve two unlocking files from the Garmin assistant.
May 25, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
GPS Logo
524 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
