Question about Sharp EL-738 Scientific Calculator
How do i obtain NPV and IRR using Sharp EL-735S
  • 3 Answers
SOURCE: Calculating out npv and irr
Use the "FINANCE" app:
[APPS] [1] [ENTER]
for npv: select "7:NPV"
now you should get "npv(" on your screen.
use: npv(interest rate, cost {cash flows}, {frequencies of cash flows})
for irr: select "8: irr"
"irr(" will come up.
use: irr(interest rate, cost {cash flows}, {frequencies of cash flows})
Posted on Apr 30, 2009
  • 102366 Answers
SOURCE: how do i use the calculator to calculate problems
http://education.ti.com/calculators/downloads/US/Guidebooks/Detail?id=6115
Posted on Jan 21, 2011
tbreeze47
  • 3083 Answers
SOURCE: My hp 12c platinum can't
The button pad could be bad, or you could have a bad portion of a chip, hard to tell. I've never taken a 12C apart, but it's probably possible to take apart and possibly clean the button pad, however, I believe these devices had a protective membrane on the button pads to prevent anything from getting to the pad contacts to contaminate them, so trying to clean it might be a waste of time and in vain.
You might review the procedure for performing NPV calculations on the following web page:
http://h20331.www2.hp.com/Hpsub/downloads/HP12CNPV.pdf
They mention something about the n register needing to be cleared, so it might be worth reviewing.
Sorry I don't have a specific solution, but hope this helps.
Posted on Mar 22, 2011
  • 1833 Answers
SOURCE: Hi, I have a HP 10bll
To solve cash flow problems, you may find a button CF1, now all that you need to do is enter the cash flow exactly. Again clear the financial keys first, now enter each cash flow figure seperatellt followed by the SF1 and you will find the present value. For any further problem you can check this link :
http://www.tvmcalcs.com/calculators/hp10bii/hp10bii_page1,
http://www.tvmcalcs.com/calculators/hp10bii/hp10bii_page3
Posted on Apr 11, 2011
SOURCE: Casio fx-991ES, how to calculate
At a blank screen, enter your IRR formula in terms of the variables using ALPHA and ')' for variable X. For example: -1000 200/((1 X)^1) 200/((1 X)^2) ... rest of subsequent years. Then, press CALC. It will prompt you to enter values of your variable (X in this example). Don't worry if there's already a value displayed - this is just the most recent value that has been stored as that letter. Simply enter your value (in terms of your IRR guess) and then press [=]. You will have to repeat this for each IRR guess until you reach almost ZERO.
Posted on Sep 19, 2011
How to Calculate IRR?
To calculate IRR and NPVEnter the cash flows as follows, remembering the sign convention:
  • Clear previous data by pressing fXY and fCLX.
  • Enter the cash flow at time zero using # gPV [# CF0].
  • Enter subsequent cash flows using # gPMT [# CFj].
  • If a cash flow is repeated, enter the number of times it is repeated (including the first time you just entered) using # gFV [# Nj]. For example, three equal flows in a row would be entered as3 Nj.
  • When you have entered your last cash flow:
    • If you are calculating an NPV, enter your interest rate as # i (consistent with interval between cash flows) followed by fPV [NPV].
    • If you are calculating an IRR, enter fFV [IRR].
This is an excerpt from http://luna.pepperdine.edu/faculty/mkinsman/calculators/hp12c.html
I did not come up with this solution. Just found it for you.
Apr 04, 2011 | HP 12c Calculator
Hoe do I calculate the IRR (internal rate of return) on sharp EL531WH
Can anyone provide the steps for calculating IRR on the Sharp EL-531WH?
Mar 30, 2011 | Sharp EL-531VB Calculator
Casio fx-991ES, how to calculate NPV and IRR
Feb 11, 2011 | Office Equipment & Supplies
Where do I find an instruction manual on the sharpe el 735 calculator
Operation manual for the Sharp EL-735 and one for the newer EL-735s, if you have the model with the "s" ending.
Sep 06, 2010 | Computers & Internet
Computing IRR calculator goes blank and outs Error 7
I belive this will fix the problem i was sitting here having the same deal waiting and waiting..then bam error 7 then i fixed it so thought i would put what i did.
go into your CF and delete all the unused CO times..for instance if your using 3 periods...delete all CF05 and F05 the last one should be C04=0 and F04=0 make sure your NPV is the same after messing around..then try to compute IRR popped up in 2 seconds for me.
word hope this helps u all ***420*** :0
Nov 21, 2008 | Texas Instruments BA-II Plus Calculator
Are you using the finance app?
[APPS] [1] [ENTER]
For NPV, choose "7:npv("
Then use:
For IRR, choose "8:irr("
Then use:
Jul 25, 2008 | Texas Instruments BA-II Plus Calculator
[APPS] [1] [ENTER]
May 13, 2008 | Texas Instruments TI-84 Plus Calculator
Sharp EL-738 Scientific Calculator Logo
498 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
