Question about Nokia N95 Cellular Phone
Changing casing hey i just purchased a new casing for my n95 was wondering how to pull apart and change casings over. thanks
  • 48 Answers
You need t6 screw driver to open all screw before you can open housing
Posted on Aug 15, 2008
I managed to pull apart the bobbin case. I found the spring, but can't figure out where it goes. I know I need it for tension on the piece that I have to pull forward to get the case in place.
Would suggest simply purchasing a new bobbin case. Trying to reinstall a spring that is probably distorted will cost you more in time and frustration than the price of a new one. Plus the new bobbin case will have the tension preset from the factory. Pop it in your machine and sew...
Nov 13, 2017 | Sewing Machines
How do I replace or repair the hole that the AC cord is plugged into on my laptop?
Have to take laptop apart, pull connector out of bottom section of case, could connect it with jack hanging out of laptop or you must purchase a new bottom case and have the way its suppose to be.
Jul 04, 2015 | Toshiba Satellite P775-S7320
Hey, i have a nokia n 95 8gb, i have just changed the housing cover on it and now when i call anyone they cannot hear me, can you help?? many thanks adam x
It sounds like the new cover is not original and may be covering the microphone of your phone,
one solution would be to take the cover off, check where the mic is on your phone and pierce a hole on the cover and put it back,
another solution would be to get an original cover,
Good Luck
Aug 04, 2010 | Nokia N95 Cellular Phone
WHEN I DIAL A NUMBER I CANT HEAR ANYTHING UNLESS I SWITCH TO LOUD SPEEKER MODE ON A NOKIA N95
This happens when you change the case. If you look at your new case and compare it to your old one you will see a square module just the other side of the mesh microphone area. You have to remove this very carefully from your old case (clear screen) and put it into your new cover!
Jan 19, 2010 | Nokia N95 Cellular Phone
My nokia n95 wont call at all not even to see my balance just says call not allowed, the sim is brand new but phone is second hand so wonder if its blocked?
Your phone probably has call restriction enabled. If it is the case, find security settings in your phone settings menu, disable call restrictions by entering phone lock code. This phone lock code is 12345 by default, if changed & u dont know, you need to take it to nearest nokia service center to reset it to default. I hope this helps...
Dec 13, 2009 | Nokia N95 Cellular Phone
N95
hi friend,
go to website
www.sparepartsformobiles.co.uk/mobile_phone_spare_parts.asp?...%20ribbon%20with%20keypad...
Then consider changing the Flexi PCB (ribbon). This is a common failure as the ribbon can suffer wear as the phone slider opens and shuts. Eventually the ribbons become worn and often this results in a screen failure. Changing the ribbon can cure this in most cases... We advise that a new ribbon is added when the screen is changed it’s a good way to service this type of part. So if you do have a screen problem including a screen failure then consider changing this part before you spend good money on a screen.
thank u for using fixya
regards,
sivaranjini
Aug 11, 2009 | Nokia N95 Cellular Phone
I just purchase a Singer 301 and cant get the bobbin case out
Raise the bed extension, revealing the bobbin area. Gently pull out on the bobbin case latch and it should pop right out in your hand. Congrats on your 301, they are wonderful machines!
Jun 08, 2009 | Singer Quantum XL-1000 Computerized Sewing...
Changing casing
Check this link here. Follow instructions and download the videos, this will help you to replace the casing on your Nokia.
Aug 15, 2008 | Nokia N95 Cellular Phone
N95 china mobile sim card problem
hte thing is...ur phone is handset bundled offer phone..so til the validity ends on ur new sim card..the phone is designed to detect only new sim..so ucant change til validity ends...or u may approach any private local mobile repair shop..i wont cost u much..
ne other prob's do tell me..N plz plz do rate me
cya
Apr 24, 2008 | Nokia N95 Cellular Phone
N95 keeps connecting to the net
That used to happen to me, however it was more user error!
This may not be true in your case however i'll explain anyway: As i'm sure you know by pressing down or the right command button you open the internet application. This would occur for me when i put the phone in my poket as there is a lag between closing the slide and the keypad locking. I suppose the way to tell is to change those buttons functions and see or check the keypad locks before putting it in your pocket. That is if it has anything to do with that! Hope this is a help anyway.
Apr 20, 2008 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
52 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
