Question about Panasonic PT-52LCX65 44" HDTV
PT-445CX65 PLEASE HELP ME CAN'T FIND THE BOOK SINCE HURRICANE KATRINA AND THE TV KEEPS GOING OFF AND SAYS REPLACE FILTER. WE DON'T EVEN KNOW WHERE IS THE FILTER. PLEASE HELP THANKS  JUDY
  • 927 Answers
Good Day, There is a device that can be used to correct your concerns. Symptoms can be correct by EE PROM CORRECTION TOOL:
LSUQ0100. Instructions included. Try calling 1-800-458-6053. It's under $100.00 and takes about 1 hour from start to finish. Good Luck, big IRISH.
Posted on Sep 09, 2008
Hurricane names
Mitch (1998), Katrina (2005), Wilma (2005), Ike (2008), Gustav (2008), Irene (2011), Jova (2011), Matthew (2016), Hermine (2016), Otto (2016), Irma (2017)
Sep 13, 2017 | Miscellaneous
I own a 5700 watt McCulloch generator. Bought for Hurricane Katrina. Ran perfect , changed oil & used fresh gas regularly. Crank every couple months to keep gaskets from dry rot. When I cranked it...
Most likely the protective circuit breaker has tripped. It doesn't look like the circuit breakers in your house wiring panel -- it is often just a small button that you must press to reset. It can trip easily from a surge when you first plug in an appliance (especially one with a motor), but if it keeps tripping with nothing plugged in, then you have a short in the generator wiring. Good luck!
Aug 17, 2010 | Garden
My washer is one that was used in Fema trailers during Hurricane Katrina. Water is leaking badly out of it. I need to replace the main seal, but I cannot figure out how to get the agitator off. Can you...
the agitator is a simple thing to remove although the threads rust and might need a little help there should be what looks like an finger grip at the top of it and it should turn anticlockwise to undo as i say it might need a little help.adrian,,,
Aug 11, 2010 | Whirlpool GSX97509 Top Load Washer
How do I clean air filter on the Panasonic PT-50LCX64?
I feel bad for you having such problems with the vendor and the technician too.
The location of that filter could be a small window in the back cover itself. could be a plastic window to the left side of the unit and is only a piece of plastic poliuretane kind of black sponge about 5 by 3 inches size .
What im interested telling you about the shut down condition and is maybe even most important than where is the air filter (who is one of the more than ten posibilities why the tv goes to shut down.
Note:
if the air filter is totally obstructed i would give one of ten probabities of suspicious why the tv shuts down:
first because the tv's air duct is not really isolated. The fan can eat air by any side of the air filter base as i said if the filter is totally obstructing which is really extreme. besides maybe the other 2 fans could help to cool down the unit in that case scenario. In my experience Most time the air filter holds tons of dust but is not totally obstructing the air passing, and really some other problems are in the set.
This is the really critical to know: if any of those fans stopped or maybe any sensor is overheated or the lamp is coming to dead or who knows.. a diagnosis is needed for this symptom really common in DLP technology.
Apr 18, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Truck wont restart when it's ran for greater than 5 min.
Will it restart warm if you hold the accelerator to the floor?
Apr 02, 2009 | 2000 Ford Ranger SuperCab
Need operating manual for 6250
Their should be a twist value on the bottom of the gas tank.( were the fuel hose attaches.
Sep 13, 2008 | Coleman Powermate Premium Plus 6250W...
TV Image not bright enough
leagreen
I'm not sure if my answer will help much, but it is free. My experieence with this site is that without paying for premium service, you won't get much help.
I had a similar problem with a different model Panasonic projection set.I got no answer on this site, but I did from an outside repairman.
Turn your color all the way down. If it looks black and white it is probably not a bulb problem. If you see a tint (blue, green, red) over the screen, it probably is a weak bulb.
The entire bottom front of my model was held on by velco and could be pulled off.
Behind this was a removable black panel. Behind this were adjustment screws for the three bulbs. This will probably only help temporarily if the bulbs continue to weaken, but it might buy you some time as the replacement bulbs are quite expensive. Good Luck
Oct 29, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Flooded in Katrina
Try hotairing (set 4 to 5, medium airblow)the main board, check also the mechanical connection or terminals ( I assumed you already did that).
Aug 31, 2007 | Sony Handycam DCR-TRV240 Digital Camcorder
Power surge
If your not a technician with tv repair experience, I would HIGHLY advise against that as theres high voltage in these sets even if they have been unplugged for awhile. Enough to kill ya. First thing though that comes to mind would be the STR##### regulator IC in the main power supply. That usually goes bad when a surge happens. But call a pro, Bro. Good Luck
Jun 08, 2006 | Toshiba TZ50V51 50" Rear Projection...
Panasonic PT-52LCX65 44" HDTV Logo
91 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
