Question about Peg Perego John Deere Loader WTrailer
Hi we have had two John Deeres that have done this very same thing....It will go in to second gear dive for about 10 seconds, then short out again, then drive again in about 10 seconds so forth as long as your foot is on the power pedal.Is there a way to fix this or are we just out of luck again?
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Probably a bad motor, disconnect one of the motors and see if it still does it, then you know that disconnected motor is the bad one
Posted on May 14, 2012
3 Suggested Answers
  • 156 Answers
SOURCE: John Deer Gator only drives in low gear.
Sometimes the levers go bad in the shifter, but I would first check the shifter to make sure the switches are engaging. You should also check the wiring on the motors in the rear. Sometimes they come loose and if they are not making a good contact the gator will not go in proper speeds.
You can get great help at http://www.shopjandl.com/mepu0002.html.
They have a toll free number and are very helpfull because the repair them as well.
Posted on Apr 08, 2009
  • 19 Answers
SOURCE: my sons peg perego john deere jeep only sets off
I would get the Peg Perego Gator Shifter Assembly from http://www.shopjandl.com/
Make sure the wires are secure on both motors in the back.
One time I had the same problem and I had loose wires on the motor, but I ended up replacing the switch assembly later because it would only work in 1st gear.
Hope this helps
Posted on Jun 09, 2009
Whining sound
check the oil level
Jun 21, 2014 | John Deere Garden
Electrical short
Hi Craig, First thing to do is isolate which circuit has the short, this can be done by observing which fuse is burning. Secondly, trace the lines (cables) of each unit which operates in that circuit and eventually isolate the cable or unit. It may sometimes be advisable once the cable has been positively identified, to cut both ends and run an additional cable, replacing the original. Obviously if the problem is a particular unit, it will need rectification. Keep in mind that sometimes manufactures these days do not follow colour coding but instead use labelling at each end of a circuit. Toyota does just that on many circuits. Keep in mind that short circuits are extremely dangerous and can be life threatening. Regards John
Oct 06, 2013 | Dodge Ram 250 Cars & Trucks
No 2nd, but will go in 1st and Reverse
bad motor, pick up the back end and see which one isn't spinning, or disconnect one and then try all of the gears, one will work in all of the gears and the other wont, you can order a new one here http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=150894216724&ssPageName=STRK:MESE:IT
Aug 16, 2012 | Peg Perego John Deere Turf Tractor
Have a 2 year old 115 with new blades, the blade heights do not match in the center of the mower deck. Is there an adjustment so theymatch
No, not unless somebody has changed the bearing unit out and it has a different depth to it. The washer on the top? Maybe. I have 2 john deeres out there and I know they are not adj, but I would check the spindles for washers or whatever somebody might have done to it. How far is it off?
Jun 28, 2011 | John Deere 195HP Hydrostatic 42" Cut...
After grinding my machine will continue grinding three or four times every 10 to 15 seconds for about 1 second. Also when I am using the steam wand it will only steam for about 15 seconds and then the low...
Hi
Sounds like you might have spilled some descaling solution on top of the machine. It might have gotten down into the board and is shorting the circuits. I have seen this before. The board might be salvageable but needs to done professionally.
You could be leaking internally and shorting the board.
Dec 20, 2009 | Solis Palazzo Espresso Machine
SECOND HAND - INVICTA MODEL 2692
Hi Ed,
I have been in the industry for the past 2 years as a watchmaker's assistant. So I'll see if I can help.
The larger second hand you see in this Chronograph model, using it is only available in the Chronograph mode.
How long a battery should last (if I had a dollar for everytime I've heard that one! :)
Well generally a battery should last about 2 years. It all depends on how many functions that watch has, as for a chrono the more you use that function the more the battery power it uses. I have not seen this watch but as it looks to be the 'standard' kind of format of a chronograph, just one battery would surfice.
In regards to 1/10 lap, please take the to a watchmaker as the hands need to be reset, this either can be done manually or can be done by pulling out the crown slightly (please as if you are to forcefull you will pull the crown and stem out) NOT GOOD!. if you pull it out to 'quick date change' where only the date can be changed try pressing one of the pushers and see which sub dial hands move, if that doesn't work try the other pusher.
Again if the above doesn't work, pull the crown out to time set mode (where you can adjust the time) and try the same steps as above. If this fails and it's still off, take it to a watchmaker and he/she will realign the hands for you!
Kind Regards
Shenlun
Jul 12, 2009 | Invicta Dive/Sport - ABYSS ALARM CHRONO...
Transmission wont shift until about 4000rpms from 1st to 2nd gea
Have a code check done and see if speed sensor or controller is working properly. if bought from a dealer, get it back there asap...they can't sell it in that condition!!...No test drive before you ploped down your money?
Apr 16, 2009 | 2004 Jeep Grand Cherokee
Escort rs turbo
it could be sum thing ta do with an alarm or sumthing.had a corsa an scubby tat done tat.tock the imbolisea out and alarm and went 110 percent
Oct 21, 2008 | 1988 Ford Escort EXP
No Power in Mitsubishi VS-55705
Hi John This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB
Sep 11, 2007 | Televison & Video
Peg Perego John Deere Loader WTrailer Logo
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
