Question about Zebra Z4M Printer
Print Graphic by coding program to Zebra printer
Dear Expert
Normally I used ZPL command ^GF to print graphic but my problem is I must prepare grahpic to bitmap format.
Is it posible I can print other graphic format such as jpeg? Or the other command instead of ZPL to control printer Zebra?
Thank you in advance
rph@ecco.com
    Problem Solver:
  • 17 Answers
No u cant use jpeg... u can use .bmp "Monochrome Bitmap (*.bmp,*.dlib)"
Posted on Mar 20, 2009
Hi Dear All, My printer is not printing ZPL
Only Zebra printers use and print ZPL. ZPL =Zebra Programming Language. Other printers cannot intrepret ZPL.
Aug 13, 2013 | Zebra RW220 PRINTER 2" DT RUGGED MOBILE...
Ido not have any problem if I print label using Zebra. I wrote codes on Visual Basic 6 to print label using Datamax printer conneccted parallel port with command L to start. The printer printed the text...
Do you have Zebra emulation firmware installed? If not, your printer will not understand the command language that you are sending to it. Datamax has its own language and you will need a branch in your code to support that if the printer does not work with ZPL.
Jan 14, 2010 | Datamax Prodigy Plus Thermal Printer
How to print logo in zebra printer
you be abel to print the logo in ASCII code, and send some ZPL commands to the printer, like a file.
Dec 14, 2009 | Zebra Z4M Printer
Hi. I Recently inherited a Zebra 140 XiII(2) and I cannot set the print speed as the option doesn't show on the LCD menu or when I print out the printer config settings. Any help would be appreciated.
Print speeds on the Zebra xiII series printers are set via software. There is no printer menu speed setting on the xiII series. Zebra didn't allow speed adjusts thru the front panel menu until they made the xiIII series printers... The ZPL code command for print speed is "^PR"
Jul 16, 2009 | Zebra 140Xi II Thermal Printer
How to print to zebra tlp 2844 using vb6 through usb port
You need to use a printer driver or use ZPL commands to print.
Jun 23, 2009 | Zebra TLP 2844-Z Thermal Label Printer
HOW TO PRINT LABELS IN DATAMAX PRODIGY PLUS PRINTER USING VB.NET
Tu necesitas utilizar comandos DPL. Pero si vas a utilizar graficos o windows true type fonts, tu necesitas un cartucho de memoria ram o flash. You need to use DPL commands. But if you use graphics or windows true type fonts, you need a RAM or flash cartridge.
Apr 06, 2009 | Datamax Prodigy Plus Thermal Printer
Read and print .DAT files on labels
you must embed ZPL/CPCL or EPL command to your program.. or use Zebra Designer Pro then connect the .DAT file to it and design your sticker..
Mar 20, 2009 | Zebra 105SL Thermal Label Printer
Zebra Z4M Communication
Yasemin, the most practical solution is to design your label on a software like a label matrix or zebra designer and print to a file and have the ZPL codes. Roberto Martinez Mexico bartech9@yahoo.com.mx
Feb 27, 2009 | Zebra Z4M Printer
I have Thermal Zebra Printer TLP2824, I have installed it and
The printer has firmware TLP2844-Z Zebra. This printer uses ZPL commands and not epl. ZebraDesigner can print to a file and have a format command.
Jan 08, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Can we use any commaon laguage for all Zebra printer.
Can you explain what is is you are trying to print on the label?
May 22, 2008 | Zebra LP 2844 Thermal Printer
Zebra Z4M Printer Logo
1,369 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
