Question about Sewing Machines
The needle on our Empisal 9300 is hitting the shuttle hook - how can we fix this?
  • 106 Answers
SOURCE: pfaff creative 7570 shuttle assembly
Have a look at www.sewusa.com they have a "repair & threading page" this may help you re-assemble your machine. It is impossible to explain how to put the thing back together and re-time it, it is something you need to be shown how to do. Other alternative is to take it to a sewing machine tech.
Posted on May 04, 2008
  • 3422 Answers
SOURCE: Singer 1120 timing
h,
Timing" is the alignment of the needle at its lowest point and the hook on the bobbin case. The point of the hook must pass directly behind the "scarf" of the needle fo the interlocking loop of a "single needle lockstitch" machine to occur. Look closely at the needle. You will see the long groove along the front of it. This is where the thread rides as the needle goes up and down. If you look at the back of the needle you will see a flattened area just above the point. This is the "scarf"; it's flattened to permit the hook of the bobbin case to run right by it and catch the loop.
When a machine is out of "time", the hook is either too early or too late, OR to far away from the scarf to make the connection. You can send a machine out of time by hitting a pin, or breaking a needle "hard" (too fast through too many layers, etc.). You can usually identify a machine that is out of time by multiple skipped stitches at high speeds, or by stitching fast and then quickly putting it into reverse. Sometimes, you can scrape by if you rotate the insertion of your needle a little bit, this can help compensate for minor timing issues.
Posted on Sep 07, 2008
Mimito7
  • 128 Answers
SOURCE: Singer Simple Shuttle Hook Catching Needle
Sounds to me that your machine is out of time. I recommend you take it to your local repair center.
Posted on May 12, 2009
  • 46 Answers
SOURCE: Centered needle won't stitch
Timing is not correct.
Posted on Aug 05, 2009
  • 7 Answers
SOURCE: My needle doesn't catch the bobbin thread and if I
Sounds like a timing issue..... really should be brought to a technician.
Posted on Aug 09, 2009
My bobbing shuttle spins around and the needle hits it when I turn the wheel.
First, be sure you are using a brand new needle. A bent/dull/damaged needle may be hitting the internal mechanism of the machine.
If the needle is still hitting, it is most likely a timing issue. There are lost of web sites and videos on the internet that address sewing machine needle/hook timing if you want to try to fix it yourself. Or take it for service.
sewing machine timing Google Search
Jul 25, 2016 | Sewing Machines
How do i put the shuttle back correctly to stop needle hitting shuttle
If you are inserting the shuttle and locking it in place but the needle continues to hit, the needle may be bent. If a new needle is installed and it continues to hit, most likely the needle/hook timing is off. Take it for service.
Feb 23, 2016 | Sewing Machines
Singer 9116 needle hitting shuttle ****.
Is needle bent? Are the feed dogs aligned? Shuttle clicked in? Is the needle set for zig zag? Could be one of those things.
Best wishes
Nov 11, 2014 | Sewing Machines
I cannot get the top needle thread to pick up the bobbin thread on a Singer 404. I have the manual online and can see that I have loaded everything properly, but the bobbin thread just sits there when I...
Hi Jennifer:
Do you understand how a stitch is formed on a sewing machine? The needle goes down to its full down position. At that point the shuttle hook should be pointing right at the needle scarf, ready to go past it as the needle starts to go up.
When the needle starts its upward travel it forms a loop... the shuttle hook enters the loop and the bobbin thread is "captured" in that loop.
If your machine's timing is advanced, the needle will hit the hook and break or make nasty thumping noises. If your timing is ********.... the hook misses the loop entirely and does nothing.
So... open up the entire bobbin/throat plate area.... take the foot off so you can see. Clean if necessary. Then turn the hand wheel by hand until you see that the needle is at the lowest point of travel. Where is the shuttle hook?
From there you'll have to use your logic to find the right screws and adjust the hook.
Here' is a Parts Chart for your machine.
http://www.parts.singerco.com/IPpartCharts/404-1_4_5.pdf
Sep 14, 2012 | Singer Sewing Machines
How do I fix timimg on a singer 2263
There should be one or two set screws behind the bobbin shuttle, they could also be in the bobbin shuttle. You will loosen them st the timing and then retighten them. The Timing on a sewing machine is really straight forward, but that doesn't mean its not a pain in the but. When the needle is at the bottom of its travelthe hook on the shuttle should be coming around to meet the needle. As the needle starts back up it will create a loop in the thread for that hook to catch. Therefore the needle needs to start up before that hook is directlly in line with the needle. But the hook has to be above the eye of the neelde. So rotate it back and forth with no thread and watch to see when the hook passes the needle. It will probably take several attempts but you can do it. Do it in small movements. and only tighten the set screws enough to hold the shuttle in place to check it. Do not forget to retighten them.
May 27, 2010 | Singer Sewing Machines
Singer sewing machine jammed after sewing over straight pin
The shuttle and needle timing needs to be re-set. Also the hook needs to be inspected for damage.
Oct 14, 2009 | Singer Sewing Machines
May 12, 2009 | Singer 3116 Simple
Singer sewing machine Merrit. Needle is hitting something and not going into hole
turn the machine slowly by hand as the needle goes down check it does not hit the foot ,then the hole of the plate.
If it enters the hole and then stops aganst something it is possible the shuttle or bobbin is not in right take them out and replace them again.if the problem prisists take the needle plate off and warch as the needle goes down what it is hitting.
if the hook or shuttle is in the way the timming could be out.
Aug 01, 2008 | Singer 3116 Simple
No action
Remove the bobbin, bobbin case as well as the shuttle hook. There are black pins/holders that hold the shuttle hook. After you remove these 3 components, make sure there are no thread stuck in between the 2 hook pieces as well as the bobbin shaft. Most of them time, there are either fabric or thread stuck. If not, make sure the needle is not hitting the feed dog or the hook.
Feb 23, 2008 | Yamata FY920
Sewing Machines Logo
43 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
