Question about Cycling
Cannot raise seat on Clear Creek Loosened quick release and pulled up but rod doesn't budge. How to raise seat?
    Problem Solver:
  • 3 Answers
Use a pair of channel locks or a pipe wrench tohelp pull the stem up little by little without deforming the head....should work now with quick release adjustment...
Posted on May 22, 2011
Can't raise outboard motor up so I can trailer it
Disconnect Battery! Just For Safety.Try Turning Prop And Engage Forward Gear, Once In Gear Try Lifting Motor!!
Mar 09, 2013 | Boating
Raise seat
where the post beneath the saddle meets the frame, you will find a quick release skewer. pull the part that looks like a tab outwards, it will swing around and outwards, loosening the seat post. you should now be able to twist and raise the seat post, then flip the tab back down.
Oct 29, 2012 | Huffy 26 in. Cranbrook Cruiser Bike
Passenger seat won't lock in place
The adjusting lever for seat position is not locking into place. On the bottom of seat are runners on each side with holes in them that the adjusting lever tabs will lock in and hold seat in place. The seat slides on the runners if those tabs are raised. There is also a connecting wire or rod from the lever to the other side of seat so when lever is pulled up, tabs on both runners are raised for seat to slide. Something is keeping the tabs from locking into the holes on the runners in your car. Maybe the adjusting lever is broken somewhere, or the wire/rod came loose, or the lever is just dry and sticky and needs a shot of WD40 to loosen it up. If you can't see it and fix it with seat in place, then pull the seat back off for the repair. Good luck. Post back if my explanatiopn is not clear or you still need help.
Jun 19, 2012 | 1998 BMW Z3 Roadster
Drivers seat is stuck in farthest back position and will not slide forward.
Check under the seat where the guide rails are and look tovsee if the wire underneath is pulling to release both sides of the seat on the rails or one side. If it's not releasing both sides you have to check to make sure there is nothing stuck in the guide rails (coins perhaps). If all is clear you'll have to adjust the rod or cable that attaches to the lever of the seat to make it release both sides so the seat unlocks and moves easily.
Feb 21, 2012 | 2011 Mini Cooper
I want to raise my handle bars just a bit have unscrewed everything and still won't budge
There is a bolt at the top of the stem (the part that fits in to the fork and clamps around the handle bars) which is the only thing you need to loosen to raise the handlebars.
It should only need to be loosened 2 or so full rotations. (If you have loosened it a lot, tighten it back up a bit.) The secret is that you need to bop that bolt with a mallet. (The stem is held in place by 2 wedges- they jam together to make the connection secure. Sometimes they get a little stuck.)
If that doesn't work, try loosening the bolt another turn and bopping it harder.
(Make sure that you don't raise the stem up any higher than the "insertion point"- the series of lines on the stem to mark it's maximum height. And make sure that you don't damage the bolt from hitting it too hard.)
If that doesn't work- I'd recommend taking it to a shop. They shouldn't charge to much for the adjustment... all the shop's I've worked at would do it either for free or for under $10.
Sep 25, 2011 | Huffy 26 in. Cranbrook Cruiser Bike
I'm trying to change my rear tire , i have put the chain in the smallest cog in the rear, loosened the quick release but the tire doesn't want to come out. Do you have to do something with the...
If the quick release is truly loose, from the rear just lift the bike by the left side of the seatstay (or what would be a seatstay if itwasn't rear suspended) and rotate the rear derailleur backward with your right hand. It should just fall out.
Google "remove rear wheel bicycle" for lots of advice in video form.
May 20, 2011 | Cannondale Jekyll 800
Replacing original seat for Clear Creek with Noseless saddle seat. Hoe to?
All you need to do is match the seat post clamp to the seat rails. 99% of seats are compatible with modern days seat posts. If yours doesn't fit, get the adjuster.
May 19, 2011 | Schwinn Cycling
This hasn't been used in a long time and I'm trying to change the bit/head. Even with the Collet nut loosened, the bit that's in there will not budge. I even took the Collet nut right off to...
Is it possible to grip each part with a pliers and twist and pull at the same time to release the bit? Let some oil run into the collet before you do this.
May 12, 2011 | Craftsman 2.0 amp Rotary Tool Kit
1998 Toyota 4 runner - Cannot raise seat to get tire tools
In the middle of the seat itself, there will be a loop you can pull and the actuall seat part will flip up
May 10, 2009 | 1998 Toyota 4Runner
Rear seat won't come back up
I had the same thing happen! Pushed all the way down the rear back locks, to unlock push the lever in and press DOWN on the seat to release the lock.
I had to check my manual, I tried to lift it 'case it made sense but nope - you have to press down while pushing the lever.
Jan 04, 2009 | 1993 Ford Taurus
Cycling Logo
74 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
