Question about IBM 89P7663 Motherboard
MAXIMUM PROCESSOR SPEED SPORT - IBM 89P7663 Motherboard
  • 393 Answers
Your motherboard will support Intel Pentium 4 processor .
Thanks for using FixYa.
Posted on May 23, 2011
For work, I have an HP Compaq 6715b notebook with the standard 2.0GHz processor. If I right click on "My Computer" and select 'Properties' it shows 1.99GHz which is close enough. However, at times...
The computer does that because it does not have to run at maximum speed. Although it can run at a higher speed, it is usually a safety precaution to do otherwise. If the processor needs to run at a faster rate, it will. If you want to run at a higher speed, you can overclock the processor (Here is a site that may help: http://lifehacker.com/5580998/a-beginners-guide-to-overclocking-your-intel-processor). If you do try to overclock it, be aware that there are risks of doing this (heat problems, battery life decay, possibility of messing up the processor, etc.) but if you want to try it and that is not your main laptop/computer, try it, else, be cautious.
May 23, 2013 | HP AM135USABA Hp Compaq 6715b Business...
Tip
How to increase processor speed of a rooted android phone
For most smartphones, the processors are clocked at speeds much lesser than their maximum supported speeds to improve battery life. That also means you are not enjoying all the juice your phone can give you.
Lets see how you can overclock your android phone to unleash its full potential.
Important: Overclocking requires super user permissions and so your phone needs to be rooted.
SetCpu is the best app out there to overclock your android phone. Its sheer simplicity and useful options sets its apart from its competitors. You can either download it as a paid app from the Android market or simply download the zipped apk from XDA forums.
Using SetCpu. Once you install and start SetCpu, it will first show you a screen with two options. Unless you have a specific reason to do otherwise, simply select "Autodetect Speeds Recommended".
A screen will come up where you can change the maximum and minimum clock speeds and select the scaling method. SetCpu will automatically detect the maximum clock speed your processor supports.
Max - maximum clock speed.
Now its a bad idea to rush and drag the slider to its maximum in one shot. Although there will be no problems for most phones, it could lead to instability for some. Instead, try increasing the clock speed in small steps, running some heavy apps like games and if you don't see any instability, go back and repeat with increasing the clock speed. In case you find your phone going unstable at any speed, just set the speed to slightly below that value.
Min - Minimum clock speed.
Minimum frequency is the speed at which your phone will run when it is idle or no heavy apps are running. Setting it to a too low value can cause your phone to go slow with incoming calls, alarms and any other app that runs while idle. Generally it is advisable to set it to at least one third of the maximum speed your phone processor supports.
Scaling.
The scaling option determines how aggressively the minimum and maximum clock speeds will be applied. The drop down menu gives 5 options as below -
  1. OnDemand - Automatically sets the minimum and maximum based on load. This is the recommended setting.
  2. Conservative - Very similar to OnDemad except that the scaling is less rapid.
  3. Powersaver - Makes your phone run at min speed always to give maximum battery life.
  4. Performance - Makes your phone run at max speed always.
  5. Userspace - This option is useless as of now and is kept as a future option for apps to change clock speed that SetCpu doesn't use.
Once your phone looks comfortable with the new frequencies, you can use the "Set on Boot" option to enable the settings permanently.
Tutorial Video:Overclock Your Android Phone to Unleash its Full Power
Download link: http://forum.xda-developers.com/attachment.php?attachmentid=648354&d=1310073004
on May 27, 2015 | Android Apps
Tip
How can test Laptop?s temperature and temperature should it be at?
