Question about Kenmore 25614 / 25615 Progressive Bagged Canister Vacuum
The nozzle housing has cracked at one end of the front axle assembly. This allows the assembly to slip a little bit, resulting in failure of the lifter. Ds you think it pratical to try to replace the housing myself? Having a pro do it is quite pricey, but I just don't know how complicated it will be.
    Brigadier General:
  • 3,301 Answers
Contact Parts direct at sears, when you have them on the phone ask them to e-mail you the sheet that shows how that part is assembled,, you can get the part from them, heres the number 1-800-252-1698
Posted on May 22, 2011
Hoover max extract leaks from end of upholstery hose
Hello! The nozzle/valve assembly, the white piece at the end of the hose that releases the solution may be clogged with build-up residue. Try soaking the trigger end in warm water for a few hours. If this does not help, the nozzle/valve assembly may need to be replaced. Order the nozzle/valve assembly by following this link. Search Results or order the complete hose assembly by following this link. Search Results
Hope this helps!
Jun 06, 2014 | Hoover SteamVac F5914-900 SpinScrub...
I need to know the correct position of the rear wheel assembly and spring to istall in a electrolux renaissance power nozzle model#n106a in the base.Is this power nozzle refered to as PN5,6 or7? I also...
any Aerus deler will have the plate go to aerusonline.com they have dealer listing in your area. Beware they will try to sell you a new one. Part should be around $10 you may want them to put that axle and spring and cover on it is hard to do. A hint though for a DYI the spring barb goes in a little square hole in the weel channel. Good luck .
Apr 03, 2014 | Electrolux Guardian Bagged Canister Vacuum
How do i hook up my upholster cleaner
The parts needed for upholstery cleaning should be in the attachment box. First remove the rug nozzle (or hose) , from the motor unit. Next remove the entire bag assembly - grip the lower housing and turn it counterclockwise to remove. The attachment hose can now be placed on the motor outlet. Look for a small arrow on the hose connector and line it up with the small "bump" on the metal fan housing, and turn it clockwise to install. The air intake guard is placed on the front in place of the rug head. Turn the motor on to blow dust out of the hose and fan chamber prior to placing the spray gun on the end of the hose. Be sure to put the small "suds screen" on the nozzle of the spray gun to produce foam. Place the foam onto the area to be cleaned, and massage it into the fabric with a sponge or towel. Allow it to dry thoroughly before vacuuming it out.
Feb 06, 2011 | Kirby Ultimate G Bagged Upright Vacuum
Need to replace belt in Kenmore Vacuum Power-mate nozzle
Here's what you'll need to replace a belt on a Kenmore canister vacuum:
- Phillips Head Screw Driver
- Flat Head Screw Driver
There are two different types of belts that are used on a Kenmore Canister. One of them is called a cogged belt, which has little teeth on the inside of the belt. The other is called a serpantine belt, which looks like a car belt, and has little grooves on the inside of the. You'll be able to tell which on yours takes after opening up the power nozzle.
This is the Cogged or Geared Belt with little teeth inside the belt:
Kenmore Canister Geared Belt for Canister Vacuums
This is the other Serpantine Belt that has little grooves on the inside of the belt:
Kenmore Canister Serpantine Belt for Canister Vacuums
Here's how you can replace the belt on your Kenmore Canister vacuum cleaner. First, before taking apart the power nozzle to change the belt, try pressing the overload protection system reset switch. This overload protection feature is designed to shut off the power nozzle if something gets stuck in the brushes, to prevent the belt from breaking. On most Kenmore models it's either a grey switch cover to the right of the neck for your power nozzle, or it could also be a little red colored pole. The reset switch will turn all power off to the power nozzle. If you turn on the vacuum, and try turning on the power nozzle and you hear absolutely no noise, then it's possible it may just need to be reset. It also could mean that your hose may have a short circuit in it (pretty common on Kenmore), and the hose is not getting power down to the power nozzle. If however you turn on the power nozzle, and you can hear the motor in the power nozzle come on when you switch it to carpets, then mostly likely your belt needs to be changed. On the model that I was fixing, the reset switch is a grey color, and I highlighted the reset switch in red:
So we'll just say for this repair that you are able to hear some noise come on in the power nozzle, but the brush is still not turning. This indicates a bad belt. Here's how you can fix it:
Step 1. If you're power nozzle is a square shaped nozzle like the nozzle that I took a picture of above, then you'll need to first remove the headlight cover before you can access the roller brush and belt. Simply squeeze both sides of the headlight housing, and while squeezing, lift upwards with your fingers exactly where my fingers are located in this picture:
Step 2. After the headlight cover has been removed, you'll see two screws underneath of the headlight cover, directly in front of the neck of the power nozzle. You'll need to remove both of these screws. I have circled these screws in red:
Step 3. After both of these screws have been removed, turn the power head upside down, so the roller brush is facing upwards. Look on the both the left and the right sides of the power nozzle. You should see writing that points to an area to put your flat head screw driver. You'll need to put the flat head screw driver down inside of the nozzle, and pry the top blue housing from the black bottom housing. Here's where the screw driver should go on the left side0723429.jpg:
Here's a picture of the screwdriver prying off the right side:
Step 4. Now turn the power nozzle back over on top, and remove the top housing of the nozzle. You may have to push the handle release pedal in order to take the top housing off.
