Question about Garden
I have a yard machine mower model 660 thru 679 how do you change the spring on idle pully bracket
mickey813
  • 472 Answers
SOURCE: installing belt on mower deck
CALL1800-959-4683 ASK THEM TO SEND YOU A COPY OF IT THAY WILL
Posted on Sep 30, 2009
SOURCE: I HAVE A 660 SERIES MTD YARD MACHINE 17.5HP 42
I have a yardmachine snow blower and I like to know how do you take the tire off to put a new one on?
Posted on Jan 14, 2010
  • 80 Answers
SOURCE: yard machine mower start and quits
this sounds like faulty switch or more likely a break in the cord close to the where the the extension cord exits the machine.
Posted on Jan 28, 2010
  • 146 Answers
SOURCE: 609 yard machine tractor idler pulley spring broke
Here's a diagram, not a great copy, but it may help:
The spring hooks to the idler arm on the opposite end from where the pulley is mounted. The other end of the spring looks like it hooks to a raised tab on the deck, straight behind the left mower spindle. Hope this helps you, please rate my solution if so, thanks!
Posted on Jun 08, 2010
vincob
  • 718 Answers
SOURCE: MTD Model 660-679 riding lawn
Go to this website, upper right hand corner and do a parts look up. Search for your model and that good stuff they ask of you and then choose mower housing should be there, browse the site it's really cool and has a lot of info.
http://www.jackssmallengines.com
I did a sample search for generic engine diagrams and found great diagram of engine. Give it a try you will find same results Good Luck! Don't forget the thumbs!
Posted on Aug 14, 2010
How do i rewind the recoil spring on my craftsman lawn mower?
Normally these small engines use a clock spring to retract the rope.
Remove the cover on the top and you should find the spring either broken or the tab where the spring end has broken off or jumped out of the mount.
You will need to pre-load the spring with enough tension to retract the rope.
Remove the pull handle from the rope, load the spring and then wrap the rope around the pully holding the pully and spring in the loaded position. place the end of the rope through the hole and tie up the handle. The rope should pull and retract without being installed on the engine.
Best explained here...
https://www.youtube.com/watch?v=tmo6oYOJJ4U
Jun 27, 2014 | Mtd 22" Yard Machine Push Mower
Idle adjustment screw
Most lawn mowers do not have idle adjustment screws. They typically have governors with governor springs, or a throttle spring and/or throttle cable. Perhaps a picture would help.
Aug 18, 2013 | Yard Machines Garden
How do I put the drive belt back on my yard man automatic riding lawn mower?
The v side of the belt goes in the v of the pullies and the flat side of the belt rides on the flat pullies. It looks like the flat idle pully is bent out of alinement. The one showing in video with no belt on it that is the last pully the belt runs on before returning to engine. The belt comes from the engine to a spring loaded flat pully, to v pully on right of mower ,to v pully on left, to flat idle pully // that looks to be bent // then back to engine. Put belt on all pullies saving the spring loaded pully for last.
Apr 09, 2013 | Garden
Idle is too slow
check under the air filter and u see a spring and the end thats attached to the stationary piece bend it to stretch out spring
Sep 06, 2012 | Mtd 22" Yard Machine Push Mower
I have a riding mower MTD 660-679 model with a battery that won't turn over
If it was sitting all winter the battery should be charged.
Mar 22, 2011 | Garden
Pull start cord got pinched. Dumb me took off
Yes you can put the spring back in but it takes patience. Wind the spring inside the pully first. Then install the cord on the outside of the pully. Make sure you wind both in correct direction. You probably should replace the cord while you have it apart. The parts would be listed by the engine brand and model number, not by MTD. Probably a Briggs & Stratton engine? You can go to their web site :www.briggsandstratton.com to get part numbers. Or you can try a place like www.jackssmallengines.com
Jul 18, 2010 | Mtd 22" Yard Machine Push Mower
Mtd 22" low idling how do I correct the problem?
if this has a briggs & stratton engine on it, then the idling is set thru a spring on top of the carberator. some units have an idle set screw also. if it has an idle set screw, turn it in untill it idles where you want it to, if it just has a spring, then replace the spring.
May 28, 2010 | Mtd 22" Yard Machine Push Mower
Rpm fluctuates idles high then low high then low
It could be the governor spring is weak. Get your model type and code numbers off the engine shroud and take them to your local small engine repair shop and get the new spring. It's not hard to replace. Install the new one and you should be up and running.
roundo4
May 23, 2010 | Mtd 22" Yard Machine Push Mower
Spring keeps breaking on mower deck belt tighener.
I would try getting a stonger spring but the same length as the orriginal spring. The spring still needs to have enough tension to pull the pully back, if you get one that dosn't have as much tension it wont pull the pully tight enought.
Apr 22, 2010 | Mtd Products Yard Machines 158CC Tiller
Diagram for Lawn tractor instalation belt
managemyhome.com has many manuals for yard machines/mtg lawn tractors.
The information you need may be generic and therefore almost any manual may help re-install the belt. This manual is for the 660-679 series. Once at the site you can check different model numbers for one that may be closer to the machine you have.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0403122.pdf
Good luck,
Techjoel
Jun 04, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
