Question about Cub Cadet Garden
I have a cub cadet tiller its a honda gc ft24 model number 21a-395a756 i replaced the carb last year run it off and on all year during the winter i started it once a week. i went to use it today it will not start, if i pour gas or use starting fluid it will run until the fluid is gone then stops i think maybe im missing some springs do you have a diagram showing the spring set up or did the carb go bad i have gas going to the carb thank you
  • Anonymous Mar 22, 2014
    Maybe carb problems good gas it just won't run
    It hasn't even been used it never would run right
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly.
I think you just have debris in the float bowl and the jet where the bowl nut threads into the bottom of the carb but here is the engine parts manual:
http://www.hammerwall.com/Download_Manual/115010
or
http://manuals.mtdproducts.com/mtd/GetFile.do?filename=gc160a-mha2.pdf
http://www.hammerwall.com/Manuals/MTD/Description/21A395A129/MTD%20Tiller%20Honda%20Engine%20Parts%20and%20Diagrams/gc160a-mha2/
You have to click on manual location and then enter a CAPTCHA script of 4 digits when they appear.
The 2 metering jets are items 19 and 10 on pages 17 and 18 of the manual.
^- I think this is where your problem lies. Simply cleaning with some carb cleaner in the threaded are where the bowl nut threads into the body usually gets them going again. If not you will have to use a thin bladed screwdriver and first remove orifice jet 19 then jet 10, clean them up and reinstall.
Other possibilites: (Noted you said you had fuel to the carb)
1. The fuel tank port is covered in debris
2. Fuel filter Item 27 on page 22 of the manual is clogged.
3. Check all of the lines from the fuel tank to the carb on page 22 to include the breather line of the fuel pump. On this particular engine these lines are known problems. Especially the breather line that drives the fuel pump.
4. The fuel float needle can also have debris in it. Item 9 page 17.
5. The bowl nut itself has debris in it clogging jets 19 and 10 on page 17.
SPRINGS are items 4 and 5 on page 24 of the pdf file. There is also a spring washer item 7 on page 24.
Thanks for choosing FixYa,
Kelly
Posted on May 22, 2011
I need to know what brand and type of oil to put in my cub cadet rt 65 tiller
As 1st option,It would be best to call the manufacturer Cub Cadet,or their Authorized Repair Center,and ask them directly.
Refer to the manual that came with the tiller.
As 2nd option, a general small engine repair shop can be helpful too.
Have a nice day.
Apr 23, 2016 | Horizontal Ohc Engine 190cc,gc...
Engine starts but wont stay running!
Sounds like a dirty carb. Before you do anything if there is a cup on the bottom of the carb remove it and clean it out really well and clean the fuel jet. The jet may be partially plugged. Any dirt will prevent the engine from working properly. When taking it apart make sure you don't lose parts out of the float area. There should be a bot on the bottom of cup. remove it and your jets should be in the bottom of that bolt itself.
Apr 02, 2016 | Cub Cadet Ft 24 Front Tine Tiller 2010...
I have a cub cadet rt65 tiller. Had a new honda gc 190 engine installed and now there is no power getting to the tines. Tried a new belt and that did not help.
Check and see if the safety pin in the shaft on your drive pulley or your tine shaft is broken. Does every thing turn up to your tines if so that could be the problem. There is a pin that breaks instead of doing damage if you hit something. After a while they just wear out.
Feb 09, 2015 | Cub Cadet Garden
How do I find year model on Cub Cadet rzt 50
The Manufacturers Serial and model numbers should be on a plate under the seat. Go to the Cub Cadet Website navigate to Manuals, enter the Serial/Model numbers and the year of manufacture should pop up.
Sep 21, 2014 | Cub Cadet Riding Lawn Garden Zero Turn...
Oil drain location on cub cadet rt65
How old is it? Lots of newer small engines don't have a drain plug. You tilt it on its side and let the oil run out the oil filler hole after removing the dip stick. I put a piece of plastic shopping bag over the gas tank hole and put gas cap back on to help keep gas from coming out. Good luck.
Jul 26, 2014 | Cub Cadet RT65E - RT65E 18" 208cc Dual...
Cub cadet LT-1042 blades spin when motor is turned on, pto lever does not turn on or off blades
sound like you have some wires shorted out follow the wires from the clutch back to the switch
Apr 08, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
I have a cub cadet #2135. Had it overhauled last winter--new blades, new battery, new pto switch and changed oil. Recently the mower runs for about half an hour and then quits--seems to be too hot--but i...
Maybe your fuel is getting too hot and causing it to be vapor locked. Check to see how far the fuel line and the fuel filter are from the engine on the approach to the carb. If you are able move the line away some. You may want to move the fuel filter closer to the carb. so that any vapor bubbles can come out in the upper part of the filter allowing for free flow of all the way to the carb.
If really helpful, please rate.
Jul 12, 2011 | Cub Cadet Street Sign- tractor lawn riding...
I don't think my tiller is getting any juice to the sparkplug. I changed the sparkplug and air filter, checked the oil and gas, but it still won't start.
disconnect the kill wire on the motor and then see if you get spark. If so its your switch, if not it either points or electronic coil or regular coil or condenser problem did you gap the pints correctly and was there a problem b4 you changed the points.
May 03, 2011 | Troy-Bilt Pony Garden Tiller
What are the propper oils and lubes for the model 127 cub cadet?
Well, personally, i use a normal engine oil; what ever your preferance. i use pennzoil. for the engine, the weight that they call for at cub cadet in those days is winter-5w20-summer 10w30. they call for a low ash oil, you can get it at any cub cadet or internation harvestor dealership. the rear end, if its a hydro stat takes hy-tran fluid, also sold at the dealer. you cant use anything else in a hydro, theyre real touchy. if its gear differential, any 80-100w gear oil will work. hopefully this helps, ive been dealing with old cub cadets for a close to 20 or more years. good luck!
Aug 14, 2010 | Cub Cadet Model 18611862 Parts Operators...
After a period time, my cub cadet push mover won't start.
I would be a spark tester on first,see if your getting spark,mabey bad coil or wire. If your getting spark I would have the carb checked out.
Aug 02, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
791 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