Step 5. Once the top housing has been removed you should now either see a white semi-circle shaped housing over top of the brush, or your model may not have this part (some did and others didn't). If yours has a long white part over top of the power nozzle, look at the back corners of this white colored housing, and you'll see two clips, one on each side. You need to push these clips in, and pull backwards at the same time.
Step 6. Once this white colored housing has been removed, or if you model didn't have this housing, you'll now have full access to the roller brush and belt. You should instantly be able to see the belt if it's broken, as it won't be connected to the roller brush. Simply pull straight up on the roller brush to remove it from the vacuum cleaner:
Step 7. Wrap one end of the belt around the metal motor shaft in the back of the nozzle. Wrap the other end through the roller brush, and stretch the brush back into the housing where it belongs. Simply reassemble the parts, and test the vacuum to make sure the brush spins!
If you don't hear the power nozzle motor come on when you change the hose from Floors to Carpeting, this either means the reset switch needs to be pushed, or that you have a bad hose that needs to be replaced.
If you would like help on how to diagnosis the electric hose to see if it's bad, please just use the Clarification Request here on Fixya. If you have any other questions, please feel free to ask me, I'm always more then happy to answer follow up questions. If this repair was helpful to you, please be sure to rate it as helpful by clicking the thumbs up icons at the top of the repair.
Thank you very much,
Chris J.
GoVacuum
Apr 06, 2010 | Kenmore 23313 Whispertone Bagged Canister...
My rear wheels keep poppping off. I've hammered and glued, but they won't stay on. Do I need new wheels or a new axle assembly?
Greetings,
You may need to just purchase the the little c-clips that hold the wheels onto the axle. Kirby Vacuums actually have a hub cap on their rear wheels that can be removed to access the axle end with the c-clip. If you take a flat head screwdriver, and pry off the plastic part of the wheel off of the rubber part, you should be able to see the end of the axle. There should be a little tiny c-clip at the end of the axle that holds the rear wheel in place. Is that clip there on both sides?
If yes, then you may need to replace the entire axle assembly. If they are missing these clips are available for purchase through many online websites including our own, govacuum.com.
If this repair didn't fix your Kirby, please contact me, I'm happy to try and diagnosis this further with you. If it did help, please rate the repair as helpful, thank you.
Chris J.
Mar 13, 2010 | Kirby Ultimate G Bagged Upright Vacuum
I took my Kirby G4 outer covers off, vacuumed the inside to remove the dust and now it refuses to turn on. Is there some sort of redet switch?
I'm pasting this from another solution I posted. Hope it helps:
There are a few things to check:
There are safety switches mounted on the body of the machine designed to prevent the machine turning on when it is not fully assembled. Ensure that your bag unit is snapped completely into place, (with the rear of the emptor assembly nearly flush with the body of the machine,) and that the front nozzle assembly is mounted correctly.
Also check that the power cord (immediately aft of the bag unit,) is pushed completely into the machine.
If the switch does not feel responsive, it can either be that the little metal "pole" (for lack of a better description) is not attached to the main switch assembly correctly, which will require you to open the entire housing to check.
Those are the simple things to check, otherwise it may need a switch, cord, or motor replacement. Checking continuity on these items with a VOM will allow you to determine the cause.
