Question about Michael Kors Chronograph Watch MK5188 Watch for Women
My watch is not working!!!!! is brand new...i do not know if im doing soemtihing wrong>>>
Tip
How to exchange leather straps for almost any watch brand
Most of the people are pretty sure that when their watch leather straps are worn out they have to replace them with new ones, made by exactly the same brand as their watch brand is. This is completely wrong. About 95% of all watch brand models can be fitted with leather straps from any watch strap producer without loosing brands identity. All you have to do is: 1. Release the strap from the watch; 2. Measure the width of the strap where the spring bar (pin) goes through and write it down or memorize it; 3. Undo the buckle/clasp; 4. Measure the width of strap in place where the buckle/clasp was fitted and write it down or memorize it; 5. Measure the length of the strap (both parts together) and write it down or memorize it. Now you have everything you need for strap replacement. Visit any shop selling leather straps or even find it on the internet. You will find thousands of different colours, patterns and leather variations. The choice is yours. Just one thing to remember: The strap you are buying must match all the measurements you took of your original strap. This is not difficult to match, as the watch straps usually are made to global standards. When you have your new strap delivered, just fit it to your watch and undo the buckle/clasp that came with it. Fit your old, original buckle/clasp on to the new strap and you are done. Most watch manufacturers impress, engrave or laser engrave their logos on buckles/clasps, not on the leather straps itself. So, when you fit the original buckle/clasp on brand new strap of different make, it becomes the original strap of the watch you own. And nobody knows that the strap is, for example, from Hong Kong, but watch is from Switzerland (except you, of course} as they look together as one nicely designed piece and the buckle/clasp works as the proof of identity. In case if your watch has some unusually shaped fixing for the strap, this shape can be easily cut in to the strap by modellers scalpel. At the very end I just want to remind to all readers: Watch straps sold under watch brand names are 2-10 times more expensive. In fact - they are not produced by watch manufacturers themselves, but in Italy, Germany, China and Hong Kong and then sent to watch manufacturers. Just because these straps were fitted to the watches and the buckles or clasps were added to them, these straps automatically becomes their brand straps and cost a lot, lot more. Hope it helps to save your hard earned money.
on Jan 10, 2010 | Watches
The time is wrong on my watch. I'd like to know how i can set the correct time on it.
Victor, what is the brand and what type of watch is it- digital or mechanical etc.
Nov 30, 2014 | Watches
The time is wrong on my watch. how do i set the time?
We can't be much help without knowing the brand of watch.
Nov 29, 2014 | Watches
I have a ladies Fossil watch #AM4168. The battery went bad on it and when I changed it out with a brand new battery and the second hand won't move. I took the battery out thinking I was sold a bad battery...
It is a common logic problem. The watch stopped working. You assumed it was the battery; hence your assumption was wrong. Therefore the obvious answer is that the watch broke and that a battery would not help unbreak it.
Oct 21, 2013 | Fossil Sport Collection watch #AM4168...
My watch wont run
sometimes when u buy a new watch they have it turned on for display try getting a new battery.
Jul 26, 2012 | Invicta Diver Watches
New battery inserted.digital part of watch shows correct time.clockfave shows different time.also the 2 buttons on the side when pressed in do not come out again
First, take the back off the watch and make sure that the movement is inserted correctly. When buttons dont come back out it is usually the movement in the case wrong or the back is put back on wrong. If it is a pop off back then you want to be sure the dimples in the back are over the stem and crown and buttons so they move freely. Also, be sure that any springs that were in place are still in place.
Now i dont know what brand or model of watch this is but most digital analogs have a stem and crown to set the analog. Pull out the stem to the first position and set the time.
For specific instructions please leave the brand and model.
Thanks!
Sep 19, 2009 | Watches
I need a sector watch expert.
There are no bad motions for watches - they are designed to withstand all motions, except very hard knok/hit.
You do not need a Sector watch expert, as all watch brands use movements made by few manufacturers and all decent watchmakers know them from A to Z. Only very expensive watch manufacturers produce their own in-house movements - Sector is not in that league.
Contact that shop and ask for full explanation what and why went wrong.
Rate me, please.
Aug 11, 2009 | Watches
Reymond weil ladies watch automatic
hi guys heres my pic ty not very clear644ef545-133c-4e4c-823f-750b9fd2175a.jpg
Jun 11, 2008 | Watches
Michael Kors Chronograph Watch MK5188 Watch for Women Logo
291 people viewed this question
Top Michael Kors Watches Experts
Ansel Alberto
Ansel Alberto
ray gallant
Are you a Michael Kors Watch Expert? Answer questions, earn points and help others
