Question about Husqvarna Chain Saw 20" Bar
Chain saw starts but wont stay runimg - Husqvarna Chain Saw 20" Bar
    Sergeant:
  • 281 Answers
HI,
Use a stiff piece of wire and form a hook on one end and use it to fish the filter that is on the end of a tube in the gas tank.Buy a new one and you should be back in business.Hope this helps and thank you for choosing FixYa.com.
I always add this for your information. If this is not the solution that you are looking for please re post because when we pick a question to answer FixYa takes it out of the questions.
Posted on May 22, 2011
Ryobi pcn 4040 chainsaw won't start What is the
1st add fuel/oil mix to fuel tank , then top off oil tank with bar oil , place saw down on flat surface , press 'ON" button above trigger handle to ON (its marked on case) then pull out blue choke handle till it clicks and stays out , press primer bulb with thumb 8 to 10 times bulb will become harder to press as it fills carb , push chain brake forward (on) ` place left hand on top of saw and right hand on start cord , hold saw down firmly and pull cord vigorsly several times till it sort of starts (sound) , squeeze trigger in and pull cord once more , saw should take off running , chain wont move ,walk to wood pile then disengage the chain brake and cut wood , if saw fails to start after this procedure then there must be a fault in saw , consult a exp small engine dealer for repairs
Sep 01, 2013 | Ryobi 18-inch Electric Chainsaw Chain Saws
Saw starts, wont stay running unless throttling then bogs and dies. changed pluge, gas, cleaned tiny screen in carb, checked diaphrams.
hi
check the fuel pump(not to be tired)inside the carb.the carb could be out of adjustment
regards savumihai71
Oct 29, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
CHAIN SAW WONT STAY RUNNING
PLEASE stop shouting and provide a model number for your saw. I will provide an IPL with some fuel system detail and a schematic to use for hose replacement. Reply below. Lou
Mar 15, 2010 | Homelite Garden
Wont stay running when you let off the gas???
Sound like the carb was never adjusted right. Unfortuatley, the carb adjustment screws require a certain tool that's not available to the public. (EPA thing) You'll have to take it to a shop to get it adjusted. That should solve the problem.
May 25, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Choke wont stay in the closed position for starting
Been a while since I saw a Jonsered but I think if you bend the choke linkage a little that it will stay in the choke position.
May 19, 2009 | Standard Oregon Chainsaw Chain For...
HOMELITE Textron Chain Saw, wont stay running properly.
The preset is to turn them all the way in (Don't tighten them hard or you will damage the needle) and then back each out 1 1/2 turns. This will get you started. You can then run it at full throttle and turn the high speed jet in untill you hear a change in the RPM. Then turn it out untill you hear the same. Find the happy medium.
May 09, 2009 | Garden
Wont stay running
Try pumping the primer till it's full of fuel, then start the saw
Apr 03, 2009 | Garden
Husqvarna small chain saw won't stay on and now won't start
check your pick up coil . i had one it done the same thing to and that what it was
Apr 02, 2009 | Husqvarna Chain Saw 20" Bar
McCulloch chain saw wont stay running after it warms up. I go to cut wood it start to bog down if i let go of the button it idles fine
Is the chain brake engaged? The brake lever should be in the back position. Toward the handle.
was this helpful?
yes
no
Mar 23, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Husqvarna Chain Saw 20" Bar Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
