Question about GPS
Hello FixYa I own a 2003 Jaguar X-type manufactured in England which was originally exported to Japan. It is fitted with a Denso navigation model no 2R83 10E887 BB 462100-8125. I live in New Zealand. What disc do I have to use to get this unit working here? Jim Beaton
onyeredson
  • 404 Answers
SOURCE: yamaha sr 125 how much air should i pump to rear and front tyres
Hi!
You are asking a sensible question and obviously are concerned and rightly so for your safety and others plus tyre wea.
Good on you!
However it depends on load,circumstances, conditions and the type of tyres/compound you have.
So as a rule of thumb, 28/30 front normal conditions rider only short journeys, 30/32 rear normal 2 riders +- 2psi for loads and long runs.
Hope this helps, press the Blue button please to rate my FREE! efforts, Thank You!
Paul 'W' U.K.,
Posted on Feb 13, 2009
raygin
  • 322 Answers
SOURCE: Jaguar 2003 S Type
1 More info needed for disc fault = what are you trying to do to make this disc message appear?
2 The car picture is the dsc switched off - but this message should disappear if the ignition is turned off and on again as the dsc is on by default. If this dsc message keeps reappearing then you may have a fault in braking or sensors that is triggering this message - get it investigated.
Posted on Apr 29, 2009
  • 52 Answers
SOURCE: 2003 Jaguar S-Type, programming a key fob
If its a new key fob the only way you can program it is this the factory scan tool, u'll have to take it to a dealership for them to do this and they will charge you .5 hrs for labor.only x-types can be programmed without the jaguar software. Im guessing it will cost you between 40 and 50 bucks to have them program it.
Posted on May 11, 2009
SOURCE: denso navigation problem
I had the same problem, and then I figured it out. I unhooked the dvd rom opened up the unit and noticed there were resistors on the board which were burned out and the inside of the housing showed slight signs of oxidation. I came to the conclusion that since the unit was mounted in the trunk the unit malfunctioned from water intrusion or moisture, which shorted out the board. Now I'm searching the web to see if I can find a Denso repair facility.
Posted on Oct 26, 2009
SOURCE: Hello i have a Pioneer Carozzeria avic DRZ90. It
Hi
Download the disk image here
Good look
Posted on Sep 08, 2010
2004 Jaguar, Vaden Plaus,car just quit running going down the road. Had to have it towed home Won't start,turns over, just won't start,says Restricted Performance.
Sounds like it is some type of 'limp home' mode.
It could be anything. It might be as simple as a bad Fuel Pump Relay. When you turn the Key to the ON position (not Start) can you hear a little buzz for about 1 second? That would be your fuel pump running. You need to see if the engine is getting gas and spark.
Jan 05, 2016 | Cars & Trucks
How do i get the code into the radio for my s type jag it is saying locked 10 at the momen
if its the original fitted radio contact jag agent with your chassis number found in your log book if its not the original contact radio manufacturer
Aug 24, 2014 | Jaguar S-Type Cars & Trucks
How to turn off security on 02 jaguar so car will crank
No easy way of doing this and the ECUs on the pre 2004 jaguar are very complex. They are made by Denso Japan. There is one specialist in the US, you would have to remove the alarm (immobilizer) ECU and I think the main ECU and send it to them to recode. Alternatively you can take it to a main dealer with the full jaguar factory software and he should be able to do this (at a price).
Aug 13, 2014 | Cars & Trucks
How do i update the navigational system in the 2003 jaguar s-type?
you need to purchase a new nav disc, sorry not cheap i dont think
Jun 01, 2013 | 2003 Jaguar S-Type
Can you help with instructions on how to install a mesh grill and spoiler on a 2003 X Type Jaguar..... Thank You
i have fitted an "admesh" brand mesh grille and spoiler on my fathers 2004 X type.
the mesh in the spoiler would have just fitted over the existing plastic grille using the supplied clips, if the original grille had not been damaged. i just removed unscrewed the original grille and fitted the mesh one using the same fittings.
for the main grille, i removed the grill from the car (4 screws) and cut out the centre plastic vanes before fitting the new mesh one to it using the supplied clips. i then screwed the whole unit back in place. it took about 1 1/2 hours from start to finish for both mesh grills.
the instructions were quite clear and most helpful.
i do not know which kit you have so do not know specific fitting instructions, but as far as i am aware, most kits would fit in a simillar way and should not be to difficult to fit with a little care.
Feb 25, 2011 | 2003 Jaguar X-Type
I have ATN night jaguar binoculars and one side has stopped working, i want them repaired and i live in the uk, what do i do??
Hello, it seems that there are quit a few people that have ATN products that will destroy it self just setting on a shelve in the closet. I sorry to mention this to you. This ATN Night Jaguar Binocular are manufactured in Russia.
The biggest problem is those Russian image intensifier tubes. They are manufactured without any type of quality control, also they are made with very thin glass, and what is the quality of this Russian made glass. About 85% of the problem with a number of vender's that sell and ply their NV goods that all are manufactured in Russian, and that even includes the cases. Night Vision vendors will have the Russian put their name's and logo's them and sell them as; excellent quality Night Vision Monoculars, Binoculars, scopes, and other NV devises.
This could be a problem for you being in England. I think that ATN might have a couple of distributors located in England, and Europe. You need to check their web site. Also, you know that this ATN NV binocular is about 7 years old. I'm fairly sure that ATN will try to get you to trade in for a upgrade which more British Pounds. They might also tell you to ship it to the US for repairs. You can try to auction it off on eBay in Europe. I need some parts, what do you want for it? Sorry buddy. Best of Luck, GB you.....stewbison
Dec 03, 2010 | ATN Night Jaguar Binocular
Low beam bulb on 2003 X-type
Hi Rod
Open the hood, remove the plastic dome cover, and then the bulb connections, un clip the bulb retainer, extract the bulb, and check with the new one that its same.
No fingers on new bulb or it will pop when you switch on.
Fit new bulb and retaining clip, refit wires, test it, then fit plastic cover.
Good Luck !
This is what it looks like under hood !
A FixYa rating would be appreciated Thank you !
e3ac4f3.jpg John
Feb 08, 2009 | 2003 Jaguar X-Type
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