-R
Sep 10, 2008 | Kirby Vacuums
Need to replace front vacume propeller
You will have to take most of the vacuum apart to replace your fan.
First; remove the handle assembly by pressing the button on the front of it near the base. Remove the bag unit by twisting the rear of the emptor away from the body, and remove the front nozzle assembly by rotating the belt removal part to the "off" position and flipping the latch at the top of the nozzle.
There's a screw on the very back above the self propel select, and one on the top of the plastic where the cord attaches, removal of these will let you remove the rear plastic piece. Then there will be two more screws above the main power switch, and two on the front of the housing under the headlight. Remove the power cord, and then you can lift the rear housing from the main body.
Now you can remove the screws from the front of the fan housing; I believe there are five. Make sure you keep track which screws came from which position, because they are all different sizes.
To remove the front of the fan housing, put a flat-head screwdriver in the gap at the top to the side of the headlight assembly and pry it apart.
To get the motor pulley off you'll want to grip the pulley with a pair of vice grips, and use a wrench to hold on to the motor shaft in the rear of the machine. Look at the shaft that runs to the rear from the armature, and you should be able to locate a flat section which will allow you to grip it with a wrench... I do not recall the exact size, but there is a standard one that fits it perfectly. The pulley can then be removed. Note that it is reverse-threaded. Keep in mind that you will need to replace all the little plastic washers and rubber gaskets and things that are on the shaft with the fan. They are usually included with the Kirby fan kit, but if not make sure you find some before attempting the repair.
Before reassembly, you'll want to apply a thin layer of adhesive around the edge of the fan housing, making sure you don't glue the safety switch on the front into place.
Reassembly is the reverse of disassembly.
Good luck.
-R
Aug 13, 2008 | Kirby Generation 3 Bagged Upright Vacuum
How do i put a new belt in kirby vacuum ultimate G
You'll want to rotate the front plastic piece 270 degrees until the red triangle on the plastic piece lines up with the red triangle on the top of the nozzle. Then, rotate the nozzle release (located under the headlight assembly) until the nozzle can pull free of the main vacuum body.
Rotate the front plastic piece back to its original position and flip the nozzle upside down. There will be two clips which will rotate to release the baseplate. After removing the baseplate you should be able to remove the brushroll and take the belt off.
Put the new belt onto the brushroll, and replace the brushroll in the nozzle, making sure that the colored dot on each bearing end is the same on both sides to ensure that the brushroll sits level. then rotate the plastic front cover again, watching to make sure that the hook inside grabs the belt and pulls it upward.
Replace the baseplate, then turn the nozzle back upright and replace it on the front of the vacuum by setting it onto the axle on the front of the machine and then tilting the top of the nozzle back into place and turning the nozzle release back to lock the nozzle into place.
Rotate the plastic front piece back to its original position, and your belt should be fully installed.
-R
Aug 04, 2008 | Kirby Vacuums
Kirby vacuum suddenly appears dead. It worked this morning, but this afternoon would not even turn on!
-R
Jul 31, 2008 | Kirby Vacuums
I CAN'T SEEM TO INSTALL A NEW UB8 BELT
  1. Remove the lower plate
  2. Carefully lift up on the agitator assembly until it clears both sides of the nozzle housing.
  3. Remove the belt from the motor shaft by sliding it off between the end of the shaft and the nozzle housing.
3.4.2 Installation
  1. Place the belt around the motor shaft.
  2. Start the new agitator assembly back into the nozzle housing by placing the side opposite the belt partially into the slot. This will hold the agitator in place and leave both hands free to place enough tension on the belt to allow that side of the agitator to return to the nozzle housing slot.
  3. Place the belt around the agitator pulley on the agitator assembly.
    NOTE: There is a place for the belt to fit on one end of the agitator assembly only. This is the agitator pulley.
  4. Use both hands to pull the belt tight, and slide the agitator assembly firmly into the slots on each end of the nozzle housing.
  5. Rotate the agitator assembly by hand to insure nothing rubs and to check for correct assembly.
  6. Replace the lower plate
Jan 10, 2008 | Panasonic MC-V5745 Bagged Upright Vacuum
Kenmore 25614 / 25615 Progressive Bagged Canister Vacuum Logo
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
