Question about Olympus T100 Digital Camera
My Camera just lost power, the lens is still stuck out, the battery was full when i used it, I also tried plugging in the charger now to see if it will restore power but it hasn't.. What should I do?
    Sergeant:
    Champion:
  • 214 Answers
Hi
usually camera doesn't lose power with lens stuck out, there must be external cause. But you should check first battery which actually is good or not.(using multimeter or to different camera that use same battery.) second with good battery is any light blinks momentarily. If any light blink then cause come from lens most case. But nothing happen then main pcb or power control pcb is the problem. Good luck with you!
Posted on May 22, 2011
Lost charger
Hi
Are you looking for a battery charger or a household power adapter. The battery charger may be specific to the battery used in the camera or you can purchase a Universal Charger that caters for most Lithium Ion batteries.
I would need to know the full camera make and model and if possible the battery part number to assist further.
I hope this was of help.
Nov 26, 2013 | Cameras
I have a kodak Z740. The last time I used it the lens got stuck in the mid way part it did not retract full. after which it just turns off. I guess the batteries get overloaded with a stuck motor. can u...
Good day,
This tip will explain a few methods on how to try and fix your lens if it is stuck or you get a lens error on your screen.
Please note that all these methods are used at the users own risk and that I can not be held responsible for any damages or losses that occur while trying these methods.
1. If your camera is still under warranty, send your camera to the manufacturer to be replaced or fixed professionally.
2. If your camera is out of warranty try these methods.
  • Make sure your batteries are fully charged.
  • Remove the batteries for 10min. Replace the batteries and see if the problem persists.
  • Try compressed air. This method can be useful if there are any sand or any other object stuck in the lens motors. Use compressed air with a fine tip. Direct the air between the camera body and lens and move in a circular motion around the lens to complete a full rotation.
  • You can also try to tap the padded USB cover firmly on a flat surface like a table. This is sometimes a surprisingly effective method.
  • The last method is to try and force the lens. Turn of your camera and place it on its back on a flat surface. Look at the spacing between the lens and the body and see if the gap is consistent all the way around the lens. If the gap is not even it is likely that the camera fell while the lens was extended. Now VERY GENTLY push down on the lens were the gap is the biggest until you her a "click". This will indicate that the lens is back in place. Try powering back on.
  • If the lens does not extend or it extend and retracts turn of the camera. Hold the camera in your one hand and with the other hand turn the one part of the lens in a circular motion. Rotate both sections of the lens until you hear a "click". This will indicate that the lens popped back in place. Power the camera back on.
  • The last method you can use is to turn the lens while powering on the camera until you hear a "click". Power the camera of and back on to see if it works.
If any of the methods listed above failed to work for your lens problem it would be wise to take it on to a professional to get your camera repaired.
Thanks for taking the time to read my tip and feel free to let me know if it was of any help.
Regards
15073327
Jan 25, 2011 | Kodak EasyShare Z740 Digital Camera
My Digital IXUS 120 IS Digital Camera won't open! i tried charging the battery with different chargers including universal chargers just to charge it.. and i still cannot open it.. i don't know what seems...
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Sep 01, 2010 | Canon PowerShot SD940 IS / IXUS 120 IS...
Lens got stuck..how to make it work
If the camera has recently been dropped you may have lens damage that's preventing it from powering up. If it hasn't been dropped your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera - which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then clean the battery contacts, place the batteries back in the camera and give them a full charge (assuming that you're using rechargeable batteries). This cleaning clears the problem about 80% of the time. It's also possible that the lens zooming mechanism is sticking due to a buildup of sand, dust, etc. To remedy this, try cleaning the area where the lens meets the camera with canned air. If these solutions don't work for you, it may time to replace the batteries, or the camera may have a problem that requires professional repair.
BillB
Feb 14, 2010 | Nikon Coolpix L11 Digital Camera
I am having power supply and lens problem with a canon sd1000 digital camera. its not working with the battery inside and the lens got stuck and was not closing and now it is open but the camera is off and...
I am afraid you have the notorious lens stuck problem. If you google "canon lens stuck" or "canon lens not retracing" the results will be in millions. Canon's quote for repairing this issue is well over the cost of the camera itself. However all is not lost. It may be just dust. You can try to clean the lens contacts with isopropyl alcohol and see if resolves the issue. I have previously suggested placing the camera lens on the edge of the table and hit it with moderate force to force the lens back into the slot and I was surprised to know it worked for a lot of people!
http://www.fixya.com/support/t240817-camera_error_e45
Might be worth a try after getting a quote from canon?
Dec 25, 2009 | Canon PowerShot SD1000 Digital Camera
My camera lens isn't working, how can I reset it?
it sounds like there is dirt, dust or something else in the lens mechanism. I'm assuming you don't want to take the camera to a repair shop. I've had several cameras and this issue comes up periodically.
You can try:
1. using compressed air (with as thin a nozzle as you can find) to blow out the dust,
2. try powering on the camera and zooming the lens at the same time, 3. gently knocking the camera on a hard surface to loosen the lens mechanism,
4. manually forcing the lens to go back in. This can potentially damage the camera, but it's not working now, so you don't have a lot to lose.
5. Googling the camera model to see if you can find instructions on opening the camera up to clean the lens mechanism.
Oct 09, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
My L200 samsung camara is frozen and the lens are stuck out
I had the same problem - and wondered if if might be that the battery didn't have enough 'grunt' to close the lense - so I am charging it via the actual charger (rather than through the computer) and sure enough, I turned it on and then off, and the lense closed. The green light comes on when I plug the camera into the computer to download photos, and I thought this was therefore charging the battery, but maybe it doesn't charge it properly. Anyway, my lense is now closed and the battery is still charging (light is still red). Good luck.
Jan 06, 2009 | Samsung L200 Digital Camera
Kodak V550 EasyShare
hmm, that happened to me too when the battery was dead. try recharging your camera. make sure it is sitting on the charging dock right. make sure the charger is plugged in and it's working. see if the battery was put in correctly. if none of this helps, try a different battery, maybe the one you bought is no good. who knows what shelflife is on those
Mar 08, 2008 | Kodak EasyShare V550 Digital Camera
Olympus T100 Digital Camera Logo
160 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
