Question about Onkyo TX-SR307 A/V Receiver
Input selection changing often by itself. e.g. while playing DVD, av receiver input selection change from DVD to CD then it comes back to DVD after some time automatically. I have reset the receiver by holding VCR/DVR + stanby button but the problem still exist.
    Brigadier General:
  • 8,546 Answers
I'd suspect a poltergeist or a stray i/r source somewhere in your environment. You can prove the latter by blinding the receiver so it can't 'see' any remotes. Then just wait. If it behaves you have an unintended i/r source that it listens to. Security systems, garage door openers, sunlight...
Posted on May 22, 2011
How to source AV Input on remote
Search Results
    How do I change the input on my television? ' FAQ ' Cogeco ...
    https://www.cogeco.ca/.../how-do-i-change-the-input-on-my-tele...
    CogecoClick on the TV button near the top of the remote. Click on the video source button on the bottom left corner of the remote. Using the arrow keys to highlight/select the inputyou want. Some televisions may require pressing the source button multiple times to change the inputs.
    Understanding Inputs - Harmony Support - MyHarmony
    https://support.myharmony.com/.../understanding-different-input-changi...
    Televisions, AV receivers, soundbars and other home electronic devices switch ...Devices with toggle (or cycle) inputs have a single button on their remote that ... In the below example, you would press the Source button to bring up a list of ...
    Changing AV input on TV using Sky remote ' AVForums
    www.avforums.com > ... > Satellite TV, Sky TV & FreeSat
    Changing AV input on TV using Sky remote. Discussion in 'Satellite TV, Sky TV ...VSX-924 LG simplink changing AV source to TV. Posted By djrobmac In AV ...
    Selecting the DVD, VCR, Game Console, HDTV, Camera, or ...
Feb 08, 2016 | Venturer KLV39150 15" Under Cabinet LCD TV...
Can't change channel 3 to video for dvd playing - video won't come on to use with dvd player
I SUGGEST YOU USE AV CABLES( RCA ) AN CONNECT TO THE AV INPUT OF THE TV
Jun 20, 2013 | Panasonic CT-36D32 36" TV
How to play digital input
You need to assign a digital input (optical 1 2 or coaxial 1 2..) to a source (DVD CD etc). You can do it in setup menu > input assigment. Some receivers have preassigned inputs, check labels you your receiver next to digital input. Ex If it says "Opt1/DVD", select DVD and receiver will play a signal from optical 1 input.
Dec 18, 2011 | Denon Audio Players & Recorders
Multi room will not play any digital input, just analog. I.e. Video 1 when analog connection plays in multi room, but optical 1, when set as input for vid 1 will not play in multi; works fine in main...
I have a Marantz 7.1 AV receiver (sr5500) and I run a 5.1 set up for home theatre and use the 2 extra channels to run a pair of outdoor stereo speakers... When I first set it up I also found I could not get a digital signal output, only analog, after reading the manual(!) I discovered that it can only output an analog signal...so I have used the phono outputs on my blu-ray player into the CD input of the AV amp and play CDs outside through this and it also outputs the optical digital signal into the AV amp through the DVD input...my iPod also plays through a dock and it's analog output to the speakers outside through another (CD-R) anolog input on the amp... Hope this helps
Dec 24, 2010 | Harman Kardon AVR 335 Receiver
No sound when dvd input is selected on onkio tx-ds696
Make sure your DVD setting is looking at the right audio inputs. Usually there is a menu option or a button to toggle from analog or digital input. Usually when no-sound but video ok, you have the wrong input-type selected. If you are using 2 RCS's (red/white) then you want ANALOG input mode. If you are usung a single RCA (orange) or a fiber optic input for audio, you want DIGITAL input selected. If digital os selected, make sure you plug into the correct digital input to hear. If it does not work at first, mofe the jack/fiber around into the different inputs untill you hear sound, then you will know which port is associated with the DVD setting. Unless it is self evident feom the menu.
Jun 12, 2009 | Onkyo TX-DS696 Receiver
Can't change TV to AV input.
dont bother trying to do it but then i got the same problem :)
Nov 30, 2008 | Televison & Video
Dvd plays can see picture but no sound
Check all your connections.
Also please let me know how you have it connected currently, what is the model of the dvd player and the television. Are you running through an AV receiver?
one ting to try is connecting ONLY the red and white audio connectors from teh dvdplayer to the correct input on the tv while it is on. if you hear a slight "pop" [not harmful] you have the right input and there might just be a problem with the dvd player itself.
be sure you have the right audio track selected or try playing a cd.
May 02, 2008 | Televison & Video
Hooking up external DVD player
if you tryed to hook up into another video input you also have to switch the inputs on the remote in the input menu from input 1 or 2 to the same.
May 27, 2006 | Toshiba MW20FM1 20 in. Combo
Onkyo TX-SR307 A/V Receiver Logo
67 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