<p><span>If your laptop is not working ideally it may be the cause of temperature. But most laptops naturally run hot, so a system utility that can access your laptop's internal temperature sensors can help you decide if you need to take some steps to keep your laptop cool down.</span><br /> <p><span><span> </span></span><br /> <p><span>Most CPU's maximum temperatures are around 100 degree Celsius. But you can look up temperature specifications for your specific laptop's Intel or AMD processor. Optimal operating temperature is 50 degree Celsius or below.</span><br /> <p><span> </span><br /> <p><span>Some programs will help you to test your Laptop's CPU Temperature that can show you the CPU temperature as well as other system details such as processor load, voltage, and more. And some of them can also automatically adjust the speed of your laptop's fan for better performance.</span><br /> <p><span> </span><br /> <p><b><span>Speed Fan</span></b><span>- In the case of monitoring fan speeds, voltage, and processor temperatures using your laptop's internal sensors, Speed Fan can also access S.M.A.R.T. information to set your hard disk's temperatures.</span><br /> <p><span><span> </span></span><br /> <p><b><span>Real Temp-</span></b><span> The real temp is specially designed to monitor temperature for all Intel single, dual, and core processors. In the case to showing the temperature and load the processor, it also shows the CPU's safe maximum operating temperature and how far from this maximum temperature your processor is running at. Another most important feature of Real Temp is tracking of your highest and lowest temperatures since you opened the program.</span><br /> <p><span> </span><br /> <p><span>These tips may help you to determine the exact temperature for your laptop. </span><br />
on Dec 24, 2010 | Computers & Internet
I have this motherboard PACKARD BELL BV GA-T671MG. how much ram memory can it have? can i use ddr3? my pcie port supports a 2.2 graphic card?
System
System : PACKARD BELL BV ISTART F2310 AIO
Mainboard : PACKARD BELL BV GA-T671MG
Bus(es) : ISA AGP PCI PCIe USB
Multi-Processor (MP) Support : 1 Processor(s)
Multi-Processor Advanced PIC (APIC) : No
System BIOS : Phoenix Technologies, 255.255
Total Memory : 767MB
Intel Pentium D 3.00GHz
Packard Bell BV (GA-T671MG)
SiS chipset (Si671V11)
DDR2
1024mb ram
PACKARD BELL BV
Model GA-T671MG
Chipset Vendor Silicon Integrated Systems (SiS)
CPU Intel Pentium D
Cpu Socket LGA775 [Socket 775]
Processor Upgrade ZIF Socket
Max CPU Speed 3000 MHz
System Slots 2 PCI, 1 AGP
Memory Summary
Location System board or motherboard
Maximum Capacity 1024 MBytes
Memory Slots 2
Error Correction None
Use System memory
Maximum Memory Module Size 4096 MBytes
Manufacturer PACKARD BELL BV
Model GA-T671MG
CPU Intel Pentium D
Memory Summary
Memory Slots 2
Use System memory
it seems this might vary i have listed 4
hope this helps
May 17, 2011 | Computers & Internet
Maximum processor core speed on ibm i845g motherboard?
The maximum core speed processor for IBM i845g is 1.8ghz which you already have.
Nov 01, 2009 | Computers & Internet
How do I upgrade the processor to faster speed in acer asprie 4720z it has an intel dual core but the speed is only 1.73 Ghz and I would like at least 2.4 GHZ can this be done or do I need to purchase a...
PLease try to refer to your motherboard processor maximum support and see the processor you can upgrade to your laptop without buying new motherbaord and other accessories such as memory. Remember if you plan to upgrade device in your laptop please see the hardware maximum support that your laptop hardware can support otherwise if you buy processor and other device beyond the maximum limit support of your current laptop hardware it would not work as you plan.
Thanks
Aug 25, 2009 | Acer Aspire 4720 Notebook
If I Change My Processor will the the boot be the same
Probably the same but how do you know the processor will work with the motherboard?
Jul 22, 2009 | Computers & Internet
What is 'd Maximum PhysicalMemory 4 WinXP? How can i speed up 3DMAX Rendering?
Max speed depends on your M/board, dear. If the slots are empty, double what you have for a start. WIn XP doesn't care. You can go past 1 Gig.
Check Bios and open up you AGP or PCI apature to maximum allowed.
Also set your shared memory for VGA to 128 MB or more.
For your processor, be careful. Factory settings come with processor settings preset. Check BIOS first, see what it's set at and compare with listed processor speed for your machine. If they match, leave them alone; work on RAM.
Feb 17, 2008 | Computers & Internet
Upgradation
the maximum upgrade for its processor is Pentium III.
go to www.dotstation.info for more details
Feb 04, 2008 | Intel Dot Station (INTC300AIO) PC Desktop
Upgrade beyond limits
if you goto this link it will tell you what you can put into your comp you can only put in the maximum it tell you the link is http://www.crucial.com this will scan your computer and tell you everything about it and anything you can put in it.
It will also tell you everythin that is compatible hope this helps you let me know how you get on ok
Nov 29, 2007 | Sony VAIO Digital Studio PCV-RX550 PC...
IBM 89P7663 Motherboard Logo
48 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
