Good Morning, I have an ESE18HRA air conditioner in an investment unit that I purchased recently. Recently the tenants wanted to heat the unit but around 10 minutes after turning the ac on the defrost light came on and it failed to restart after that. The outside temp was not excessively cold. The unit worked fine to cool during summer. What do you suggest? Regards.
  • 35 Answers
That sounds like a safety feature. Better units protect themselves by shutting off if the outside temperature is not warm enough to turn the freon into a gas properly.
Running an A/C in the winter could cause liquid freon and thick oil to go where only gas should be and lock the compressor.
Posted on May 22, 2011
We have an in wall air conditioner. I am not sure of the model #, but recently it has started spraying a fine mist back into the room. I removed the front of the unit this morning and found that the foam...
You could have a pin hole in your refrigeration line. The mist is probably the refrigerant coming out. Check the coil very carefully to see signs af any breaks. You may also have a bad drainage and the water is accumilating inside the unit. The fan blades can throw the water against the filter. Look inside for standing water. Good luck!
Aug 04, 2011 | Fedders A3X05F2A Air Conditioner
Hi i have recently purchased an amcor sPLIT UNIT AND CAN NOT GET THE HEAT TO WORK AND DO YOU HAVER ANY SUGGESTIONS AND PRESUME IT IS A SETTING i AM NOT CORRECTLY PRESSING ? rEGARDS cRAIG
dear sir
please first make turn on your electrical supply for air con
and then use remote controller and find out there heat mode and select it then make your air con on heat mode ..
i hope it will work on heat mode
hope answer the question
thank you
please vote!
Sep 25, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
I just want info on this Maytag M6Q10F2A
it is a 6,000 cooling btu's. check the display controls if you see the word heat then it has heat. ( I'm not been sarcastic)
Dec 16, 2009 | Maytag M6Q10F2A Air Conditioner
No A/C Msg. On Control Unit
Apparently the tenant turned off the unit because he was too cool. I explained that basements are normally cool anyhow but he could close some of the vents.
Aug 17, 2008 | Heating & Cooling
Maytag AC afternoon out to lunch
Clean the condenser coil and change the filter.
May 09, 2008 | Maytag Chassis Built-In Air Conditioner...
Trane Heat Pump
What caused the power outage? Check the outdoor disconnect to the condenser unit. The fuses may have blown, causing the heat pump to not function and depending on the aux. heat to carry the load.
Dec 16, 2007 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
134 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
