Question about Freecom Office Equipment & Supplies
Hi there i have a freecom 1T external hard drive, i have plugged it into my laptop, and a message comes up saying that the device has malfunctioned and that windows does not recognise it, code 43, can u help me out? would b much appreciated i just want to use my external
  • 72 Answers
Code 43 refers to a driver installation error with Windows. If you go to their support website here: Click Here, you can select your exact model hard drive from the drop down menu, download the drivers that correspond to whichever version of Windows you have, and follow the on screen instructions from there.
Hope this helps. If it does, please accept and rate the solution! Contact me with any more questions you may have. Thanks for using FixYa!
Posted on May 22, 2011
  • 4,281 Answers
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa.
Freecom usb port broken away from circuit board inside enclosure
It is hard to buy replacement for the same enclosure, but there are many USB2.0/3.0 enclosures available on the market for 2.5 and 3.5 inch drives.
Make sure read reviews for issues and performance on those enclosures.
Apr 10, 2014 | Freecom Xs External Usb Hard Drive 2tb
Hi I am running Window Me and my freecom external won't work
unplug its usb cable and plug it into a different usb port
Mar 30, 2010 | Computers & Internet
I have an external freecom 400gb hard drive
The chances are that you would have burnt the Power IC's, so there might not be any damage to the Hard Disk itself. you culd try buying a cheap External Enclosure at the closest IT store or moun the Hard drive on to a desktop computer. you should be able to retrive the data.
Mar 25, 2010 | Computers & Internet
Freecom Hardrive "Malfunction"
Not necessarily your information (data) was lost. The freecom hard drive might have some problems installing itself or some connection issues. I would take it to a data recovery technician. Of course there is always a 50 50 chance that you lost it or not. Wish you the best, Good luck
Dec 31, 2009 | Computers & Internet
Verbatim 1tb external hard drive malfunction error message
Try changing the USB cable that connects the hard disk to the computer, this message usually comes when the cable is damaged.
Dec 14, 2009 | Computers & Internet
My freecom 1T exrternal HD does not connect and has burn smell
First of all make sure that the USB port that you are using to connect it to your PC is a USB 2.0 port, and not USB 1.0.
Also if it came with an external power, connect it to the external power before putting on your PC.
This is because the voltage supplied by USB 1.0 is lower than that of USB 2.0 and therefore might not be enough to power up your USB Drive.
After making sure about this, power up your system, and plug the external drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your external drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your external Drive to be detected automatically.
Or in case there is a problem with the read/write head inside the hard drive.
What I would advise you to do is, unscrew the hard drive case and remove the Hard disk from the case, connect it directly to a system, not externally or through USB this time around, then get a software called NTFS DOS Professional. It is a software that works like magic when it comes to hard drive repairs.
If you know any other hard drive utility, apart from this, you can also use it. I just recommend this personally because that is what I use.
Insert it into your PC, start up your CD-ROM and let your system boot from CD-ROM.
It works through DOS, and it should be able to help you with it.
If this does not solve the problem, then I'm afraid you might need to replace the hard drive.
And if it repairs it, I would suggest that you just retrieve all your valuable files from it and don't fully rely on the hard drive again because of the hardware error it has developed. Just keep using it as a second.
If you cannot do this by yourself, just get a very good technician to do it for you instead.
Kindly keep me posted about the problem.
Hope it helps.
Goodluck.
Nov 25, 2009 | Computers & Internet
WD External Hard Drive malfunctioned & is not recognized
you can **** in western digital factory with this ugly hard drive
Dec 24, 2008 | Western Digital My Book (WDG1U2500)...
Freecom 400 GB external hard drive not being read by computer an re-installing Freecom Personal suite. When I turn on the external hard drove the power light comes on ( and stays on) and the drive itself...
hi there,
sounds like you have a hardware problem...you should look into trying this drive on another system to see if the same thing is happening without the drive software ...and if it works try to recover all your data from this drive as soon as possible...hardware problems are most time intermittent ... so they work now then say after a while they stop...
Apr 13, 2008 | Computers & Internet
Freecom hard drive problem?
Unless you "GHOST" or "CLONE" the programsd over to the harddrive, instead of just copy and paste, they will not open. What you will have to do mo0re than likely is remove the installation files through control panel and reinstall the program onto the external harddrive.
Mar 23, 2008 | Computers & Internet
Freecom 250 Gb Hard Drive
Hi des,
you need to install windows XP, on a different hard-drive.
even if it,s only 10 gig plus.
You can then access the drive.
Your problem is here, is that you,ve upgraded from XP to Vista, theres a possibility, that you may have lost or even formatted your freecom hard-drive.
No-Support-Device detected, is saying that your USB devices are not functioning correctly.
Check in the bios that the USB devices are enabled, to operate your hard-drive. ( this is assuming it,s a USB drive )
Hope this helps you out.
Mike @ compurepair.
Mar 11, 2008 | Computers & Internet
99 people viewed this question
Top Freecom Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Freecom Office Equipment and Supply Expert? Answer questions, earn points and help others
