Question about Harman Kardon Festival 60 CD Shelf System
The CD player has a problem, it's not working. I brought this to the our reputable technician, the findings is that, we have to replace the lens of ths CD. Where can we find and buy the lens of this CD?
    Sergeant:
  • 250 Answers
First of all, try CLEANING the lens. Try the easiest way first : Run a cleaning disc through it. That may just work. But if not, get a piece of very soft cloth (Tear a piece off your wife's or baby's pyjamas ) and dampen it with Methylated Spirits (sometimes called White Spirits). Wait a minute or two, then wipe it again with another piece of the same cloth, this time dry.
Posted on May 22, 2011
How do I change lens on Bose Wave CD player
You need to buy the correct replacement lens - usually on ebay is a good selection. Keywords - Bose Laser. Email the seller, and ask for help to identify which lens you need.
Then disassemble your machine, and install the new lens.
If that's too complicated for you, have a local technician do the work.
Dec 15, 2014 | Bose & Wave& Music System
Cd changer cannot read cd
Its laser pickup assembly might be faulty. Click here to know more about how to clean it. Do it once, and if it do not help you, replace it with same type and number.
Sep 03, 2012 | Audio Players & Recorders
My Dvd rom can't detect any CD or DVD
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Regards.
Jan 24, 2012 | Compaq Presario CQ40 Series Laptop Charger...
Technika combi unit dvd player wont read discs anymore
Regards.
Jan 12, 2012 | Televison & Video
When I try to listen to the cd's, it won't play them. It tries to acknowledge them but the player won't play them
CD players commonly will not recognize some types of CD, eg MP3 recordings, or maybe CD-RW recordings.
However if this is happening with CDs that would previously play OK, then it could be
- scratched or dirty CD surface
- contaminated laser lens in the player
- laser lens has become misaligned
The last 2 need a service technician, but it may be cheaper to buy a new player.
Nov 19, 2011 | Audio Players & Recorders
Having difficulty locating cd-rw's that will work in my philips cdr765 recorder
I hope you're looking for CD-RW DIGITAL AUDIO blank media. Try eBay.
Jul 06, 2011 | Philips CDR765 2-Disc CD Recorder
When I turn the system on the CD Drawer keeps going in and out repeatedly by itself. When I load a CD it won't recognize it and won't play it and keeps going in and out opening and closing by...
Hello
Check all connections, such as from player to amplifier or receiver and receiver to speaker. Check and clean contacts on RCA jacks and cables and try a different input on the amplifier or receiver.
Clean the lens. Use only a special CD lens cleaner and follow the instructions carefully.
Check the traverse assembly (the metal rod that the laser travels along and the gear that drives it) if CDs aren't recognized or won't play, frequent skipping occurs at random, CDs randomly get stuck in one spot, the player can't find tracks correctly, or cleaning the lens doesn't work. Dust and lint may be interrupting its function.
Have the laser-head assembly checked by a repair person if the traverse assembly seems intact and free of debris.Look for broken plastic parts, such as gears and clips,look for loose or broken internal connections.possibly have gears and belts replaced.
Jun 09, 2011 | Audio Players & Recorders
I have a Fischer DVD player which now gives a NO PLAY message when I insert any DVD. It will, however, play an audio CD. This includes DVDs that at one time played just fine. It seems to me that there must...
If non of the above solves the problem, then know that you need to replace the laser to a brand new one......
Yours sincerely.
Elect_Comp.
May 16, 2011 | Televison & Video
I have a sony xav-622 in a new rv camper. Everything works except the connection to the sony tv on the dvd only plays in black and white. This is connected with a yellow cable with no place to put s...
try cd/dvd cleaning lens kit of your XAV-A1. if still it doesn't work, try opening you XAV-A1 and clean it with a cotton buds with a cleaning solution from the cleaning lens kit. if still it doesn't work, have it change a new lens from a certified technician.
Apr 25, 2011 | Sony XAV-60 Car Video Player
The dvd is not loading and will not play. the cds are working fine.
Regards.
Apr 20, 2011 | Blaupunkt DVD-ME2 Car DVD Player
Harman Kardon Festival 60 CD Shelf System Logo
93 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
