I have a nobo 2000w panel heater. I need a new circuit board because the battery in the board has leaked acid. Board No. is 1150601-4 NOB0 can you supply this part. yours jason lowe
SOURCE: need circuit diagram for bush
Diagrams i am sure as you know are not always easy to come by, at least for free. I see that there are available boards online and a company that will rebuild this model of power board for you in UK. ohmsupplies.co.uk is where it is at. looks like $80
Posted on Oct 16, 2008
john224
  • 1378 Answers
SOURCE: circuit board inside power supply is bad. I need a replacement
You'll need a replacement board. You'll need model and serial numbers off of the cleaner itslef to help identify which power supply and therefore what PCB is needed to replace yours. Try contacting our service center at www.arrowmotor.net and click the contact button in the upper right corner.
Posted on Jun 13, 2009
  • 49 Answers
SOURCE: my heater does not turns on
if this is a high effeciency model, the venting may not be clear or the drain may be partially plugged. if you hear any sort of water gurgling in the inducer motor, you probably have one of these conditions. if that checks, see if you have 110 volts to the hot surface ignitor. if you read voltage there after the inducer comes up to speed, then you need a new hot surface ignitor. if no voltage, then the pressure switch is still not closing. concentrate on the condensate drain and furnace venting.
Posted on Oct 27, 2009
  • 980 Answers
SOURCE: brother sewing machine circuit board is out need new one
If you have any problems with sewing machines with electronic boards or if the machine is computerised it is wise to take it to a specialist for repair.
Posted on Nov 04, 2009
heatman101
  • 43501 Answers
SOURCE: How do I know if I have 240v when replacing old baseboard heaters
When you turned off the power to the heaters was the breakers a double (2 pole ) one? If so, then yes, it defintely is 240v. There are very few 110v baseboard heaters out there anyway. The best way to check is to have an electric meter and check it out for sure. Actually if you are working on electrical circuits and you do not have an electric meter to check if you have them shut down for sure, you are on dangerous ground. Always be safe and check before working on any circuit.
Posted on Nov 14, 2009
CAMERA
The only way to fix this problem, is to bring in to the place you bought it and see if they have a technician who can look at it or do it yourself.
I can tell you that whenever batteries are left in any battery operated device and corrosion happens, that corrosion will leak into the circuit board and destroy some of the components.
If you are lucky, you can open it up and clean it.
Just be careful when openning and do not use a solvent in it, unless it is one recommended for cleaning circuit boards by an electronics technician. The cleaners some technicians use are not even for electronic, but have been tested on delicate circuit boards and have been proven to be safe.
Ask someone like a geek at best buy or some other shop to find out what to clean it with.
Feb 13, 2008 | DXG Technology DXG DXG-301V Digital...
I have some nobo e4eu electric panel heaters with 7 day programmable timers,does anyone know where i can get instructions on how to replace and swap over for a new one?
There are not even photographs of the product online...
That tells me that nobo might be using generic timers made by various manufacturers.
And they might not use the same timer one year to the next... preferring to sell whatever they can buy with lowest price.
A lot of companies re-brand generic products and sell them under their brand name, and folks assume the company made the product.. and the company has manuals... but they don't manufacture anything... they just sell stuff.
First Alert, Timex, Kingshield, Stanley, ... are examples... I suggest not buying products from companies that do not post manuals
maybe you can find a manual by doing a google image search for timers, heater timers, or Nobo ... and seeing if you can find similar timer.
Nobo timer manual below is also sold under Sunlight and Timex brands.
http://www.e-tradecounter.co.uk/PDF/p-1125.pdf
Gene
Oct 08, 2014 | Hardware & Accessories
Water leak problem on passenger side floor board of 1992 chevy caprice classic. Need help???
either the air conditioner condensation drain is clogged orb the heater core is leaking .
Nov 19, 2013 | Cars & Trucks
Magellan gps 315 battery leaked and will not power up. what could be wrong
The acid from the leaking battery most likely shorted out the circuit board. You can trying cleaning of the acid spill with a little alcohol on a Q tip. The batteries are probably also no good and you will need to replace them also. If this does not work you can try taking the unit apart and cleaning any further acid that has leaked to the inside. Thanks for using FixYa
Here is a link to the manual
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000013645.pdf
Jun 19, 2011 | GPS
My bose av 321 IImedia center remote isnt working , is there a way to program it, have new batteries in now
One does not have to program the original remote of the media center, yes even if the battery runs out. It is pre-programmed and you cannot change that .
What you have to check is if your previous battery leaked inside ( was there any wetness in the battery compartment when you replaced the previous battery? ). The acid / alkali in batteries are known to corrode the circuit board and components . You might need a replacement instead of a fix .
Apr 10, 2011 | Bose (321GS) System
I own a sony icf sw 7600g short wave radio which worked perfectly until recently when I believe a battery may have leaked and now it is caput with nothing coming on ; dead dead ! is it fixable and can you...
When a battery leaks it leak acid which can damage or ruin everything it touches. First how extensive was the leak? Was it just a bit or did it seep onto the circuit board? You can clean the terminals. Remember your dealing with battery acid. Do it over a metal can and brush the terminals with a small wire brush. (Don't touch your eyes until your finished and have thoroughly washed your hands.) Just like you would a battery terminal. Then when down to the metal again use a regular pencil eraser to finish the cleaning. You may try a drop of flux per terminal as well after using the wire brush. If a wire was negated then soldier a new one in. You can also use a small, dry, non soap impregnated SOS pad in place of a wire brush. Install new batteries and give it a try. If no acid ruined the circuit board it is just an issue of getting the terminals to run current through them again.
Mar 07, 2011 | Sony ICF-SW7600 AM/FM/SW Radio
I have some nobo e4eu electric panel heaters with 7 day programmable timers,does anyone know where i can get programming instructions or just how to get them to work? I have tried google but nothing yet ...
The instrusctions are available in english on the australian site: http://www.nobo.com.au/Brochures/Shared/NOBO%20Timer%20Operational%20Instructions.pdf
Other useful documents available here too.
Oct 16, 2010 | Heating & Cooling
Nobo heater
the nobo heater cant keep opening for long time, i just turn it on then secound its turn off by self, i dont know if there have time contorl or not? the one im sure its not broken , just dont know how to fix this out,please help.thanks!
Feb 20, 2008 | Heating & Cooling
Heating & Cooling Logo
148 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
