Question about Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower
I got oil leaking through the air filter, which resulted in a load of white smoke.
3 Suggested Answers
  • 130 Answers
SOURCE: Oil is leaking from the muffler and white smoke is coming out.
this is more severe.if you are not a small engine person 3 things get a book on mower or take to shop or get a new mower.
not trying to be funny but if you dont know its going to be hard for you to fix the valve guides are bad need to replace will take speical tools to fix.sorry
Posted on Jul 22, 2009
hunter19_46m
  • 7482 Answers
SOURCE: My Troy Built Self propelled
Hi smithjazzy8...
Check your oil level, it sounds like it has got too much oil in the crankcase.
The oil level should be to the last two threads on the fill plug threads of the engine.
This is the main cause of white smoke coming from the exaust of the engine.
Free Answer...Please take time to rate me.
Posted on May 31, 2011
I hamve a suzuki 2006 reno with only 42k mi and it just started blowing white smoke out of the tail pipe and leaking oil out of the bottom of the motor on the passengers side behind crankshift
get it serviced?
if you dont know what oil leaks are or how serious
then get it serviced now,
stop driving it. or burn up a good (hope) engine.
call a tow truck, is best possible end results.
but
open hood, and turn the oil filter CW to tight.
look for road collision damage under car, first.
google how to tighten a filter, oil, see wix filter page, read.
Mar 22, 2017 | 2006 Suzuki Reno
What does the white smoke coming out of the top of the flu on my oil boiler mean
White smoke means steam and that would be caused by a leak in the heat exchanger coil of water in the fuel.
May 02, 2015 | Biasi B-6 Oil Boiler w/ Riello Burner -...
When first started black smoke comes out exhaust pipe,, what could this be
Black smoke is burning oil. Blue smoke is usually transmission fluid due to a leaking modulator valve in the older auto transmission. White smoke is due to water getting in to a cylinder from a bad gasket, cracked block or a cracked head. Black smoke from engines on starting and/or running tends to mean there is fuel leaking into the engine, or the fuel mix is incorrect and not atomised correctly. the main causes are normally a nakered air filter that isnt letting enough clean air into the engine to mix. a blocked fuel filter, which is either not letting enough fuel in, or in some cases, a faulty fuel filter which is letting too much fuel into the engine, and causing black smoke due to excess burning. Black smoke is a fuel/air mixture suggestion problems with injection or carbonation. Cause of black smoke is due to running rich in the fuel air mix. Check the oil,the oil leak,the air filter,the fuel pump and fuel filter to confirm the fault.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Sep 22, 2010 | 1986 Mercury Grand Marquis
I have a 2002 Jeep Grand Cherokee with a 4.7 V-8. It burns oil aprox 1 Qt a week. The driver told me she sees white smoke from the exhaust when the A/C is on. I did not think the problem was related to...
I think, the bearing of the A/C unit jam and putting extra load on the engine or the belt that connects to the engine has dried out. Logically, A/C has no direct connection with the engine exhaust.
Aug 16, 2017 | 2002 Jeep Grand Cherokee
Smoke from engine
Is the smoke white or blue? If white means that you have a leak of water or antifrezze into the combustion chamber. If blue, replace PCV valve, and air filter.
Jul 20, 2009 | 1988 Ford F 350
Oil leaking from air filter area of push mower and mower smoking
You have overfilled the oil tank. White smoke is only a hassle, not a serious problem. You have to empty some of the oil and change the gas. Clean the air filter if it is the spongy type with Dawn Dishwashing Liquid, rinsing and drying it well before reinstalling. The white smoke will stop soon as it is still in the gas that is in the carb. If the case is that you haven't filled it with oil prior to this smoke then you must be mowing on a hillside and the gas tank was on the lower side allowing oil to leak into the gas. Same solution.
Jun 24, 2009 | Poulan Garden
Hard starting smokes white like gas is getting into cylinders
White smoke in a small engine is oil. Oil in the cylinder will create too much pressure for the engine to achieve compression. Make sure the engine is not getting fuel into the oil and thinning the mixture (literally smell the oil... gasoline and oil smell nothing alike, if it smells like gas, it is). If this is the case, the carb is leaking fuel into the engine, thinning the oil and causing the oil to leak past the rings into the cylinder head, through the valves and, from there, into the exhaust to burn off. Black smoke indicates a direct fuel issue in a small engine, white is oil based.
Mar 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Thick white smoke coming from exhaust
White smoke usually associated with water or moisture. it doesn't take too much water to produce white smoke. check
1. cloudy oil under oil cap
2. leak through gasket from cooling jacket to combustion chamber
Oct 08, 2008 | 2000 Nissan Pathfinder
Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc  650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower Logo
169 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
