Question about Toys
I BOUGHT A LIBERTY JEEP TERRAIN JOGGER STROLLER ABOUT 3 DAYS AGO, TOOK IT ON A TEST TO SIX FLAGS AND HAD A FLAT. HOW DO I FIX THE FLAX. DID NOT SEE WHERE I CAN PUT AIR IN IT. PLEASE HELP!
  • 3,018 Answers
  • There is a place to add air on the inside of the wheel (rim) of the tire. The problem would be will it hold air.
  • First get a tire pressure gauge and check the air in one of the two good tires to get a good pressure on it.
  • I must caution that if you use a compressor to air it up you will blow the tire in about two seconds. So use a standard foot bike tire pump. It airs up on the little valve stem sticking out from the inside of the wheel (see diagram)
  • Should the tire not hold air then you will patch it just like a standard bike tire. Follow these steps.
  1. First put some air in the tire.
  2. Now get some soapy water and splash it liberal on the tire in and note where the air is leaking from.
  3. Put your thumb on the leak and mark the hole clearly with some chalk. Drawing a small circle around the leak works best.
  4. First the nut on the bolt on the side of the wheel has a lock pin that needs to come out. Straiten it with a pair of pliers and then pull it out.
  5. Now remove the nut with a wrench or socket.
  6. now pull the bolt out.
  7. Now the wheel will come out of the fork. Mind the placement of the washers as they need to go back where they are upon reassemble.
  8. Now let all the air out of the tire by pushing on the end of the valve stem and pressing on the tire.
  9. Now take a flat screwdriver and gently wedge it between the wheel and tire and walk the tire off the rim.
  10. Now do the same withe the remaining side until the tire is off the wheel completely.
  11. Now use a standard tire patch and repair the leak.
  12. Now reverse to get the tire back on the wheel and the wheel back on the stroller.
  13. Air tire to proper pressure.
  14. Job complete.
  15. I have also included a picture of where to fill the tire from.
Regards, Tony
Posted on May 22, 2011
I need to replace one of the back tire tubes & trying to find out where to get one for my 2005 jeep liberty stroller.
It looks like yours has the same wheels as mine which are 12.5 x 1.75/2.25 inch. I went to my local bike shop and bought new tubes for all 3 tires. You might even be able to find them at Toys R Us or Walmart or Target type stores. Hope that helps.
Tim
Mar 18, 2012 | Kolcraft Jeep Liberty Limited Urban...
I need replacement brakes for the back tires...any ideas on where to go would be appreciated!!
I suggest you take it to your local bike shop ...usually the smaller the better. They can usually fix any problem pertaining to non motorized vehicles. If they don't have a factory part available they can usually rig something up that works as well or better than the original... hope this helps you can also see my other post about stroller problems and almost all took them to local bike shops with very positive results ...
Apr 20, 2010 | Jeep Liberty Limited Urban Terrain...
Need to replace tires
try to inflate them with a hand pump first. if not you can use fix a flat. It would work perfect. There are no tires for sale for this item. Its all on keeping th emoney flow for the economy. hope this helps. You can find fix a flat at walmart target or any auto repair store
Feb 05, 2010 | Kolcraft Jeep Liberty Limited Urban...
Almost brand new and the tires are going flat. Very frustrated with this stroller.
It would be the tubes are thin. I just replaced mine with tubes from the bike shop. They're thicker. No problems since.
Jan 31, 2010 | Jeep Liberty Limited Urban Terrain...
Where can I buy air pump and tire for my jeep liberty urban terrain stroller.
I believe that this model was manufactured by Hauck UK. If you contact (0)1978 664362
they should be able to point you in the right direction.
I hope this helps.
Sep 11, 2009 | Jeep Liberty Urban Terrain Jogger
Can I put an infant seat in this stroller? If so, how do I do it? My MIL gave us the stroller but we don't have the manual that goes with it. Thanks!
No, this stroller is not built for a car seat. It will shake too much and will not lock properly, causing a safety hazard for the child. Makes a great jogging stroller though.
Aug 04, 2009 | Jeep Liberty Limited Urban Terrain...
Need parent's tray for a 2003 Jeep Liberty Urban Terrain Stroller
need shade cover for front seat on tandem stroller ! also tray for back seat !
Apr 08, 2009 | Kolcraft Jeep Liberty Limited Urban...
Intertubes
You should be able to find a tube at Wal-Mart to fit your tire. We have a Jeep Stroller and Wal-Mart had the right tube.
May 17, 2008 | Jeep Liberty Limited Urban Terrain...
Toys Logo
938 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
