Question about Acer Computers & Internet
VERTICLE LINES ON MONITOR - Acer Computers & Internet
  • 11,361 Answers
You may ahave bad LCD panel, http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
try reseating the ribbon cable first.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on May 23, 2011
Computer will not boot to normal and verticle lines on monitor, dell XPS410, windows vista 32 bit
Unplug the monitor video cable from the computer. Power on the monitor and see if you get the same results. If so then your monitor is defective.
Oct 11, 2012 | Dell Computers & Internet
My screen has verticle lines and the colors are incorrect
Try your monitor on another computer (laptop or desktop), to see if the problem "follows' the monitor.
Try another monitor on your computer, to see if your computer's video-card is creating the problem.
Try a different "data" cable between your computer and your monitor, to ensure that all 3 "primary" colours are being transmitted.
Jul 21, 2010 | Dell Y4694 Dell MOTHERBOARD INSPIRON 9300
I have a Dell computer with a flat screen now all of a sudden there are fine pink verticle lines along the right side of the screen. There is also a group of fine pink verticle lines about 1.5 inches wide...
Try the following steps:
  1. On the monitor, press Menu, and select Factory Reset.
  2. If the monitor has more than one type of connection available such as VGA, DVI, or HDMI, try a different type of connection.
  3. Connect the monitor to another computer. If the line appears when the monitor is connected to the second computer, the monitor might be damaged or defective.Otherwise, the video card and driver is causing the problem from the computer.let me know if this resolves ur issue.. if not then we need some other steps.. regards,guru
May 05, 2010 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
Blue verticle line is displayin
The blue line is most likely the result of your monitor's screen going bad. One thing you can try is disconnecting and re-connecting your video cables to make sure it's tight and has a good connection. This probably won't help, but it's worth a try. You may also want to connect the monitor to another computer to see if the blue line stays, or goes. If the blue line stays with another computer connected, the problem is inside the monitor. If the line goes away, you should replace/repair your computer's video card and/or cable. Otherwise, you need to replace/repair your LG monitor.
Mar 03, 2010 | LG Flatron L1750S 17" LCD Monitor
I have two verticle lines- one white and other one
The screen will likly need to be replaced. Try an external monitor on it, does it still have lines? if not then its the screen on laptop.
Feb 25, 2010 | HP Pavilion zd8000 Notebook
I have verticle line in my monitor and was
This generally means your Monitor or the hardware driver, is going faulty.
Jan 31, 2010 | HP Compaq Presario 2200 Notebook
Monitor displays verticle coloured lines when turned on
As i understood the explanation you have a problem with the Video card not the LG Monitor.
Jun 19, 2009 | LG Flatron W2242P-SF 22" Monitor
Verticle lines on monitor
Hi...there,
Well... I hate to say, but you got a damaged panel. Thinking of replaced the panel... you can forget it.
Get a new one...it's will saved you the headached and $$$... Have a nice day!
Oct 02, 2008 | IBM ThinkVision L170 17" LCD Monitor
Verticle line down the middle of lcd monitor.
This is a common problem with LCD screens. It is pixel line damage and the screen is permanently damaged and is not repairable. It will probably get worse. The only answer is to replace it
Oct 01, 2008 | Toshiba Satellite P30 P35 Series Notebook
Verticle line in the middle of the monitor.
IT'S THE PROBLEM IN THE DISPLAY PANEL GET IT CHECK THROUGH A SERVICEMAN
Oct 01, 2008 | Toshiba Satellite P35-S611 Notebook
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
