Question about Kenmore 91112 / 91114 / 91117 Electric Kitchen Range
My kenmore oven keeps saying f7 and doesn't work
    Sergeant:
    Champion:
  • 226 Answers
In another posting I saw that a Technical Data Sheet was taped inside the top control panel. I opened it up (two LONG screws mounted vertically in the top of oven door) and was able to access the Technical Data Sheet. It DOES have all the "F" codes listed, AND instructions for setting many variables within the oven. CAUTION: !!!! if you are NOT experienced working on ribbon cables, the delicate connectors and in close proximity to "hot" wiring... I DO NOT recommend attempting this... Call a repairman or find someone who IS familiar with all of the above.
Posted on May 22, 2011
On a Kenmore gas oven the flame goes on and off and doesn't keep a constant temperature.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 19, 2011 | Kenmore Ovens
When the electricity goes out the F7 button comes on and the manuel says to turn the power to the unit of and it still comes back on
Unfortunately the F7 error code normally means a problem in the controller or touchpad (replacing both is common and parts alone is about $300)
You might try shutting down the power. Then finding the ribbon cable connector for the touch panel, unplug and clean the edge connector with a #2 pencil eraser. Sometimes that improves the signal enough that it will work a little longer, sometimes it doesn't and then you are talking about a $300 parts expense plus your labor or the $300 parts and Service call and labor expenses if you call a service tech.
Jun 05, 2011 | GE Profile JTP56 Electric Double Oven
My kenmore elite microwave when turned on shows a f7 error code.
f7 keeps showing up and the microwave keeps cutting off,f7 code shows up. what do i do
Oct 26, 2010 | Kenmore 68361 Microwave Oven
I have a Kenmore built in oven, it doesn't work. There is a code F7. What could that mean?
Hello there:
Here is the list of f7 codes for this oven and what they mean and what needs to be checked and fixed
F7 Function key shorted Replace touch pad
F7 Function key shorted; too hot at the clock assembly (also called the ERC) or shorted touch pad or clock assembly (also called the ERC) Replace touchpad or ERC
F7 Lock motor relay watchdog circuit is active when it should be off Microprocessor checking the operation of the EDC lock, relay failed. Replace EDC.
Oct 05, 2010 | Kenmore Ovens
Oven keeps blinking F7 AND WILL NOT WORK
Hi
Thanks for using FixYa. Error F7 on your Kenmore means that the keypad is shorted or stuck and to resolve this issue you’ll have to replace the electronic range control (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 15, 2010 | Kenmore 42161 / 42169 Electric Single Oven
F7 error in Kenmore double oven
You can find my solution to the most common cause of the F7 problem at the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared my fix with over two thousand unhappy GE customers. Most report success. I hope that it works for you too. Please let me know by sending an email to:
hutchipop@yahoo.com
Regards,
Powerman
Nov 20, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Kenmore drop in range code F7
Oven control beeps and Electronic control as detected fault condition.
Press CLEAR to clear the display and stop displaysF1,F3, F7 ,or F9 beeping.
Program oven again.If fault recurs,record fault number.
Press CLEAR and contact your Sears authorized qualified service agency.
Oct 17, 2008 | Kenmore Kitchen Ranges
F7 keeps flashing
I have read that F7 refers to the problem of the digital panel control.
Jul 05, 2008 | GE JKP28 Electric Double Oven
Kenmore double oven
This is what f 7 means:
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Will need to replace the oven control. Part # is WB36T10486 for black and WB36T10488 for white. Cost is $314.75 for black and $417.99 for white. You can get it at http://www3.sears.com/.
Nov 16, 2007 | Kenmore 47772/47774/47779 Electric Double...
Double oven
ovenman, there's not a complete model number here but in the Kenmore line F7 is the code for a stuck function switch or bad keypad. Makes sense that it's telling you to start the lower oven. Try removing the ribbon cable from the board and cleaning the ends with an eraser. Reseat it and see if the code comes back. Make sure to kill the power before doing this. Catriver..post back.
Mar 28, 2007 | Kenmore 47732 / 47734 / 47739 Electric...
Kenmore 91112 / 91114 / 91117 Electric Kitchen Range Logo
168 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
