Question about BOSS AUDIO SYSTEMS BV9980RDS Car DVD Player
BOSS BV9980 ATTENTION YOU CAN NOT USE THIS FUNCTION WHILE DRIVING
How to connect an expression pedal to a Boss gt-3
Just plug FS-5U or FS-5L or EV5 / FV300L (Roland),or other external switch to SUB EXP PEDAL.
You can also use pedal switch that you create by yourself.
Use stereo phone jack and cable.
It can be function for 1 or 2 switch.
Setting function for SUB-EXP-PEDAL is at UTILITY-GLOBAL menu.
You can set switch 1 or 2 for what do you want to function each switch at the external pedal.
If you want to connecting external expression pedal (FV300L),just plug it to SUB-EXP-PEDAL. Setting is same as above.
Aug 31, 2015 | Boss Music
Toyota fault code P0446
The definition of fault code P0446 is the carbon canister ventilation function failure, this problem does not affect driving performance of engine driven, but due to the fault will cause ECU to trigger fault light, we also should handle. Especially in the automotive emission control is being paid more and more attention today, we should master the principles of automobile emissions control system and diagnosis method of repair, the repair of the vehicle can keep the original vehicle emission control function.
source: obd2 tools auto scanner key programmer
Dec 21, 2013 | Cars & Trucks
Boss radio bv8966b is not reading the music cd keeps saying no disc
Did you try to wire it so that you could watch it while you are driving?
Apr 12, 2011 | Boss Car Audio & Video
When I insert a DVD, such as "Due Date"; even while my car is off and parked. The screen displays a message saying "ATTENTION You can not use this function while driving. Although I can hear...
the unit will have wires that need to connect to your foot brake, and parking brake. Its the law in the state I live (Alaska) that professional installation requires the dealer to install the wires to the foot and parking brake. There is usually a sequence to getting the picture up. (like holding down foot brake while applying parking break) then the message will disappear.
I simply bypassed this by connecting the two wires to the AUX (usually red wire) so there was a 12 volt draw. added two switches inline to act as the brake sensors.
Feb 28, 2011 | Boss BV7965 Car Video Player
Video will not play. I get the message: Attention can not use this function while driving. My car is not even running and I have this message. Please advise on what could be the issue. Thank you for...
there is a wire (pink i believe) that is labeled emergency brake. If connected to the e-brake it sends a ground when the e-brake is engaged that enables video. This is to ensure that you are not driving (are in park) while watching video. To work around this, simply take the pink wire and ground it out. You can do this by attaching it to the chasis or by splicing it in to the ground wire (I believe it was black, but double check before doing any splicing).
good luck with your player!
Jan 05, 2011 | BOSS AUDIO SYSTEMS BV9565BI Car Video...
Siren came on while driving the car and could not 1997 saturn sl
pay attention at the time that this is happening because I guess your alarm is in anti-car jack mode so if the car is in running mode and them suddenly you open any door. This function will activate after usually 30 sec. or less. the only way to fix this is deactivating this function at the program mode of your allarm.
Jun 02, 2010 | Vehicle Parts & Accessories
Boss DD3 - LED switches ON but the signal remains dry.
Have you tried a new battery?
If you have experience with electronics then open it up and start testing all the components with a digital multimeter to find the failed component(s).
Unfortunately the newer DD3's are harder to fix then they once were. There is no place to point you other than just to start testing everything. Hard to say what has failed. The signal into the input of the circuit may simply be shorting to the output. Maybe the switch or switching circuit has a fault.
Here is the schematic as a reference: http://www.8bitsindgenug.net/boss_dd2.png
Dec 29, 2009 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
Bypass parking brake wire
Boss Audio is the easiest in-dash DVD on the market to bypass; all you do is ground the ebrake wire. I recently installed 12 Boss Audio in-dash BV-7300's and did this to all of the decks problem solved. By the way I did this because they were in the back of limousines where the driver couldn't ever even see one of them while he was driving. I don't think there will be a problem, try it.
May 20, 2008 | Boss DVD-7500 Car DVD Player
BOSS AUDIO SYSTEMS BV9980RDS Car DVD Player Logo
383 people viewed this question
Top BOSS AUDIO SYSTEMS Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Kazim ERGUNEY
Kazim ERGUNEY
Jerry Umali
Are you a BOSS AUDIO SYSTEMS Car Audio and Video Expert? Answer questions, earn points and help others
