I have a Rowe Cd100 Jukebox and I'm getting the CheckSum Error BE00. It states that the Ram Test Passed. I did replace the Central Computer unit and I'm still getting the errors. It lights up "Board Error" and it's like the speakers make a funny sound when this error lights up. Does anyone have any advice? Thanks.
SOURCE: problem with 'central' speaker output
took apart my reciever and found that the blue relays in back in the middle are starting to malfunction. I tapped on them and they clicked. When I tapped the right one, i got the sound back in my center speaker.
Posted on Dec 07, 2007
SOURCE: CMOS Error
If your CMOS batt is ok, then try flashing your BIOS
Posted on Feb 08, 2008
robotek
  • 1512 Answers
SOURCE: Kenwood Amp blinking Standby indicator light
Hi fuxsiloh.
It sounds like you have eliminated all the things that could generate this symptom that are external to the amp. It is most likely that there is an internal problem that is causing the amp to go to protection mode. A power supply failure(maybe a fuse) is the only really user serviceable part inside the amp. Perhaps check for failed fuses, replacing any that may have blown with exactly the same type. BE SURE TO UNPLUG AT THE WALL FIRST:)
Is the amp still under warranty? If so, then returning it to a Kenwood service center is the shot. If you want to have a go at repairing it, I can talk you through it, but some experience with this sort of thing is very necessary. Good luck
regards
Graeme
Posted on Apr 06, 2008
  • 41 Answers
SOURCE: CMOS Error
Are the CMOS batteries good?
Posted on Oct 15, 2008
SOURCE: Panasonic error code
Take the case off and clean out the fan, it worked for me, it was the protection circiut kicking in to prevent the amp from blowing.
Posted on Feb 18, 2009
I have a R 93 ami jukebox and keep haveing error codes 1and4 what do they mean
Error 4 means the memory backup battery inside the Central Control Computer is dead or very low. Error 1 means factory defaults are being loaded due to a dead battery.
Jun 15, 2014 | Wurlitzer Jukebox CD Player
How to fix rowe R89 jukebox error 4
Error 4 means the battery for the memory is too low or is dead. This battery is located inside the Central Control Computer.
May 18, 2013 | Wurlitzer Jukebox CD Player
Rowe CD100A Jukebox CD carousel keeps turning.
if you got the service manual with it, it will tell you how to pull up the error codes and what to check.....I got lucky cause I just bought one and it had the manuals in it...mines is a rowe ami cd-100c. ....I just googled ur model and a pdf manual pop up for downloading. ...hope that helps!!!!
Mar 14, 2013 | Audio Players & Recorders
I have a Rowe ami R92 jukebox, when I turn it on I get error 37
Did you ever get an answer to you question on the error 37 for the Rowe R92 Jukebox
Peter
Rowe R-92 Jukebox
Dec 09, 2012 | Audio Players & Recorders
I have rowe ami jukebox Eagle Laser Star and its amp seems to be dead sin have no sound justa a buzz. Need to find one or how to repair it.
CALL AB JUKEBOX SERVICE--ASK FOR BRUCE--TELL HIM LES FROM RMC VENDING SUGGESTED YOU CALL HIM.-
603-382-6272
Apr 27, 2009 | Wurlitzer Jukebox CD Player
Rowe AMI CD100 RAM Error
try this turn the box off , hold down the 0 and the 1 selection button
at the same time turn the box on. that reloads the prom to the ram
Apr 01, 2009 | Audio Players & Recorders
CD palyer will not play all Songs
It sounds like the CD has to be initialized, so the jukebox knows how many songs are on the specific CD.
To initialize a CD, go into service mode, input code 31, then index the cd number (two digits), then hit "popular". return the jukebox to play mode.
The carousel should scan and load the CD you initialized, and then return it to it's slot.
It should now be able to play any song on the CD you select.
Mar 05, 2009 | Wurlitzer Jukebox CD Player
Does not hold memory of programmed options
I do not know what type of jukebox you have but the the battery will be in the Central Control Computer, this is the case with the Rowe Ami version of your jukebox. It is a 3 volt lithium (disk type) battery.
Regards
Alan Hood
ami-man
UK
Nov 29, 2008 | Wurlitzer Jukebox 1015 One More Time...
Rowe jukebox
I take it that the jukebox accepts selections when you type them in. Also that you have tried selecting the A side and the B side records.
Is the switch on the CCC (Central Control Computer) set to Record it should not be set to Video.
Rowe Ami jukeboxes are very pone to dry (cold in the USA) joints.
If you can solder then the following items need to checked for dry joints.
Power Supply PCB (printed circuit board)
CCC
Mechanism Control Board
When taking out the plugs pull on the plugs (not the wires)
Look on the soldered side where the connectors pins are fitted for any cracking around the soldered joint ( this is the sign of a dry joint).
Resolder any suspect joints on all of the boards and refit into the jukebox and test.
If this does not cure the problem then the boards will be needed to be sent to a Rowe Ami specalist, I am one of these in the UK.
Regards
Alan Hood
ami-man
UK
May 30, 2008 | Wurlitzer Jukebox 1015 One More Time...
157 people viewed this question
 Grubhead
Grubhead
