Question about Kenmore HE2 Plus Front Load Washer
What size is this washer 11047532600 - Kenmore HE2 Plus Front Load Washer
Where does the washer go in the tetra wisper x30 filter go
A size and description of the washer could help. If it is the size of the intake tube then it is for the intake tube. If it is the size of the filter then it is for the filter etc etc.
Nov 12, 2013 | Tetra Whisper Ex45 Aquarium Filter 30-45...
What sizes do flat washers come in?
Flat washers come in many different s and are dividedinto three series: Narrow, Regular, and Wide. For a complete list of s,check out this website: http://www.engineersedge.com/plain_washers.htm
Jul 15, 2012 | Danco Flat Washer 2-1/4"X3/4"X1/8"
My front load kenmore he2plus is showing a f-24 code what does this mean model#11047532600
Hi
Error F-24 means water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F). This is caused by a failed temperature sensor. It can also be caused due to a wiring failure or a failed electronic control board could also cause this fault code. Unplug the washer & remove the kick panel in the front. Use a multimeter to check the resistance of the temperature sensor. To remove the bottom front service panel, take out the screws at the very bottom of the panel and then pull it out and down to remove it from the washer. With the panel removed, you should be able to pull the wires off of the temperature sensor at the bottom front of the washer tub. Measure the resistance across the leads of the temperature sensor. It should read around 10K ohms (10,000 ohms) of resistance at room temperature. If the reading is less than 7500 ohms then you would need to replace the sensor. If the resistance reading of the temperature sensor is fine, then the issue is with wiring failure or a bad control board. Hope this helps... Please post back if you need more information.
Daniel
Jan 01, 2011 | Kenmore HE2 Plus Front Load Washer
How do you select the load size on the Maytag Bravos Top load washer?
This machine is equipped with technology that allows it to sense the load size and will use the appropriate amount of water for that load. Takes the guesswork out!
Apr 21, 2010 | Maytag Bravos MTW6600T Top Load Washer
What is the capacity (Size) of the Speed Queen Marathon Washer?
Pi,r,squared times height. Remember math back when we didn't have computers? So that's 3.14 x radius(half the distance across drum)squared(times itself) times height or depth of drum. Remember to do radius times itself first, then Pi, then height.
Jun 29, 2009 | Speed Queen AWS52NW Top Load Washer
What is my washer's capacity?
able to find a spec sheet on your specific washer, but i can tell you that you have a whirlpool made kenmore washer. and at 18 yrs ago they have only gotten larger, youd be hard pressed (unles you bought a apt sized machine or a laundry center) to get a smaller capacity machine. new machines are huge in comparison to the oldies
Oct 26, 2008 | Washing Machines
Size of washer
Size varies between manufactures, the biggest I have seen is the GE which is 3.5 cu ft, base your machine on your standard size load, ours is about 8lbs however I dont overload, I take large items quilts, comforters etc to a laundromat, its not worth breaking my machine over a comforter wash for $3.50 American.
Go to Sears.com and look @ the washers available
Jun 06, 2008 | Kenmore 22422 Top Load Washer
What is the capaity of 2005 Kenmore Elite Washer and Dryer, models 110?
Starting in early 2002, the capacity sizes were changed around a little bit. A normal sized washer now all have the same sized tubs (pretty much) in the 110 series (Whirlpool Manufactured) washers. The capacity is now rated somewhat by the agitator action the washer comes with. Depending on the type of agitator you have, will determine the capacity. King size capacity means you have a pretty good capacity (size wise) than others. You have normal capacity, large capacity, super capacity, king capacity, and I even think they have canyon (yes canyon) capacity. Capacity sizes dont really mean to much though. In order for you clothes to get clean, the must have room in the tub to move. The must be able to float up, then get pulled down by agitator action. That should determine the size of what goes in the washer. Always use same type clothing when doing laundry (i.e. towels with towels, sheets with sheets, etc, this will keep the load balanced better). Watch what you load, comforters are ok (per manufactures ok) but I do not tlike the idea unless its a front loader, and only by itself. Let me know if this helps you out any.
May 10, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore HE2 Washing Machine Leaking
Have you looked behind the bellow under the folds to make sure there's no rips or tears? The bellow could appear okay on the outside, but still could have a tear somewhere out of plain view. I had this happen to me before.
The inner seal from the bellow to the tub could also be loose now. If you said a garment got stuck and the washer continued through the cycle, this could have loosen the seal where it attaches to the wash tub. You would need to tighten the band clamp around the facing of the tub if this is the case.
A good way in determining where the leak may be coming from is to remove the lower panel under the door. Start a wash cycle and watch to see where the water is coming out.
Now...if the tub seal is loose it may require some disassembly to get to. If you're going to go the route of disassembling the washer front, and have never replaced the bellow before, it probably wouldn't hurt to replace it anyway. My rationale: It's better to disassemble the washer once, rather than possibly having to do it all over again in the near future.
You can get a replacement bellow at searspartsdirect.com. Just type in your model number and look under the "Door and Latch Parts" section for item number 1 (part #8540952). It only costs about $32.
If you need instructions on how to replace the bellow, just go to my profile and look under my "Tips and Tricks". There is a write I posted there giving step-by-step instructions. If you cannot find it, or have any further questions, please post back and let me know. I hope this helps answer some of your questions.
May 04, 2008 | Washing Machines
Kenmore HE2 Plus Front Load Washer Logo
140 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
