Question about Garden
I can start it but it wont run . I presume its a fuel problem, the diaphram or whatever. The main problem is I cant find who sells parts. Been on the internet, found thousands of ryobi tools but not this model, its as though it doesnt exist. I wouldnt mind buying a new replacement carby, in the Us they sell aftermarket ones reasonably priced but dont know how to cross reference it. What if any other ryobi trimmer model matches with this RST131Es model of mine? Any information would be appreciated Many thanks Steve
  • 3,740 Answers
Contact them here:
http://www.ryobi.com.au/sendusyourquestion.aspx
It should use the K10WAT repair kit. K10WAT kit is used on all Ryobi carbs for trimmers and brush cutters 31cc and below.
RYAN / RYOBI - WALBRO EQUIPPED
Trimmers
99 WA-62, 62A D10WA&T CAS459282 K10WAT CAS459284
551, 5511 WT-5, 11, 18, 24, 26, 58, 59 D10WA&T CAS459282 K10WAT CAS459284
1300, 1360, 1330 WA-62B, 62C D10WA&T CAS459282 K10WAT CAS459284
3477 WT-123A D10WA&T CAS459282 K10WAT CAS459284
3526, 3613 WT-124, 133 D10WA&T CAS459282 K10WAT CAS459284
31cc WA12, 25, 62A, 84, 85, 123,
124
Almost any reputable lawn mower repair shop will have this kit in stock.
Thanks for choosing FixYa,
Kelly
Posted on May 22, 2011
On a Poulan wood shark when I push the primer pump it squirts fuel out the hole on the diaphram cover an wont run on
You need to replace the fuel bulb. The gas is pulled in by vacuum and with a hole or crack in the bulb it can not build up vacuum. Most lawn shops can sell you a fuel bulb just tell them the model number of the saw.
May 26, 2017 | Cars & Trucks
Engine dying while started and fuel hand not working
on diesels this is comon on the escort diaphram in lift pump splits letting air into main fuel line allowing fuel to flow back to the tank no sucktion no fuel
Aug 17, 2012 | 2000 Ford Taurus
I have a te400 poulon weedeater,it will start only if i put fuel in the carb port.wont stay running
Check the fuel filter in the tank, inspect fuel lines and then clean the carburetor and replace the diaphrams.
Aug 31, 2011 | Garden
I have a MAC 3516 and it wont stay running. I found it at a yard sale for 35 bucks. I have cleaned out the bad fuel and am now running good fuel. I have set both high and low to 1.5 turns, it will start...
It sounds like a fuel issue, pull the fuel hose out of the tank and replace the filter on the end, check the fuel hoses for leaks or breaks, under the alloy pump cover on the carb held with a single screw is an internall fuel screen, clean or replace, at the same time check the condition of the pump diaphram, remember on this side the diaphram must go against the carb body followed by the gasket and cover.
May 01, 2011 | Garden
1987 30 hp johnson outboard wont start,was running one day and then had the fuel pump changed,now it dont start when i hit the electric start button.Battery is fully charged,new solenoid,power coming out...
Mate.Get the fuel pump checked.Diaphram might be in the wrong way.Fuel lines?if you prime the bulb,does it pump up?Was the electric choke hooked back up and is it working properly?Check the correct part was put in.Does it run or start if you squeeze the primer bulb.It may be in the wrong way if it was changed.Start from the tank and work slowly forward towards the motor.Hope this helps to get you going
Apr 08, 2011 | Boating
Won't start. possible diaphram problem?
Chainsaw carbs are all position pump carbs, and do have diaphrams, there will be a pump diaphram, and a metering diaphram, the pump diaphram pulsates via either a hole through the cylinder and induction block, or a pipe from the crankcase, the negative and a positive pressure produced as the piston rises and falls is fed into the carb, this diaphram shoud be flat show no signs of blistering or cracks, under this diaphram is the main inlet screen, this should be clean, any doubt and it should be replaced, the metering diaphram controls the amount of fuel allowed into the metering chamber, it should also lay flat and be supple, the metal disc in the middle should be flat and not distorted, both of these components are very robust and only need replacing if they are damaged, worn or have become stiff due to fuel attacking the material.
Feb 02, 2011 | Garden
96 blade fuel tank starvation?
The petcock has a safety in it that only allows fuel to flow when there is vaccuum applied to it. There is a second hose beside fuel hose that goes to diaphram in petcock. If the hose collapses or the diaphram ruptures then fuel wont flow. If you pull the hose off the back of the diaphram and see fuel then the diaphram is definitely shot. When you take the tank off fuel shouldn't flow. If you apply vaccuum to the port on the back of the petcock it should begin to flow. If not then petcock is bad. If it does check hose from engine to petcock.
Mar 03, 2010 | 1998 Honda CBR 900 RR Fireblade
Vtx 1300 won't start
Hi I have had the same problem with my 2007 VTX1300S, the problem was caused by the fuel tap diaphram this comes in two parts on this model the vacumn side and the actual fuel cut off side. the two sides become seperated and cut off the fuel supply. the smaller inner part should fit into the outer main part.
Dec 17, 2009 | 2005 Honda VTX 1300 C
Poulan wood shark 1950 wont start spark plug has
Try to squirt a little gas in the carb and see if it pops or tries to run for a short time. The diaphram in the carb is probably old and hard. That would be the first place I would look.
Nov 07, 2009 | Garden
Craftman conv.wont start run when first start it soon dieded
sounds like you need a kit through the carby the diaphrams go hard if fuel is left in them for too long.
Jul 22, 2009 | Craftsman Convertible 25cc. Gas Line...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
